#201 |
![]() Join Date: Jul 2012
Re: 1953 Burb build
That looks really good Iceburgh. Did you wrap or paint the under dash ac ? Looks like carbon fiber.
#202 |
Re: 1953 Burb build
Hydro graphics
#203 |
![]() Join Date: Mar 2007
Re: 1953 Burb build
How does hydro dripping work? I know that the graphics are embedded in water but after is it is applied do you need to coat the piece with anything to preserve the graphics from rubbing off?
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#204 |
Prestige Worldwide
![]() Join Date: Feb 2001
Re: 1953 Burb build
It's really coming along, looking good!
#205 | |
Re: 1953 Burb build
You use a activator to adhere, then dip and clear. http://www.bing.com/videos/search?q=...E1DEA7E3008384 many patterns to choose from |
#206 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: 1953 Burb build
Burb is looking really good.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#207 | |
Re: 1953 Burb build
Marc
#208 |
Re: 1953 Burb build
#209 |
Re: 1953 Burb build
Outstanding!
Do you have a programmed PCM already? Access to HP Tuners? What does the engine do? |
#210 |
Re: 1953 Burb build
I've followed your build and love the results. Having swapped several LS based engines, my first question is how long has it run up to now? If only for a minute or two, crank it up and let it run. These engines have a "Crank Learn" mode, and the engine can run very rough at the start, but if everything is hooked up, it will smooth out in about 5 minutes if this is the problem. If this is not it, did you buy an aftermarket harness and PCM, if so, your supplier should have asked you for the engine displacement, injector size, what type of camshaft, etc, and then used this information to set up the tune. If this was done, the odds are that it is something besides the current tune.
If I were troubleshooting the engine, I would first pull the plugs to see if they are gas fouled. If not, then I would check the fuel pressure. If the pressure is good (over 55 PSI), then it is possible the injectors are plugged or restricted (a problem on almost every engine I've installed that had gas in the injectors before it sat for a while). I pull the injector rails (still hooked to the gas line), then pressure up the system, unplug the coil packs, then attempt to crank the engine. Watch the injectors, they should each fire a fine mist of gas as the engine spins. If not (say nothing or just a drip) that injector (or injectors) is restricted and will need to be cleaned. If the injectors are firing correctly, re install the fuel rail and check for spark (although you said the engine was running - just poorly - so spark should be OK). I use a tool NAPA sells that clips to the engine, plugs into the plug wire, and you can set the gap at the spec called for . Crank the engine again, you should get a good blue spark. If the spark is good, I would get on the phone to the person who sold me the PCM and wiring harness. Good luck, once the engine runs, you will never regret this choice of power plants! Ricky
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
#211 |
Re: 1953 Burb build
Thanks...it fires up and sounds great at idle. It is after pulling it in gear the problems start.
Feels like it is starting out in 2nd gear and bangs real hard when you first drop it in drive. I put one mile on it and didn't like the feel so I put it back in the garage. The PCM, Harness, motor and trans all came from the same guy in Denver. It is a 5.7 that is pre 2004. Much past that I cant say anything else about it. It as a hell of a cam in it by the sounds....more lope then I have in my 383. No doubt that it is all knew. All the sensors were new in the box. The engine was a complete rebuild as was the tranny. supposedly 485 hp |
#212 |
Re: 1953 Burb build
It looks great. You will get it figured out. It never starts and runs great the first try other than on those tv car building shows.
Marc
#213 |
Re: 1953 Burb build
Iceburgh,
No doubt you will fix it. I checked with my buddy that does a lot of swaps and here is his suggestion... He needs to check for dtc's, and see what vin is programmed into the pcm. I ran into this on travis firebird, it was programmed for a 6.0/4l80e should have been a 6.0/4l60e. It would start in 2nd(default) gear. Some tuners will start with an incorrect base tune and do segment swaps, such as a different transmission, to the tune. I read thru the build thread and it sounds like he is unsure of any of the programming. He should order an extra pcm with a "mail order tune", lots of companies doing this. I think bp-automotive does it. And then take it somewhere and have it dyno tuned. Some mail order companies will make the adjustments for cam,headers and such |
#214 |
Re: 1953 Burb build
Iceburgh, Looking Very nice and great progress.
1950 3100 5 window |
#215 |
Re: 1953 Burb build
Iceburgh WOW your Burb looks amazing body work, paint, interior sounds great as well. Hope you get the motor bug worked out. If mine turns out half as good I'll be happy.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#216 |
Re: 1953 Burb build
The motor bug is a broken rod....stay away from sand and street performance. They will steal your money. Me and a dozen other people are hoping the attorney general of Az. Will catch up to this guy.
#217 |
Re: 1953 Burb build
That thing is sick!
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
#218 | |
Re: 1953 Burb build
Are you going to rebuild it or find another engine?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#219 |
Re: 1953 Burb build
Incredible!!
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU |
#220 |
Re: 1953 Burb build
Sorry to hear that Iceburgh.
#221 |
Re: 1953 Burb build
That plain sucks. Sorry to see all of your hard work get derailed by a d-bag.
Keep your head up Marc
#222 |
Re: 1953 Burb build
Just one of those things. Karma is a ***** and they will get theirs at some point.
Got a 6.0 I am putting in after some cashing in a few stocks. Rebuilding the 5.7 to put in my yellow truck with a carb and 700r that I have had sitting around. That will be the winter product. FIL picked up a '56 bel air we will get started on as well. Maybe a month before the burb is on the road....little late but better late than never |
#223 |
Re: 1953 Burb build
Your this close to the finish line no sense to rush it now. I know its probably disheartening but you will forget about this the first miles down the road. Keep your head up.
Marc
#224 |
Re: 1953 Burb build
Good plans for recovery after a bummer of a deal. Hopefully you guys will do a build thread on the 56 BelAir? Plans for that one?
#225 |
![]() Join Date: Mar 2011
Re: 1953 Burb build
Your not letting it keep you down. Keep us posted on everything...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
