02-27-2016, 08:57 AM | #201 |
Re: FITech Experiences ?
does the electric fuel pump cause much of a drain on the electric system if you are still using a new but old style alternator with the external regulator?
02-27-2016, 11:38 AM | #202 |
Its not too bad. A quite a bit louder than an in tank efi depending on where you mount it. Mine is mounted to the inside of the frame rail and I have dual two chamber flowmasters. You can hear it at idle mostly because you know its there. I can hear it in a drive thru when I'm near a wall. I can't hear it driving down a road. It would probably be annoying without performance exhaust.
Made in America by Americans |
03-05-2016, 01:03 PM | #203 | |
But Found Her 25yrs Later!
I wonder if you could just set the Rev Limit to like 500 RPM. Send to ECU, and then unplug the Handheld Controller and take it with you.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-14-2016, 09:08 PM | #204 |
I guess someone wants to make a little money off some poor unsuspecting soul. :-(
http://denver.craigslist.org/ptd/5452209425.html
03-30-2016, 04:20 PM | #205 |
The truck sits for 4-5 weeks and one turn of the key and it starts right up. Nice!
03-31-2016, 01:00 AM | #206 |
What air cleaners are you guys using! My drop base doesn't fit. A 1" sure seal wasn't enough to clear and I tried a 2" and it's too tall for the hood to close. I have a 5" filter and really need at least a 4".
04-04-2016, 10:20 PM | #207 |
Pushed back another month. Wow. Is it really worth the wait? Power Tour leaves 6-11 and the new "arrival" date is 5-27. That's cutting it really close. No shakedown time really at all.
04-04-2016, 10:52 PM | #208 |
Guys,
We have had a bit of progress installing the FiTech on my 69 Camaro. Thought you might like to see some pics. My buddy Diceman, who was the mastermind on my 72 is also working on this one. We're basically waiting for our buddy Double E to spare some time to wire it correctly and cleanly. Oh, it has been pressure tested and no leaks. Enjoy.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
04-04-2016, 10:55 PM | #209 |
And a few more of the command center with hard lines.
04-06-2016, 09:14 PM | #210 |
Thanks for the update.
Very Clean!
04-06-2016, 10:04 PM | #211 |
I'm having cold start issues with mine still. Takes 2 tries to start. Been on the phone with them multiple times. If I turn the key on and off and let the fcc prime twice it works on the first crank. I've upped the cranking fuel a bunch (like 50 points so far). Anyone else have this issue? It seems fuel related. I don't have a big cam in my 489.
Posted via Mobile Device |
05-30-2016, 12:31 PM | #212 |
I just read through this thread and it is very interesting as I am about to put a 1997 Vortec 454 into my '63. I have the factory '97 port injected manifold, Howell wiring harness and computer. Right now, Im debating over scratching the factory FI in favor of the FITech setup just for ease of set up. With my factory set up, I still have to buy new injectors, regulator and swap to an 0411 computer so that I can get it tuned easier. Basically its a lot of money, work and time that I could probably save by going with the FITech 600 maybe.
My main question is would I lose / gain a noticeable amount of power by going TBI vs the factory port injected system? The engine is a '97 7.4 Vortec, stock lower end and heads. Straub roller cam set up for the factory FI. I have a Blazer tank with the in tank pump already in place so I think Im covered for the basic fuel system. Any info is greatly appreciated as always. Happy Memorial Day! Chris
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
05-30-2016, 12:47 PM | #213 | |
1991 K5 Blazer 4x4 "9 ball" 2019 Chevy Silverado Trail Boss 4x4 2018 Chevy Colorado 2 door ZR2 4x4 1988 23' Mako Marine 2005 Harley Davidson Road King |
05-30-2016, 10:57 PM | #214 |
I've had different issues on and off with this thing. I like you found if I just kept cranking it when cold it would start after 6-9 seconds. Shouldn't be like that one would think. I'm in process of replacing my tank and putting in an in tank pump and new lines. This fuel command center is not good for me. It gets hot and won't send enough fuel past 3000 rpm sometimes, doesn't like to start when warm sometimes, hoping this fixes it. I don't have a radical cam by any means.
05-31-2016, 11:17 AM | #215 | |
Never Ending Projects
Here is a great thread on this, http://www.chevelles.com/forums/89-e...te-fitech.html
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-31-2016, 11:21 AM | #216 |
They had me change that, it didn't help a whole lot.
05-31-2016, 11:47 AM | #217 |
Bummer. Starting to get worried about the FCC and I have two of them. Guess we'll how they work.
05-31-2016, 02:01 PM | #218 |
Thanks for sharing the thread. It looks like folks were able to get refunds. They were less than friendly about it with me so time to get a little meaner.
06-10-2016, 11:41 AM | #219 |
No luck getting a refund at this point, trying to talk to ownership. I got my in tank pump running and it resolved all the issues I was having before with the Fuel Command Center.
06-10-2016, 01:27 PM | #220 |
Here's an update. I let my car sit for about 3 weeks in the garage. Started up on the first try. Yes it was a cold.....a blistering 85degrees.
So far I'm pretty pleased with mine. I don't have many miles on it, for lack of time, but it seems to be working as advertised. I do know that it woke up my ZZ4.
09-09-2016, 04:09 PM | #221 | ||
I came up with another idea - tried it today. The lowest Fuel Cut Off RPM setting is 1400 rpms. I entered it and 'Sent To ECU', removed the handheld controller, and the engine won't Rev above 1400. If we could set it as low as 500 or lower, they couldn't even idle out of the parking lot.
09-09-2016, 09:48 PM | #222 |
I forgot to update, I was able to get a refund on my FCC finally, from the reseller, not Fitech.
09-12-2016, 12:08 AM | #223 |
I recently installed the FItech 1200 power adder unit on my truck to sort it out before putting it on my turbo motor. Right away I noticed the lack of "fuel smell" being in & around the truck. I went to the track & by the third pass the MPH was right where it was a few weeks before with the carb & the fuel mileage is notably improved.
My research told me to stay FAR away from the fuel command unit..."Fuel pump in a can". The idea seems great, but they sure are having trouble with them. Z10, I hope your's works out for you! You did a VERY nice job installing it...hate to see you need to punt, but many have done just that to end up with a reliable system. I went with the AEM 380 lph pump...hopefully it will work out ok. The only problem I've had with mine was the hand-held controller went wacko (screen kept "rolling" from like to line & wouldn't allow any changes) & wouldn't let the truck start since I had it plugged in when this happened (changed the TACH input to coil). Once the key was shut off, it saved the "bad" info & failed to start. I called FItech & explained what was happening & was told to loosen the 4 screws on the back...sure enough that "unpinched" the touch screen & all was good. They sent me a new hand-held controller just to be sure. It came in a few days & everything has been fine up to this point. Lorne I made a jumper harness to use the TPS output from the FItech to also command my transmission when to shift. This way, no cut/spliced wires |
09-12-2016, 12:29 AM | #224 |
Guys, I wish I had more to report. My 69 Camaro has not moved since my last report. Life has gotten in the way. As to the fuel commander, it's really a sweet looking piece. If you'll look at my build thread on my 72 GMC you'll see where my good friend Dice Man actually fabricated a similar system utilizing a couple of high pressure calibration gas cylinders. This system has worked great and now has 10k miles on it. If the fuel commander had been available at the time, we probably wouldn't have gone to all the trouble of fabricating what we call a surge tank.
If and only if the fuel commander craps out, I'm sure we'll just modify it and install a high pressure corvette fuel pump in it and make it work.
09-19-2016, 12:09 AM | #225 |
Can you go into more detail on this? They told me splicing wires would void warranty. Really want to ditch the separate tps.
