02-02-2022, 09:26 AM | #2076 | |
Re: My 50 roadster pickup build
My example I use is my toaster it is a good Tfal I have had for 25 years gets used multiple times a day and works perfect. If I was to go get a new good expensive toaster I don't think it will last this long. Sorry for the rant.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
02-02-2022, 11:00 AM | #2077 | |
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-21-2022, 06:00 PM | #2078 |
Well time for an update, and still having issues. After weather final cleared up, Brendan came over and hooked up laptop and off we went. Only a few miles down the road, he said turn around and go home.
The computor speed was jumping from 60 to 50, 60 to 40, all over the place. There was nothing he could do until this was corrected. We talked about the speed sensor, and he told me to purchase an AC Delco speed sensor and check it again. He helped me with my OBDII diagnostic scanner, thru bluetooth to my phone, so I had a gauge and graph to show what the computor was seeing. This thing can do so much more, will have to play with it later. Installed new speed sensor, took it for a drive, the same problem. After talking with Brendan we checked the alignment of the reluctor wheel on transmission shaft and the speed sensor. This is where we found the problem. The reman. transmission I bought wasn't done very good. We could see 4 or 5 teeth badly broken, this was causing the fluctuation in the readings. Today Mark and I removed the tail section from transmission and could see how bad the reluctor wheel is, so Mark heated the gear and removed from the shaft. I have another one ordered, but it woun't be here till Friday. I'll post up some picture, in a minute...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 02-21-2022 at 06:13 PM. |
02-21-2022, 06:19 PM | #2079 |
Wow. That wasn't easy to find. Hope when you get the new one everything works great.
Keep the faith. The LS in my Cherokee has been great!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
02-21-2022, 06:30 PM | #2080 |
Pic 1 Transmission tail section, hole in side for speed sensor.
Pic 2 The three speed sensors. Top one would not let trans. shift out of 1st gear. Middle one took care of shifting, but thought maybe it wasn't correct. Bottom is the AC Delco. Turns out the middle and bottom were not the problem Pic 3 I couldn't focus good enought on the reluctor wheel, but at the top you can see part of the tooth missing, along with 4 others. Also more damage on the other teeth. Pic 4 The arrow head shows where the reluctor wheel (or gear) was installed on the shaft. Will get new one and install...Jim
02-21-2022, 08:30 PM | #2081 |
Thanks Robert, Mark and I both did a lot of checking on the internet,etc. Brendan was a big help...Jim
02-21-2022, 08:36 PM | #2082 |
Jim, once it's all sorted, the nonsense will be nothing but a laughing point.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
02-22-2022, 12:14 AM | #2083 |
Outlaw, I agree. Like everything about the change. Just need to get this all sorted...Jim
02-22-2022, 09:19 AM | #2084 |
You'll get past these minor set backs Jim....
Your gaining. Keep at it. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-22-2022, 10:23 AM | #2085 |
good catch and at least the trans didn't have to come out. access actually looks pretty good from the pics. now, to find some decent parts.......
02-22-2022, 11:27 AM | #2086 | |
Thanks, new wheel is AC Delco, so I shold be OK...Jim
02-23-2022, 11:04 AM | #2087 |
Hang in there Jim. You will get all the bugs sorted out and will be having a great time soon!
02-23-2022, 11:38 AM | #2088 |
Thanks Ray, I'm sure we will...Jim
02-23-2022, 11:49 AM | #2089 |
that is so frustrating, but I am sure it will get sorted out.
look forward to reading that you are driving the wheels off it.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
02-23-2022, 03:49 PM | #2090 |
Thanks Tempest, yes as soon as it's tuned, I'll be driving it and putting miles on the new toy...Jim
02-27-2022, 09:12 PM | #2091 |
Little update. Received new reluctor wheel late Friday in the mail. Mark installed the new wheel on shaft and put everything back together on Saturday.
We hooked up my OBD11 scanner and checked the speed, was showing nice and smooth, no up and down like a hearbeat. Will have to wait a day or two before I can drive it. We had about 4" of sleet between Wed. and Thurs. so the drive is not good. Pic 1 is the gauge on my phone, where we checked the speed. Pic 2 and 3 is the driveway. Later...Jim
02-28-2022, 09:17 AM | #2092 |
Good....your gaining.
Marc
02-28-2022, 10:42 AM | #2093 |
love that red truck color. what year is that?
02-28-2022, 11:15 AM | #2094 |
Thanks...Jim
It's a 2020 Chevy Silverado that Mark drives...Jim
03-02-2022, 05:30 PM | #2095 |
Quick update, drive way all dry, so I took about a 30 mile drive today to check things out. What a difference, the new reluctor wheel made the computor happy. It stays at a steady 60 mph when I can hold the throttle correct. Trans is not shifting in and out of lock up torque converter. Cruise holds a steady 70 mph when on the 4 lane. Super happy with it. Still need to have Brendan hook up his lap-top, but good for now.
Heres a couple pics. Showing driving down the road. Second pic is of my phone hooked up to OBDII showing what the computor sees. Not clear, but rpm is 1254 at 59.7 mph. Later Jim
03-02-2022, 05:34 PM | #2096 |
Very nice!
03-02-2022, 05:42 PM | #2097 |
Just lumbering along! You might need a gear change, LS's don't lug very well. Their happy place is in the higher revs.
03-02-2022, 06:05 PM | #2098 |
He is right about that! 3:55 to a 3:73 would put you right into the middle with that sweet spot. Also I had to put a B&M lockup controller in my S10 and it is adjustable so you can fine tune it. But that is all stuff you will get sorted out and it will be a Blast to DRIVE
03-03-2022, 12:37 AM | #2099 | ||
03-03-2022, 03:06 AM | #2100 |
Looks like you will be out terrorizing the neighbor hood very soon. Do they use salt on the road where you live? They use truck loads of it up here usually not washed off the road till mid April
