Old 09-09-2021, 08:46 PM   #2101
Gregski
Post Whore
Gregski's Avatar
Re: A '54 named Busty
so the doors had to come off in order to properly clean the gunk out from the previous weather strip behind the hinges area, I used a wire wheel and the section cleaned up really nice, then I sprits it with some no primer needed black spray paint, I'm not one of those guys who paints and a minute later bolts the part back on the vehicle, I like to give it at least 24 hours to dry, so we will glue on the new weather strip tomorrow
Gregski is offline   Reply With Quote
Old 09-09-2021, 09:05 PM   #2102
Gregski
Post Whore
Gregski's Avatar
now is a good time as any to mention the rubber weather strip metal retainer strip that screws on to the bottom of each door, or more importantly the broken screws that used to hold one on there
with the old weather strip off, now is the opportune time to extract those broken screws, its a PIA but they do protrude about 1/2" on the inside so taking your time you can unscrew them inward with some vice grips
Fun Fact: on my passenger side door I was able to unscrew all the screws but one, only one broke off, on the driver side it was quite the opposite, only one came out properly, and the rest of them broke off
Old 09-10-2021, 09:15 AM   #2103
6DoF
6DoF's Avatar
keep crankin sir!
6DoF is offline   Reply With Quote
Old 09-10-2021, 09:55 AM   #2104
Gregski
Post Whore
Gregski's Avatar
Originally Posted by 6DoF View Post
keep crankin sir!
LOL, thanks, it's been very up and down lately! but we've made some progress on the passenger side door
this is how the window zone looked like before I cleaned it up
Old 09-10-2021, 09:23 PM   #2105
Gregski
Post Whore
Gregski's Avatar
and here it is after the dance of the wire wheel
I hope that white paste gunk wasn't serving a purpose, ha ha
Old 09-10-2021, 09:25 PM   #2106
Gregski
Post Whore
Gregski's Avatar
then it was BTT (Blue Tape Time)
Old 09-10-2021, 09:29 PM   #2107
Gregski
Post Whore
Gregski's Avatar
obviously it's easier and messier to do two things at once, so rather than just painting I decided to also apply the weather strip at the same time, so more BTT to guard against black concrete cement overspread
CAUTION FROM THE FUTURE ME: this proved to be an Epic Failure and a waste of money. I could not get the doors to shut with this weather strip on no matter what I did. I even tried only running it above the windows and still had to push on the doors with both hands while standing outside the vehicle to finally get them to latch, not the way you wanna haul your girls around.
Old 09-10-2021, 09:31 PM   #2108
Gregski
Post Whore
Gregski's Avatar
I relied on my trusty eyecrometer to set a perfect approximate perimeter all the way around except for here, here we didn't need no stinkin' blue tape
Old 09-10-2021, 09:37 PM   #2109
Gregski
Post Whore
Gregski's Avatar
OK, let's check back on that newly painted window cavity
me likes!
Old 09-10-2021, 09:40 PM   #2110
Gregski
Post Whore
Gregski's Avatar
here are the Three Easy Steps to apply the weather strip adhesive
Step 1. apply tube of adhesive to the two edges of the door until you run out
Step 2. run to the local auto parts house to get more adhesive
Step 3. finish applying the second tube of adhesive to the two sides of the rubber weather strip
Old 09-10-2021, 09:44 PM   #2111
Gregski
Post Whore
Gregski's Avatar
so lets take a look see at the finished product
Old 09-11-2021, 08:22 AM   #2112
8man
Nice job. Would it be cheaper to send my doors to you or fly you to my doors?
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 09-11-2021, 09:50 AM   #2113
Gregski
Post Whore
Gregski's Avatar
ha ha, I will risk it for some brisket
Old 09-11-2021, 05:29 PM   #2114
Gregski
Post Whore
Gregski's Avatar
so we picked up two tubes of the sticky black stuff today in preparation to do the other side
funny how 3M plays the we're a big company so we will do what ever the hell we like and uses two different part numbers for this stuff, I recon it has something to do with the size of the tube
Part #08581 being the Jr size
Part #08006 being the bigger size
and let's not forget Part #08011 the one Dr. J actually recommends we use but no local parts houses carry it, and Amazon can only ship it via steam locomotive and needs 2 moons time to do so
Old 09-11-2021, 07:35 PM   #2115
Gregski
Post Whore
Gregski's Avatar
so before we set out to remove the vent window on the driver side we decided to make life a little easier for ourselves and went out and procured these Ukrainian tip drivers
Old 09-11-2021, 07:38 PM   #2116
Gregski
Post Whore
Gregski's Avatar
and soon after we were reminded of Busty's twisted sense of humor
Old 09-11-2021, 07:39 PM   #2117
Gregski
Post Whore
Gregski's Avatar
so we put another $2 bill in the curse jar and got that triangle out anyway
Old 09-12-2021, 08:36 AM   #2118
8man
Now that's funny!
8man-aka Robert
Old 09-12-2021, 12:55 PM   #2119
Gregski
Post Whore
Gregski's Avatar
having wasted the last of our KRYLON Rust Tough 'Camel paint on the stupid bench seat frame while Restoring Rusty
first thing this morning we found ourselves on our way to Oh'Really parts house to snag the last can of this "SEMI FLAT" paint
- these overpasses aint gonna tag themselves !!!
Old 09-12-2021, 09:19 PM   #2120
Gregski
Post Whore
Gregski's Avatar
and so we got the driver door cleaned, painted and prepped for weather stripping
Old 09-12-2021, 09:20 PM   #2121
Gregski
Post Whore
Gregski's Avatar
and for some odd reason I decided to document the bejesus out of the driver side vent window disassembly
Old 09-12-2021, 09:57 PM   #2122
Gregski
Post Whore
Gregski's Avatar
next we have to drill out that pivot rivet, lucky for me mine had a dimple which I could use as if I first used a punch on it to locate the center type of thing
it only takes about 57 drill bit sizes to step up to what you need
Old 09-12-2021, 10:01 PM   #2123
Gregski
Post Whore
Gregski's Avatar
and you just keep enlarging the whole until you feel like you can punch it out, I don't drill it to the edges so I don't enlarge the whole, you can use a file to file it down flush before using a punch to know it out
Old 09-12-2021, 10:03 PM   #2124
Gregski
Post Whore
Gregski's Avatar
the vent window pivot stud retainer spring, nut, and 23 washers were next
Old 09-12-2021, 10:12 PM   #2125
Gregski
Post Whore
Gregski's Avatar
and this is just the below the bracket ensemble
