Old 01-16-2023, 09:18 AM   #176
KyleSeal
KyleSeal's Avatar
Re: My 1967 Build (Finally)
You can never have enough clamps. Getting this dash back in place wont be too difficult, but you can definitely see I'm in need of some more clamps, and here I was thinking I had enough
Also admiring the paint match on the dash to kick panel, not exact but close enough for government work!
Size:  63.7 KB Name:  IMG_4424.jpg
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 01-16-2023, 07:40 PM   #177
regan wilson
regan wilson's Avatar
Clamps and lots of them. That's good to know since I've never had one out. I'm sure that I will on my C-50. Good work Kyle.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 01-16-2023, 07:45 PM   #178
chewychevy67
Your doing a nice job making sure you get as much creep rust as you can. It would be a disappointment if you got the whole cab done and 3 years later rust was appearing in spots. Going backwards is not fun. Keep up the good work
chewychevy67 is offline   Reply With Quote
Old 01-19-2023, 09:15 AM   #179
KyleSeal
KyleSeal's Avatar
Ive never had one out either, this is my first one, but going well if I do say so myself. I was expecting a lot of work but its been rather straight forward. I had a small spot of rust breakthrough inside the driver side a-pillar where it met the dash, and had to cut the dash for the Vintage Air, so it made sense.
Like they say "while Im here..." but thats really what I keep coming back to, is thinking of going this far and not going a touch further and then having rust creep into the seams would be an incredible bummer. I appreciate it!
Old 01-19-2023, 09:47 AM   #180
KyleSeal
KyleSeal's Avatar
Although Im a ways away from having the seat in its final spot, I just had to toss it in the truck and see how it felt, and man oh man Im happy with it. I think this seat will wear well and will really make this interior a talking point. I also want to thank n2billet for putting this design on his Tiffany. It was the inspiration for the layout of this bench.
Size:  100.9 KB Name:  IMG_4465.jpg
Old 01-19-2023, 09:48 AM   #181
KyleSeal
KyleSeal's Avatar
More pix.... because.... why not!
Size:  85.5 KBName:  IMG_4464.jpg
Size:  44.7 KBName:  IMG_4469.jpg
Old 01-25-2023, 10:03 AM   #182
KyleSeal
KyleSeal's Avatar
Welded dash back in, and installed the Altman Easy Latches. Kind of looking like a truck now!
Size:  54.9 KB Name:  IMG_4693.jpg
Old 01-30-2023, 10:43 AM   #183
KyleSeal
KyleSeal's Avatar
Moving towards getting the roof installed, while I waited on the rain to stop so I could sandblast the new skin, I cleaned and painted the windshield pinchweld frame, after I ground down the dash welds. Once I had the roof blasted I etch primered and top coated with some black paint.
Size:  62.8 KB Name:  IMG_4725.jpg
Size:  41.9 KB Name:  IMG_4738.jpg
Old 01-30-2023, 10:48 AM   #184
KyleSeal
KyleSeal's Avatar
Roof will be installed in the next week or so. I will be using the SEM panel bond glue to hold the rear seam down, I have spot weld punches every 6 inches or so, a bit closer in the front to keep it from lifting. I see a lot of people mixing these two practices together so I think this will hold well. My first time using it, so we will see.
Size:  48.0 KB Name:  IMG_4748.jpg
Old 02-01-2023, 10:29 PM   #185
hewittca
hewittca's Avatar
Excellent work and build thread! You've made quite a lot of progress in the last year.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 02-02-2023, 10:44 AM   #186
KyleSeal
KyleSeal's Avatar
Thank you! Funny you say that, it actually has been 1 year since I bought it (Jan 30th 2022). The only thing holding me up from moving forward is the weather. My garage is insulated but when its 35 outside it makes it 55 inside, and thats too cold for me to paint. So waiting for better weather to help me along!
Old 02-03-2023, 04:01 PM   #187
Stickman
Stickman's Avatar
Did you drill and weld/fill all those tack welds around the perimeter of the firewall or fill and block the rest? Beautiful work.
Stickman is offline   Reply With Quote
Old 02-06-2023, 09:24 AM   #188
KyleSeal
KyleSeal's Avatar
I actually have not used any filler on the truck yet, just weld solid and grind flat with 36 grit discs/belts and then hit with 80 to clean the appearance. Areas welded that aren't exposed to everyone when assembled (cowl area and such) I will cover the welded area with seam sealer. Thanks!
Old 02-06-2023, 09:30 AM   #189
KyleSeal
KyleSeal's Avatar
Hurry up and wait is the game here in my garage! Waiting on temps this week to reach 60, so I can glue my roof. Meanwhile, I decided to get a 8 inch booster and flush mount it, like how Delmo did on Nacho. I needed to ditch the bolt on the steering column bracket, so I decided to section in a new side to it to relocate the bolt hole. Im sure one bolt would have been fine, but I felt better with two. Recessed the firewall brace with some 1/8 plate, welded it all and repainted to match. No one will ever see it, but I will always know if I hack something
Size:  57.5 KB Name:  IMG_4833.jpg
Size:  62.8 KB Name:  IMG_4836.jpg
Old 02-06-2023, 09:31 AM   #190
KyleSeal
KyleSeal's Avatar
Pix for others to use as reference if needed
Size:  71.2 KB Name:  IMG_4842.jpg
Size:  76.3 KB Name:  IMG_4841.jpg
Old 02-09-2023, 10:13 PM   #191
KyleSeal
KyleSeal's Avatar
And the roof is ON! Fully glued and welded. I did this single handedly, what I did was put 2x4s under the roof skin in place, so I could put down the glue on each surface, and drop into place. It worked out just how I hoped. Now to let it sit for a day or so and cure!
Size:  60.1 KB Name:  IMG_4888.jpg
Size:  61.7 KB Name:  IMG_4891.jpg
Old 02-09-2023, 10:33 PM   #192
chewychevy67
Awesome. Now you know rust won't be popping its head thru the windshield area in 20 months!
Old 02-09-2023, 11:03 PM   #193
SRU1436
Very impressive, great job!
SRU1436 is offline   Reply With Quote
Old 02-10-2023, 07:57 AM   #194
hewittca
hewittca's Avatar
Nice work! This is going to be one hell of a clean truck when you're done and something you can be proud of.
I'm going back to your brake system mod. I really like the flush mount idea. Is that one of those power brake kits with the weird mounting bracket and pivot that sets the booster way off the firewall? If so, I'm wondering if you plan to incorporate the pivot somehow or if you are worried about excessive pedal travel if you do not include it. I have that booster/master combo with the bracket/pivot and it works well as designed, it just looks terrible sticking so far off the firewall. I'd like to maybe do this mod as well.
Old 02-10-2023, 09:13 AM   #195
clay68c10
clay68c10's Avatar
Nice work!
You can't have too many clamps.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-10-2023, 10:16 AM   #196
KyleSeal
KyleSeal's Avatar
Thats right! This roof stuff has been a headache, but in the end I'd say its worth it. Learned a lot, and can say at the least it was effective.
Thank you!
I got this setup off eBay, the 8inch dual diaphragm with a 1 1/8 disc/drum master, and it did come with the big bracket and bellcrank. I plan to do a direct mount of the pedal push rod, I am currently studying the design of the master/booster/push rod combo to understand what I need to do moving forward. What I understand is the factory manual brakes want 4:1 pedal ratio, and power brakes want 6:1, to my understanding I should be able to move the mounting point down 1" and accomplish something close to this, as long as it doesnt create a weird angle. I may end up modifying the pedal itself if thats the case.
Old 02-12-2023, 05:15 PM   #197
KyleSeal
KyleSeal's Avatar
and wrapping up my brake pedal pushrod situation. I decided to put the bellcrank under the dash by chopping up the bracket and welding it in place, this was all done to achieve a 4:1 pedal ratio. I cut a relief in the pedal assembly and bent some 1/8" plate to a smooth radius to reinforce where I removed, and welded in a 'leg' to support the bell crank pivot point. Brake spring clears after cutting the pivot shaft about 1/4", and I moved the pedal to bell crank push rod hole up .5" to make the ratio proper.
Size:  106.0 KB Name:  IMG_4961.jpg
Size:  86.3 KB Name:  IMG_4963.jpg
Old 02-12-2023, 05:18 PM   #198
KyleSeal
KyleSeal's Avatar
This is the diagram I used:
Name:  Screenshot 2023-02-12 161728.jpg
source (with addt'l info):
https://shop.wilwood.com/blogs/news/...o%20of%209%3A1.
Old 02-13-2023, 08:06 AM   #199
hewittca
hewittca's Avatar
That's some really fine engineering to get that mechanism to fit in such a compact and concealed location! I'm wondering how your measurements work out for this arrangement, because with flipping the pedal pushrod an master pushrod on the pivot shaft you are actually increasing the pedal ratio and thus increasing pedal travel to achieve the desired master cylinder travel. For example, in the Wilwood schematic if you flip the 2.67" and 4.00" your pedal ratio goes to about 9:1. Maybe I'm just not understanding the schematic/phots correctly. Have you had a chance to get a feel of the pedal yet?
Old 02-13-2023, 12:08 PM   #200
KyleSeal
KyleSeal's Avatar
Good catch! I had not considered that, but to my calculations, if that is the case, I can drop the pushrod position on the original pedal accordingly to drop the ratio. The numbers on the diagram are not mine, just a given example from Wilwood. But given the case, if the bellcrank ratio flipped is 0.66:1, and I drop the main pedal ratio to a 2.8:1 then I will achieve about 4.2:1. Which will still help with my operating angles, and give me a proper pedal. The truck isnt back together yet, so I wont know about pedal feel until Ive got it reassembled.
EDIT: I added a diagram of my unit, with my setup + measurements and how I calculated mine with my flipped assembly.
1967, custom, dropped, lowered
