Old 01-25-2013, 04:54 PM   #201
williamsboys
williamsboys's Avatar
Re: 66 c10 first timer build
So just dry fitting my trans mount and I could of swore someone told me that it would line up with the holes on the frame. Bit of coarse the don't , no biggy I can drill holes. [IMG]http:/ [/IMG]
Williamsboy
williamsboys is offline   Reply With Quote
Old 01-25-2013, 05:47 PM   #202
williamsboys
Painted it to match the frame
[IMG]http:/ [/IMG]
Williamsboy
Old 02-02-2013, 06:22 PM   #203
Bomp
Bomp's Avatar
Been following along.
Like it.
Bomp is offline   Reply With Quote
Old 02-02-2013, 10:46 PM   #204
williamsboys
Like it.
O thanks! Been a journey just learning as I go.
Williamsboy
Old 02-03-2013, 09:51 PM   #205
williamsboys
Not really truck related, but motor related. On my.77 vette it's got an older one piece Holley. It's been rebuilt the motor has a rebuilt block lunati cam so I guess it's a mild built 350. So question is if I romp on it from dead stop it Boggs out and even has died before. But from a rolling start or just cruisen and I romp on it all is well.
Do yall think I just need a new carb? I think it's dumping way to much full in the carb, it gets like 4-8 mpg and just smells of fuel
Williamsboy
Old 02-05-2013, 09:59 PM   #206
williamsboys
Anybody
Williamsboy
Old 02-06-2013, 09:56 AM   #207
duallyjams
duallyjams's Avatar
4 mpg is a big problem 8 - 10 mpg is normal for hi pro but you say it's mild so it should be 11- 18 depending on how hard you drive it.
If you are smelling gas that could be dangerous if it's a gas leak. I would check everything to make sure there's no gas leak then yea I would look into replacing the carb.
I would pull some spark plugs to see how they look and look at the tail pipes also , the should be grey if it is tune correct.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-06-2013, 11:14 AM   #208
williamsboys
Yea. I just replaced.plugs. exhaust looks black inside but it don't smoke.
Williamsboy
Old 02-06-2013, 11:20 AM   #209
williamsboys
Here's the worst plug I pulled out compared to the new one.
[IMG]http:/ [/IMG]
Williamsboy
Old 02-06-2013, 11:23 AM   #210
williamsboys
Would it be the carb that's making it stumble from a dead stop to romping on it? I was told to maybe change the jets on it but I've just read a lot about the older one piece holleys and they say they went all the great. When and if I buy a new one should I upgrade to electric choke?
Williamsboy
Old 02-06-2013, 11:26 AM   #211
williamsboys
[IMG]http:/ [/IMG]
Williamsboy
Old 02-06-2013, 01:57 PM   #212
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
In regards to your carb, a lot of things can be adjusted/changed to remedy the initial stumble. I know that holley makes different cams to increase/reduce quantity of fuel and when it is sprayed into the carb, and that bolt with the spring on it can be adjusted to drive the accelerator pump later/earlier to help. Another item that can be changed is the power valve, as they make units that open at different vacuum levels and you may not have the correct one if your camshaft is too lumpy. Also, if your floats are set too high fuel can be dumping in at an idle......The list goes on, and on.
Good Luck!
Modges'66 is offline   Reply With Quote
Old 02-08-2013, 08:57 AM   #213
duallyjams
duallyjams's Avatar
Good Luck!
x2
the plugs were over due for a change
James
IG duallyjams
Old 02-08-2013, 03:01 PM   #214
williamsboys
Ok so really annoyed and need advice. I just bought an edelbrock 600 and for it all hooked up. It idles better don't smell like gas and cruises like a dream. But still the stumble if I romp on it from dead stop. I'm not out to drive this tho.g in the ground or anything I would just like it to perform when I want it to. So what else could it be?
Williamsboy
Old 02-09-2013, 11:09 AM   #215
williamsboys
So when we put the new carb on we also added a plastic inline fuel filter. And that little filter might have solved my problem. It's showing that it's not getting a consistent amount of fuel, the filter is not full and has a miss surge of fuel every few seconds. Most of the time at idle if u just watch that clear filter it never gets past half full and sometimes almost goes empty. My mechanic said its my fuel pump going bad and that's what causes the stumble if I floor it from a dead stop. It's not getting a consistent amount of fuel to it . It slurps it all out then stumbles while more gas is on its way.
Does all that sound right?
Williamsboy
Old 03-01-2013, 08:41 PM   #216
williamsboys
Got some new goodies! TCI trans pan and lokar filler tube. So Wats yalls input on me putting a 700r4 behind the 327 I got. It's suppose to be pushing 375 hp. Some people I talk to say do not go with that trans, and some say it's the best. Of coarse I already have it so I'm keeping it just want yalls input.[IMG]http:/ [/IMG]
Williamsboy
Old 03-02-2013, 08:05 PM   #217
williamsboys
What trans cooler is a good one to go with? Also what lines fit our trucks? Or should I just run braided steel lines? Thoughts would be great.
Williamsboy
Old 03-02-2013, 09:19 PM   #218
gimmy 64
the 700 should be fine. as far as trany lines go do you have a remote cooler or ran through radiator? if trans cooler you can use rubber but it must be for tranny fluid not gas or what ever. if ran to radiator should be hard lines
gimmy 64 is offline   Reply With Quote
Old 03-02-2013, 09:25 PM   #219
williamsboys
K. I'll be running a separate cooler for trans. Is there a good route to run houses from trans to cooler? Any pics out there?
Williamsboy
Old 03-10-2013, 09:14 AM   #220
williamsboys
Well I installed my trans and was going to bolt up my flywheel to the torque converter and realised the bolt holes didn't line up. I called the engine builder and he said he sent the wrong flywheel with that torque converter so he is going to send me the other one this week. Pretty annoying. My engine hasn't been primed yet, but is there an easy way to turn the flywheel to line the wholes up? I have all the spark plugs out to.decrease compression. I was told not to turn the single bolt on the front of the crank cause that May break off. Any thoughts?
[IMG]http:/ [/IMG]
Williamsboy
Old 03-11-2013, 08:16 PM   #221
williamsboys
Well we got the flywheel situation figured out. My engine builder told me to make sure the engine is on tdc when I'm done turning the crank to bolt up the flywheel. I've been reading up on how to determine if it's tdc and so far I found out u can just stick your finger in the #1 spark plug hole and feel for the piston to hit top. And that's tdc. Is that a way anyone has tried?
Williamsboy
Old 03-11-2013, 08:42 PM   #222
Ta2Don
Ta2Don's Avatar
I use a pencil in the spark plug hole, not the eraser end. Then pull the valve cover to ensure both valves are closed (for the compression stroke). At least that's how I was taught in the 70's... I've used the front bolt and have never broke one, especially with the plugs out.
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 03-11-2013, 09:03 PM   #223
williamsboys
Cool thanks ta2ton
Williamsboy
Old 03-11-2013, 09:04 PM   #224
williamsboys
Ta2don. My bad
Williamsboy
Old 03-11-2013, 09:15 PM   #225
rustbucket66
Ta2Don is right. Yoiu could also watch the harmonic balancer when you turn it over and get the timing mark to lined up zero with the tab over top the balancer (TDC). It will either be on #6 or #1. check that both valves on #1are not compressing the springs. If not, you are on #6, and need to give the crank another revolution to get to the timing mark again, and you will be on #1. You can install the distibutor now if you wanted. As far as the bolt breaking off, I have never heard of that. It is a 1/2 inch bolt, and I have done valve sets and such on high compression big blocks without any worry of breaking the bolt. Horse hocky. Just remember to take the socket and breaker bar off the bolt before you start the engine.
rustbucket66 is offline   Reply With Quote
