04-05-2015, 05:12 PM | #2001 |
Re: What did you do to your truck today? Chapter II
Great day to put down my first coat of wax on Texas Touch after paint (been almost a year now).
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch" "An intellectual is a man who takes more words than necessary to tell more than he knows" |
04-05-2015, 05:39 PM | #2002 | |
There is no better upgrade that can be done especially for under 20 bucks ! Peace
69 GMC 400/400 2.5/4 drop from ECE |
04-05-2015, 05:44 PM | #2003 |
Sweet GMC c10Tex
Looks absolutely gorgeous , great job Peace
04-05-2015, 06:12 PM | #2004 | |
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
04-05-2015, 07:37 PM | #2005 |
PROJECT 7DEUCE
Beautiful truck super
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-05-2015, 07:58 PM | #2006 | |
Headlight Relays
Headlight relays make the headlights *much* brighter , even the 40 year old original seal beams . They do this by increasing the amount of electrical power reaching the headlights ~ properly done you use slightly heavier gauge wiring between the battery and head lights , this also serves to take the load off that 40 year old low quality light switch . For those who like up graded headlights , this is mandatory to get the full out put if the newer lights . Don't forget to add a ground wire between the head lights and the battery's ground location be it the body , fender or frame .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
04-05-2015, 08:07 PM | #2007 | |
The relays bypass the power having to go thru all the wiring under dash and back to lights . I had a voltage reading on low beams at 10.8 and 8.9 on high beams at the lights now they have the full 12.8 at all times when headlights are on that is . I would say 25 % brighter lights on low 40% brighter on high http://67-72chevytrucks.com/vboard/s...d.php?t=293913 Peace
04-05-2015, 10:05 PM | #2008 | |
04-06-2015, 04:41 PM | #2009 |
Assembled the rear end and got one step closer to having a roller.
04-06-2015, 09:01 PM | #2010 |
When out and got gas today, still working the bugs out. It's better everytime I take it out, fix a rattle here, tighten a bolt there, small airbag leak...
Clean it up and out the the Steak and Shake tomorrow night.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
04-07-2015, 08:04 PM | #2011 |
Success!!!! Not exactly a today only project. I replaced the brake system on my truck during the winter months. Today I took it off the jack stands and down the road for the first time since October.
I installed a power brake booster, replaced all brake lines, and replaced rear pads and hardware as well as having the drums turned. I was pretty happy seeing I have never worked on drum brakes or replaced lines before. I spent a lot of time watching Youtube tutorials. I learned a lot and have the satisfaction of accomplishment. I am so pleased I just had to post. |
04-07-2015, 08:21 PM | #2012 |
Took the passenger interior door panel off my 68 C20 so I could rig the driver's side door handle. Cleaned some grounds so I can get her cranked this weekend
04-07-2015, 09:56 PM | #2013 | |
Figure out what you want--then figure out what you are willing to give up to get it. |
04-07-2015, 10:21 PM | #2014 | |
04-07-2015, 11:29 PM | #2015 |
Looks great SuperC10Tex. Me I won't use wax anymore. Not since it made my 72 yellow Chevelle look so badly. I've been using this since 1996, and couldn't be happier. They have great polishes as well. I used the mild to take off the wax.
http://www.detailsupplyoutlet.com/item.htm?item_num=115
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
04-07-2015, 11:50 PM | #2016 | |
04-08-2015, 06:08 PM | #2017 |
Bought a full set of new tires today. Nothing fancy, just some M+S's. Now to get them on the truck. Maybe tomorrow.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
04-08-2015, 06:27 PM | #2018 |
Did everything I could without U-bolts to get ready to install the rear end back where it belongs. The U-bolts should be here tomorrow and I can wrap that part up. I mounted the Wilwood brackets and just set the disks and calipers on just to see how its gonna fall together. Man what a nice disk brake setup. That drum style E-brake is really nice. None of those big ugly springs hanging off the calipers... just nice, clean and modern design.
04-08-2015, 06:52 PM | #2019 |
Keepin an eye out
I moved mine from the driveway to the street...Big day/
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
04-08-2015, 07:51 PM | #2020 |
I spent the better part of Sunday pulling the pan on the TH350 to stop the leaking. I was pleased to have found very little crap in the pan. So, I changed the filter/gasket, cleaned and painted the pan and bolts, new modulator and topped it off with fluid. (Fluid just dripped out of the modulator too, yikes!).
Cranked it up and it was leaking worse than ever, looked like the pan again, but it was dry. Upon further inspection, I found the secondary accumulator cover leaking. I removed the clip and cover, and found the spring broken in 3 pcs and had damaged the cover. I was lucky and had another tranny to get the parts I needed, woo-hoo!. Got it all back together Monday afternoon and took it for a ride. NO LEAKS, its like a miracle. Shift like new, crisp into 2nd was something new fo this truck...replacing that broken spring helps here and smoothly but firmly into 3rd. The bad modulator was allowing the fluid to be sucked into the intake an burned, and of course, it was always "hunting" or "floating" into 3rd. Spent time cleaning the spent trans fluid off the undercarriage and exhaust. Time well spent! Tom
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors |
04-08-2015, 08:36 PM | #2021 | |
RAT1968 '68 Cab/'71 Parts
Are the brakes drum and the disk for the e-brake only? Beautiful...And I know it's me...being a simple disk front/drum rear guy....Butt, What The %&*(^^?
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
04-08-2015, 08:39 PM | #2022 |
Its like a newer disk setup where the rotor is also the drum for the E-brake.. the drum part is only for the E-brake, it works by cable... the disk part is what you stop with. Nice 4 piston calipers too
04-09-2015, 06:00 PM | #2023 |
Baby's got new shoes! More like work boots.
04-11-2015, 04:18 PM | #2024 |
No, it has disc up front and drums in the rear. I bought the booster from Classic Parts. It bolted in pretty easily. The biggest challenge was connecting the linkage to the brake pedal under the dash.
04-11-2015, 09:07 PM | #2025 |
