#2151 |
Re: What did you do to your truck today!
Hung my rods and pistons last night. Oh how I hate spiral locks. They can be frustrating when your out of practice...
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
#2152 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I finally started mine after sitting for 3 months..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#2153 |
This last Saturday I got the engine installed in the frame.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
#2154 |
Last night I Wire wheeled, primed and painted the battery box.
#2155 |
Today I called to schedule when I can go look at a new project, does that count?
#2156 |
Yesterday I picked up 2 new fenders and 2 floor patch panels. Today I ordered another gaggle of parts from the truckandcarshop. getting close to dropping her at the paint shop.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#2157 |
I modified my Cross Sill so I was able to run my Filler tube up to the bed from my Fuel Cell. also I started to strip the paint from the inside and outside of the bed.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#2158 |
![]() Join Date: Mar 2011
not much other than cut out some alternator brackets on one of the lasers at work. will get pictures up tomorrow
LIFESTYLES OF THE POOR & UNKNOWN |
#2159 |
Last night, I kicked the damn thing. It really pisses me off some days.
#2160 |
Cruised her to class last night. Got her up to 75 with nothing falling off! Was nice to drive her, never even turned the radio on. Just listened to the sound of my exhaust leak......
#2161 |
I got my ball joints and front brakes job finished, got her back down on her wheels. Tomorrow I'll convert over to power brakes (if it don't rain, that is) and if I have time I'll start on the rear brakes.
After all that, I do need to re-visit the front end. I used the supplied upper shock mount on the driver's side, but then as I was looking around the bolt bin for something, I found a set of much heavier duty shock mounts. In time for the right side, but now I want to replace the left side.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#2162 |
body work on my bed
#2163 |
changed the oil finally
#2164 |
I got the first coat of primer blocked out. cleand up the mess and the chevelle from all the dust.
1972 GMC (PROJECT LONG OVERDUE) ![]() 1998 SWB 4WD |
#2165 |
![]() Join Date: Nov 2008
Finished wiring in the computer on my 71GMC and adjusted the throttle cable on my 72 K10 woodhauler. Rained/snowed almost all day...
71 GMC C15 swb 71 K5 Blazer 72 K10 Woodhauler 89 Suburban 13 Duramax |
#2166 |
Dropped in a MSD Street Fire HEI distributor!
![]() Now she won't upshift, runs great in first gear though! ![]() I think its a vacuum line. Didnt feel like crawling under the truck tonight.
1972 C10 Longbed 350/350 |
#2167 |
Worked on my driver side inner rocker and kick panel....
#2168 | |
Tom |
#2169 |
Pulled both fenders (inner and outer) and both doors. I'm in full strip down mode. I'll try to pull the radiator and radiator support tomorrow.
#2170 |
I got converted over to power brakes. Woulda gone better, but I had a few set backs. I didn't know there are specific brackets for specific boosters. I wanted to use a different one than the one I ended up using.
![]() So it ended up taking longer than I thought, so all I got done on the rears was the drums off. ![]() ![]() I didn't make it to the parts store before they closed anyways, so I don't have the new shoes or wheel cylinder rebuild kits I need. I suppose it'll be monday before I can get them.
#2171 |
Mounted my oil cooler and bent the hard lines from the cooler to the bulkhead fittings on the front crossmember. I know they are called "hard lines" but they should be called "Really, really difficult to make fit lines" or "Next time I'm using braided hose lines".
I also had to bend my panhard bar so it would clear the oil filler on my rearend housing...that was easier than the 1/2" hard lines. |
#2172 |
tcoop68
Sandblasted my a arms , rear end support brackets, tranny crossmember , and front suspension cross members , had time to spray all parts with epoxy primer sealer then painted both cross members the same color of the frame hot lick blue. I will paint remaining part corvette silver tomorrow , will be installing back on frame in the evenings after work. This is on my 68 S/W I am frame off building to pass on to my grandson. I will get photos on as I build.
Posted via Mobile Device |
#2173 |
#2174 |
Finally got my speedo dialed in. Took me 3 gears at 10 bucks a pop to find the right one. Even with the gear calculator on this sight. No worries tho. Was driving the other day and could hear metal hitting metal on the bumps. Got under there and found that when I lowered her the exhaust is now hitting one of the trailing arms. I guess the power steering will wait until the new exhaust is installed.
Happy Easter.
#2175 |
Finally drilled and tapped the block for the z bar. Put the motor back in. I have to make a list now for what's next.
