01-09-2019, 12:34 AM | #176 |
Re: What did you do to your truck today.The 3rd chapter
Making filler pieces from scratch
Do it, Do it right, Do it right the first time |
01-09-2019, 12:59 AM | #177 |
I ended up benching the bushings onto the control arms without the shafts, and then reinstalled them with the shafts mounted. You can't help be off more than a pinch center. For the most part I put equal turns on the bushings all the way through, and they wrenched on fairly smoothly. Couldn't tell you what 90 and 100 ft. pounds is using a crescent wrench, but they're probably close. I'll let the alignment gang work that one out.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-09-2019, 10:03 PM | #178 | |
01-10-2019, 04:43 AM | #179 |
Nice work on the patch panels. I have the exact repair to do on my door. How do you get the edge bent over to go over the inner door. I can see from the speaker hole pic looks factory perfect. I have to admit i'm kind of a stalker for your vermillion red truck. Thanks
01-10-2019, 07:27 AM | #180 | |
Thanks man.
01-10-2019, 11:28 PM | #181 |
How did I get this OLD!
My good friend Robert was on his way to have his buddies restored. I asked if I could trade him my 68 console cushions for his 67. I replaced the rotted ply wood, give them a little scrub, added some Gorilla tape & a flash coat of Fawn Beige lacquer. Good enough for a 67 driver.
http://67-72chevytrucks.com/vboard/a...1&d=1547176723
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
01-11-2019, 12:24 AM | #182 |
[QUOTE=Canuckvetter;8440909]My good friend Robert was on his way to have his buddies restored. I asked if I could trade him my 68 console cushions for his 67. I replaced the rotted ply wood, give them a little scrub, added some Gorilla tape & a flash coat of Fawn Beige lacquer. Good enough for a 67 driver.
Hell ya nice score and nice reconditioning.
01-11-2019, 12:33 AM | #183 |
Got all my filler pieces done
01-11-2019, 12:40 AM | #184 |
Are you going to paint them black or body colour?
01-11-2019, 01:39 AM | #185 |
I've been playing on 3D paint with the two colours and I'm leaning towards black. The blue pulls away from the engine and makes it look small. I'm going to paint the under side of the hood which will brighten the look
01-11-2019, 09:56 AM | #186 |
Installed a Saddle Cheyenne Super seat cover from Larry @ Truck World.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
01-11-2019, 01:15 PM | #187 |
Looks great. What is the link to them?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
01-11-2019, 01:40 PM | #188 |
Larry is old school. No link because there's no website. His PayPal is an AOL address. PM me and I can help you if you want to buy Truck World products.
01-13-2019, 03:17 PM | #189 |
finishing the fine tuning of everything before inspection/registration... so close to cruising!
01-13-2019, 07:07 PM | #190 | |
I didn't get anything done to mine as I was busy running the snow thrower Sat. and today. Winter has finally arrived in Central Indiana
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
01-13-2019, 07:14 PM | #191 |
Must suck to have snow, It's a good thing I live southern Ontario Canada, we don't have any. So I spent the day in the shop. New LED bulbs in 5050K color is perfect. Doesn't need a dimmer looks just right.
01-13-2019, 08:11 PM | #192 |
Beautiful truck
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-14-2019, 09:46 PM | #193 |
Rainy day in San Diego. Prepped hubcaps for black paint.
01-14-2019, 10:44 PM | #194 |
I changed out the door lock cylinders with new ones so that my doors could actually lock. Before the rain hit here I was also able to install the new repo wiper arms and wipers along with my parking brake handle
01-16-2019, 12:40 AM | #195 |
Installed the oil pump and pan, and detailed some spots missed underneath. I was concerned about settling, because the POR15 is heavy. But in hindsight, it have been better to rotate the block when I originally brushed the paint on.
I installed the battery clips at the 2nd and 4th 5/16" bolts from the front, and the transmission lines retainer 3rd from the front. I'm not 100% sure that's what is was from factory, though suspect it is. EDIT: And yeah they're two different colors. Two completely different situations. The guy who painted the pan took a paint sample, and he's the best for many miles. But two completely different situations. I brushed three coats of engine enamel on the block. The pan was sprayed with automotive paint, primer'd and clear coated. The oil pan looks darker to me, someone else says lighter, but then I'm shade blind. I tried brushing the pan, and came close before I (*^)^ed with it. Then I proceeded to strip it. I wasn't planning to brush the valve covers anyway, so yeah, the valve covers vary as well. I'll try to enjoy it with the black and Ochre, and some engine compartment specials. Call me crazy, but somehow the shade variance is lost when it's right side up, and the valve covers were sprayed with the pan.........Hmm. Maybe I'll spin it sideways, see what happens then
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-16-2019 at 06:37 AM. |
01-16-2019, 03:56 AM | #196 |
Installed upper shock absorber brackets. Took about n hour n 20 minutes per side but I'll sleep better knowing it's done. No pictures but if your truck needs it , do it
01-16-2019, 08:28 AM | #197 |
Started stripping engine for removal
Next will be some engine bay cleaning and some paint Before the new engine goes in |
01-17-2019, 10:50 AM | #198 |
Old member
Out with the old 3 on the tree column and in with new to me tilt for 4 speed. I made this tilt out of a auto tilt by shaving off the indicator and gear lever.
01-17-2019, 11:37 AM | #199 |
Tear down complete on the 71 K10 Cheyenne. Going back to the original Hugger Orange on Saddle she came from the factory with.
01-17-2019, 04:25 PM | #200 |
Put lowering spindles and a 4 inch shackles in rear. Building this one for the wife,so we can cruise and go to some shows this summer
