#2126 | |||
Still Learning
Re: 1969 Short Wide
![]() Quote:
Thanks Mike Quote:
![]() Thanks. |
#2127 |
Re: 1969 Short Wide
Looks great Mike!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#2128 |
Still Learning
Re: 1969 Short Wide
#2129 |
Re: 1969 Short Wide
Awesome work Mike!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#2130 |
![]() Join Date: Mar 2011
Re: 1969 Short Wide
Mike,
Did you have any trouble evacuating and charging your a/c system? I've rented a vacuum pump and the gauges from the local Auto Zone, and plan on tackling this myself. Any tips or hints you can give to an a/c rookie? |
#2131 | |
Still Learning
Re: 1969 Short Wide
Thanks!
I didn't have any trouble evacuating or charging my system. I did however overcharge mine and it caused me a day or two of frustration. What I learned is that the Vintage Air system I have ( sure fit early model cable driven) only requires 1.8 lb. of Freon. I had installed two cans plus what I thought was about a 1/2 can. It made my compressor cycle frequently because I was over pressure on the high side. Check THIS out . I would start with 2 cans and go from there. I'm not an expert by any stretch but this is how I always do my evacuations. 1.) purge the system with dry Nitrogen (150-200PSI). If you don't have nitrogen, I suppose you could use filtered compressed air. but this will add moisture to your system. Moisture is no good for a/c system. But there is no need to dump gas in it if you have an obvious leak, so pressure check is kind of mandatory in my eyes. 2.) check all fittings for leaks and see that the gauge stays at pressure 3.) Gently drain the nitrogen out to 10 psi or so then connect vacuum pump. 4.) I like to evacuate mine at least 4 hour or longer if possible. Vintage air recommends like 45 minutes min. I borrow a manometer HERE from work that reads vacuum pressure down to .000 PSI. This isn't necessary but since I have access I use it. You can use your gauges to do the same thing it's just hard to tell if there is a small rise in pressure. If it doesn't hold vacuum it will more than likely leak. It might be small but over time the gas will leak out. 5.) charge with Freon. They recommend not flipping your cans or shaking them like we did in the old days with R-12. This can cause spike in compressor and damage it. Just be aware it will take a while longer to empty the can. 6.) enjoy cold air |
#2132 |
Re: 1969 Short Wide
its really coming together now
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust ![]() |
#2133 |
Re: 1969 Short Wide
Thanks for the writeup, Mike. I's eskeert a them big hosey thangs under that thar hood.
#2134 | |
Still Learning
Re: 1969 Short Wide
Thanks Dean. New pics soon
You have a great way with words Chip ![]() |
#2135 |
Still Learning
Re: 1969 Short Wide
Got the interior pretty much done, still need to finish some minor things but over all I'm pretty happy with it.
Got the radio installed in the console. (Thanks Crash_OK) for donating it to the project. ![]() ![]() Starting to actually look like a truck again: ![]() ![]() |
#2136 |
Re: 1969 Short Wide
Slick install on the tunes Mike! You're patience and attention to detail really show across the whole truck.
#2137 |
Re: 1969 Short Wide
Like the radio, that baby is looking slick Mike
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#2138 | |
Still Learning
Re: 1969 Short Wide
Thanks Jason, just trying to catch up with you. ![]() |
#2139 |
Re: 1969 Short Wide
Looking pretty good Mike! Keep it up, you're getting so close.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#2140 |
Still Learning
Re: 1969 Short Wide
Thanks Duane, hope to drive this puppy soon.
#2141 |
Re: 1969 Short Wide
Looks great, won't be long!!!
My 1970 C10 Build "Project Teacher" |
#2142 |
Re: 1969 Short Wide
Lookin Good! Time to get that bed out of your avatar and onto the truck.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#2143 |
Still Learning
Re: 1969 Short Wide
Thanks Gary
Thanks. I hear you. I'm ready to get this thing assembled. |
#2144 |
![]() Join Date: Dec 2006
Re: 1969 Short Wide
Truck looks great Mike, nice job on the interior and radio install too. You will be driving in no time
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#2145 | |
![]() Join Date: May 2013
Re: 1969 Short Wide
Truck looks great Mike.
Tom 71 K2500 71 K5 Jimmy |
#2146 |
![]() Join Date: May 2012
Re: 1969 Short Wide
My favorite build. Looks incredible. What is left on the hit list before it's on the road?
#2147 | |
Re: 1969 Short Wide
#2148 |
Re: 1969 Short Wide
Wow, lookin good!
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068 |
#2149 |
motor exploder
Re: 1969 Short Wide
Everything looks so awesome! The red paint, the trim, all the details, and the grill look great. Top notch in every way, you're gonna have one bada$$ 'daily driver'!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#2150 | ||
Still Learning
Re: 1969 Short Wide
Thanks Tom Quote:
![]() ![]() Thanks Tex. Thanks Adam. I appreciate the compliments.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 07-22-2014 at 08:10 AM. |
