Old 10-18-2020, 09:40 AM   #176
GerhardH
GerhardH's Avatar
Re: My 1968 C-20 Golden Anniversary Project
THANKS DALE!
Found out that the NOS flame arrestor #3857476 is wrong- too big, see picture. Fortunatly I have a complete set from our fellow ROOGER KOOP here in the forum.
Best regards GerhardH!
Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20
1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400
http://67-72chevytrucks.com/vboard/s...d.php?t=760400
GerhardH is offline   Reply With Quote
Old 10-18-2020, 10:01 AM   #177
GerhardH
GerhardH's Avatar
FOUND THE RIGHT FITTINGS FORE THE OIL PRESSURE GAUGE AND VACUUM GAUGE INSTALLATION.
NAPA 302X2, 6200X2, 6100X2
LMC truck 36-1923 Oil Pressure Tube Kit-49", 31-3406 Vacuum fitting-Tee-Barbed,31-3404 Barbed Fitting-Gauge
Bolts Air intake Manifold: ARP 134-2001
Old 10-18-2020, 10:18 AM   #178
GerhardH
GerhardH's Avatar
Preparing Water outlet, found out that my manifold despite the same casting number as the original has not the hole for cooling water (connection to pump), therefore I try the riser (thermostat above the opening for the hole)
Old 10-18-2020, 10:23 AM   #179
GerhardH
GerhardH's Avatar
Some more pictures:
Gasket FEL-2202
Vintage Air water Neck Riser VTA-706001-VCQ
Water outlet four seasons 84820
Thermostat: Mr Gasket #4365 195° Fahrenheit (90.5° C)
Old 10-18-2020, 10:30 AM   #180
GerhardH
GerhardH's Avatar
Further manifold accessories:
Vacuum fitting (for power brake, heating/air condition reservoir & transmission TH400, spigott must be inside the fitting.
Distributor fittings
Old 10-18-2020, 10:39 AM   #181
GerhardH
GerhardH's Avatar
Rockerarm Kit SUM -G6800 1.5 Ratio, Fits 3/8" studs
Hydraulic lifter Federal Mogul HT-817
Engine Mount screws totally stainless 6-2259
Old 10-18-2020, 10:51 AM   #182
GerhardH
GerhardH's Avatar
Temperature sending unit: 01513321
Preparing exhaust manifolds #3896956 #3855163
Exhaust Manifold LH (Driver): 3855163 L.H (Cast 8155163A or 3855163A), interchangeable 387241
Exhaust Manifold RH (Passenger): 3896956 R.H. (discontinued use 3905364 or 3932469)
Preparing some measurements camshaft degreeing
Old 10-18-2020, 10:56 AM   #183
GerhardH
GerhardH's Avatar
Oil dip stick Kit PRO-66116
Some pictures regarding exhaust gas mainifold heat shields
Old 10-23-2020, 08:18 PM   #184
cornerstone
cornerstone's Avatar
Amazing work Gerhard! You're going to have the nicest C10 in all of Germany
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 08-09-2021, 10:08 AM   #185
GerhardH
GerhardH's Avatar
Last entry from 10-18-2020, 04:56 PM , was completly frustrated, because of the not matching valve timings (tested with Summit Degree Wheel), after studing and learning alot now new hope, start soon.
Old 08-10-2021, 06:45 AM   #186
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Goodness, you're getting technical. I'm glad to see you're still around....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-26-2022, 04:24 AM   #187
GerhardH
GerhardH's Avatar
Hobby is gone, truck sold, was a nice time here in the forum
Old 05-26-2022, 07:13 PM   #188
68bowtie
68bowtie's Avatar
Noooo! Say it isn’t so. Call it temporary, leave the door open just in case another truck happens to cross your path.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 05-28-2022, 05:52 AM   #189
LT7A
Oh man, hadn't seen this build before, was just getting into it. I've never seen such detailed care taken in engine assembly. Good luck Gerhard. Sorry to hear that you sold it, but sometimes that has to happen. Hope to see you back. It looks like you got it all together. How did it run?
Old 05-30-2022, 06:58 AM   #190
Ol Blue K20
You can still stop in Gerhard.
Dale
Old 05-31-2022, 05:00 PM   #191
cornerstone
I'm surprised! What's the next project Gerhard?
Brian
Old 09-22-2023, 12:18 PM   #192
JerDom
I JUST came across this thread.
I knew this was going to happen
I gave, made, sold many parts to Gerhard and tried to give him a lot of common sense advice but being a German engineer he was determined to complicate the living dung out of everything.
I always wondered if he'd frustrate himself into packing it in which looks like finally happened - so sorry , too bad
Jerry in Canada
JerDom is offline   Reply With Quote
327, c-20, golden anniversary, th400, truck
