Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-17-2022, 04:22 PM   #176
landarts
landarts
Re: 71 K20 Idaho Edition
Originally Posted by jimbosprint View Post
Looks like you might need the same modified handles as mine. It's a little difficult to tell from the photos, but it seems like the connection to the transfer case is at the rear of the opening in the floor, not in the middle. I think his regular handles are for 1973 and up trucks.
Yes you are correct. I reached out to Jon and he requested the photos of the location of shifter boss in relation to the opening in the trans tunnel. He is going to go with making modified ones and I will cross my fingers they work out. If they do not I will just modify them myself I have ability and the tools if needed. Again thanks for the inspiration and always find myself going back to your build thread to review and enjoy the work you have done.
Super Cheyenne aka the "Devil Cowboy"
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 01-18-2022, 03:08 PM   #177
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work as always! That K10 looks like a very nice truck as well!
That Napa TEC paint, how well does it hold up?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-18-2022, 03:24 PM   #178
landarts
landarts
I have used it before a few years back on my 2WD Cheyenne. It still looks good but has not had much abuse either. Hard to tell at this point how good it will look 10 years down the road.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-18-2022, 07:38 PM   #179
landarts
landarts
Worked on getting the last few pieces to the cross member, mounts, and motor items primed and painted. I used the NAPA TEC satin for the cross member, mounts and bracket for the Brake booster and steering bracket, and the Duplicolor ceramic gloss black for the engine items. hoping that letting everything cure u[ for at least another 24 hours then I can begin to start putting the cross member back in then onto the motor install. The goal is to drive it out of the garage this weekend.
I also purchased a new tool that is a hydraulic crimper to do 2 gauge wire and other sizes. I am building my own battery cables and heavy-duty cables for the winch and jumper accessories with quick disconnects and a 3/8 terminal block.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-19-2022, 06:17 AM   #180
Dieselwrencher
Nice work. I might give that napa paint a try.
Ryan
Old 01-23-2022, 12:23 PM   #181
landarts
landarts
Was able to get the cross member and motor mounts in place for the motor install for this weekend. Also finished remounting the brake booster and brackets to the firewall, then installed the new flywheel and clutch. Got underneath the beast and removed the exhaust to see if it is possible to get a new one made at the shop by using the old one as a template.
Another side note I used a product called Calyx on my new ram horn exhaust manifolds and really like the look of it. I did a test section on one of the old cracked ones and it really dressed it up nicely. Thought before it is all said and done I would try using it on the master brake reservoir since it is cast iron.
Today I will look at possibly installing the new front lift kit springs while the motor is out to make things simple to get at. If I have a struggle with getting the old U-bolts off then I might skip to another weekend on that and just drop in the motor. Whatever gets done will still move the ball forward, little by little.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-23-2022, 06:43 PM   #182
landarts
landarts
got the truck off of the skates and pushed out into the driveway so I could take an hour and clean up the garage and mop the floor with some soap and hot water. Got picked up a bit and the floor swabbed down. After getting the truck back in the garage decided to get the front springs removed and set up for installation of the new springs.
Last night before I went in for the night I was able to crack the nuts loose a little bit and soak everything down with a little Kroll oil. Today I only had one or two that were still a little tight so I just worked them back and forth with the breaker bar then removed them with the battery-operated torque drill. It went really smoothly and was a little surprised. After getting the front springs off I tried to clean up the area around the spring u-bolt areas with the air needler and sprayed it down with some brake cleaner. Hope to get some paint on that area after a little more cleaning so I do not have to take it apart again to paint the axle.
Once the leaf springs were out I noticed the plastic material that goes between the leaf and axle was in bad shape so I will head over to the local 4x4 shop and grab some before I install Monday afternoon. Next will be to install the rear lift kit blocks and shocks, then drop the motor back in.
You will notice in picture three there are two sets of shock boots. When I ordered the kit I picked black shock boots and they sent gray so I called customer service and they said they substituted gray for black since they did not have any in stock. I told them I preferred the black so they sent out another set and told me to keep the gray also.
Pict 1,2 after the springs were removed
Pict 3 new and old springs, shocks, and shock boots
Pict 4 old an new hardware
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-23-2022, 10:09 PM   #183
jimbosprint
jimbosprint's Avatar
Nice progress!
jimbosprint is offline   Reply With Quote
Old 01-24-2022, 09:45 AM   #184
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice progress!
X2, looking good.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-24-2022, 11:27 AM   #185
Rickysnickers
I know where to go when or if I need some battery cables!! Looks great
Old 01-25-2022, 06:43 AM   #186
Dieselwrencher
Nice work! I've torn apart several of these trucks and never found the plastic in between the axle and the leaf spring. I have some front springs to remove in the next couple of weeks. I'm hoping those bolts come out and don't need to be cut out.
Ryan
Old 01-25-2022, 05:16 PM   #187
landarts
landarts
Nice progress!
Thanks Jim, I have been following along with your progress as well.
Originally Posted by Ol Blue K20 View Post
X2, looking good.
Thanks!
Any time just reach out.
These were really easy and I guess it was the luck of the draw or the Kroil Oil really did the job. I have had some that had to be broken or cut off and that is not any fun. I plan to save everything so if the next guy ever wanted to put back the stock stuff he can.
Here is a picture of the Kroil Oil if anyone is interested
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-25-2022, 10:13 PM   #188
57taskforce
All about them K’s
57taskforce's Avatar
Kroil is good stuff, I prefer it over PB. There’s another good one I like called Kimball Midwest.
I use both of them daily at work. Pb works good to obviously and I do use it often as well.
Truck is looking great by the way!
Ryan, where’s the fun in it all coming apart easily? all of my u bolts came apart with out penetrating oil believe it or not. Surprised the hell out of me, I’ve never had any other truck where I didn’t have to cut at least one of them off.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 01-26-2022, 10:13 AM   #189
landarts
landarts
Quick update with getting the prep done on front axle for some paint. Went over the axle with a needle scaler in a few hidden areas that hold dirt and grease, scuffed the axle with 120 grit paper and then finally with a wire brush on a drill. Wiped it down with wax and grease remover and shot two coats of rusty metal primer. Will let that simmer until after lunch and lay down a couple of coats of Tec chassis black.
Just trying to get paint in the areas where the leaf springs go for now, otherwise it would be a couple more days of cleaning and scrubbing. Plan is to get he truck running and driving again first, then come back around and finish painting other parts of axle and steering. Shooting for this evening to get the leaf springs installed so I can drop the motor into the cross member.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-27-2022, 09:29 PM   #190
landarts
landarts
Here is the axle after two coats of Napa TEC chassis black on the portion of the axle so I can get the leaf springs and shocks installed. When I do the maintenance on the axle and the outer spindles I will finish the cleanup there and spray.
Got the new wiring harness for the engine compartment area and gaskets and sealer for the heater box. Also received confirmation on the twin-stick setup from JB Custom Fabrication, he was able to modify the shift levers so they would fit properly. Also ordered a few toggle switches for the spotlights, USB ports, and other items for the under dash console I have planned.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-28-2022, 08:05 AM   #191
Ol Blue K20
Looks nice, I need to try that paint.
Dale
Old 01-28-2022, 09:15 AM   #192
landarts
landarts
Thanks, here is a link to the product from Napa Auto.
https://www.napaonline.com/en/p/MS_7243
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-28-2022, 05:20 PM   #193
landarts
landarts
Took my lunch break today in the garage bolting in the two leaf springs and getting it back to a roller. Have a few more items to clean up and paint next go around.
Had to do a little creative adjustment to U-Bolts to get them into the U-Joint cradles. Put them in the radiator support hole and stuck a long 3/4 pipe on one end and
adjusted the spread so it would go in nicely. Then used the dead blow to get them lined up in the spring perches.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-28-2022, 09:56 PM   #194
jimbosprint
I need to use "creative adjustment" from time to time on my projects too
Old 01-30-2022, 01:48 AM   #195
Dieselwrencher
It's looking really nice. I feel ya on the u bolt massaging. Been there a few times as well.
Ryan
Old 01-30-2022, 10:06 AM   #196
landarts
landarts
Battle with the rear u-bolts a bit, then decided to not let them win the fight so I took the angle grinder and cut them off. Installed the new 2.5 inch blocks and U-bolts without any custom adjustments to the u-bolts. Need to figure out how to adjust the emergency brake cable or get extensions on the end that hooks into the back of the drum plate.
After another cleanup session of the garage floor this morning I will move forward with getting the motor installed back into the truck. This should go smooth since all of the sheet metal is off the front of the truck. The first item that will get attention after installation is the radiator support, it has been prepped for paint so a few minutes of wiping down and a couple of coats of paint should be good to go.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-30-2022, 09:07 PM   #197
landarts
landarts
Got the cleanup done and finally was able to get the motor installed back into the "power barn" as Derek from Vice grip garage would say. It went pretty smooth for a one-man installation. But by the end of the day, I was spent from installing a lift kit and the motor. Only had one hiccup that I will need to remedy for the wire loom on the driver's side pinched the wires into the firewall and clutch rod. Looks like I will need to shave off the existing tabs and make my own mount so it can come forward about an inch or so. All in all, it was a great weekend getting things done on build and moving the ball forward so it can be a driver again in the next couple of days.
Last picture shows the distributor location with the small cap HEI Flamthrower distributor I bought from Pertronix. Has the external 45K coil right next to it to power everything up. Just about two full fingers between the cap and firewall.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-30-2022, 11:57 PM   #198
fakerwade
fakerwade's Avatar
Very nice!!
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 01-31-2022, 07:25 PM   #199
jimbosprint
It's really coming together now
Old 02-01-2022, 07:33 AM   #200
Ol Blue K20
Keep up the pace, you'll be driving it in no time.
Dale
