Old 04-16-2023, 11:00 PM   #176
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: Rodstored-72's 1986 DD build
Well I finally have taken some time to update. The build has been a hi/low venture. Unfortunately, I have had another engine setback, not of any of my doing. I guess no one was aware of the DOD and nonDOD versions of the gen IV engines (’07-’14 years). So, I am unfortunately having to get another engine. I am currently in the rebuilding stage for the 3rd engine, yes, I am typing correctly. This time I took it to a shop that has expeiences with this in LS swaps and they are aware of what needs to be done. They have pulled, are rebuilding, and then will reinstall the engine back to turn key status. This was a VERY HARD pill to swallow. Lessons learned, I guess. Anyways I have recleaned the engine bay and came up with a better computer mount plate while the truck has been sitting in my garage. I also redid the fuel tank venting so to go to the OG charcoal canister at the front and ran some lines to help hopefully help the emissions equipment passing. I really don’t have any pics as it has already been documented in previous posts.
Thanks for joining in the build hopefully it has benefited some…
rodstored-72 is offline   Reply With Quote
Old 04-16-2023, 11:26 PM   #177
rodstored-72
chevy truck fan
I remembered that I did take a picture of the new ECM mounting plate. I used the factory jack holes. the alum plate is rounded on the corners and just fits the ECM. I cleaned and painted the plate "chrome". I attached rubber stand offs to "raise" the alum. plate off of the fender well. utilizing 1/4x20 bolts and nutserts (rivnuts?). the ECM is mounted using the factory 4 holes and again I used 4 rubber standoffs to raise it above the plate mounting nutserts. the ECM mount screws are 10-24 and also used nutserts. overall it is a cleaner mounting situation as well as more sturdy too.
enjoy!
Old 08-07-2023, 10:50 PM   #178
rodstored-72
chevy truck fan
I have been very busy on the truck, while waiting for the engine debacle to be finally sorted out, I have been working on other things… like interior! I decided to switch interior color to black, the OG maroon interior just wasn’t jiving with me.. considering it is a red truck and staying red. So I am going to go with a black interior. I also chose a red/blk houndstooth material for accent color. Below are pics of the door panel look. i also have the upper trim strip (no handle) yet to install. will do that along with the inner channel when i do the final complete install of the whole interior redo.
Old 08-07-2023, 11:17 PM   #179
TKCR
TKCR's Avatar
That looks nice. I agree about the Burgundy in the Red truck, that’s why I had to change mine to Charcoal.
Old 08-07-2023, 11:18 PM   #180
rodstored-72
chevy truck fan
I also have mounted the seats that I found. Supposedly 2012 chrysler pacifica seats and with a 2019 silverado center console. The material is not a exact match, but it is pretty good for a daily driver. The bracket is 1/8”x 1” steel strap and 3/4" square tubing at seat mounting locations. I used nutserts for console attachments. Overall it works well. If to do it again a would use a thicker steel strap and maybe put a few more supports around the bracket. A few pics for viewing pleasure. the pic with the red insert is just a pic of the idea I am going for, but with the red/blk houndstooth inserts.
Old 08-07-2023, 11:23 PM   #181
TKCR
TKCR's Avatar
Now you just need some pretty black belts.
Old 08-08-2023, 12:41 PM   #182
rodstored-72
chevy truck fan
tina, LOL!! AGREE!! I first need the cash to buy those wonderfully refurbished belts!! when able, I will send you my maroon set. thanks!!
Old 08-08-2023, 12:45 PM   #183
TKCR
TKCR's Avatar
Old 08-08-2023, 12:50 PM   #184
rodstored-72
chevy truck fan
in general, the truck is FINALLY road worthy. I have it running, charged the AC, FINALLY!! got it to pass AZ emmissions. and now the daunting tasks of fixing ALL the other things to make it a dailly driver.
- fixing issue with why the ECM thinks the engine is at 250d? (dakota dig. gauges and BIM module)
- why AC compressor cycles off/on frequently (VA sure fit system)
- verify tank selector switch is functioning correctly
- many...many asthetic fixes...
Old 11-22-2023, 12:54 PM   #185
loudchevy
Active Member
loudchevy's Avatar
Nice build thread! That sucks that you had all those engine troubles. It's been a couple of months since your last update. Have you been driving and enjoying it?
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 11-25-2023, 01:18 PM   #186
rodstored-72
chevy truck fan
loudchevy (scott)... thanks!! yea.. the engine issues have REALLY been a setback..I guess that is why hindsight is better.. LOL!! yes I have been driving the truck a little bit.. still trying to figure out the discrepancy between physical engine temp & ECM temp. I had planned on taking it to Dino's...but! I got a wise idea to R-R the gearbox AND.. while doing that i decided to go ahead and get the column rebuilt sooo ... I did not take the truck (not able to get put back together in time) I am now just working on the little items to make it long trip worthy. I am currently working on trying to figure why the dual tanks don't seem to cooperate & the gauge does not work???
thanks for checking my build out.... i will keep checking on yours as well. i sold a nice '72 a few years ago.. so familiar with your to do's too!! LOL!!
