Old 02-25-2007, 06:42 PM   #201
msgross
msgross's Avatar
Re: Its the shortbed's turn "Project Junkyard Resurrection"
I bet your area must be missing some road signs! I have a clue as to where they are....
So your ebrake cables are shot?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-25-2007, 06:45 PM   #202
1969k10stepside
Those arent the real thing.I bought a whole bunch at a novelty store.The look real close to the real thing and could probably pass as some but they arent.
The cables are more then shot,they arent there period
1969k10stepside is offline   Reply With Quote
Old 02-25-2007, 07:50 PM   #203
msgross
msgross's Avatar
how are you doing your lines?
I called NAPA and he has a 25ft section for about $20-$25. I'm thinking of renting the bender and flare tool from autozone and going for it myself.
The Garage:
Old 02-25-2007, 07:58 PM   #204
1969k10stepside
I thought of buying a pre-bent Stainless steel kit but the price is a lil outrageous IMO.I am going to buy a big long section of line and bend them and flare them myself.I already have the tools,its not my first time doing it,I still hate it everytime I do it thoughIt will be fun running all them feet of line through the frame rails.I probably will buy and start running brake lines this week
Old 02-25-2007, 10:46 PM   #205
msgross
msgross's Avatar
I here ya, $185 for stainless before shipping and all. $155 for steel pre-bent.
The Garage:
Old 02-26-2007, 06:48 PM   #206
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Hey D, did you check on that through one of our Vendors? I got my SS lines
from Tim Christian, very happy with the product I got and reasonable to me.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-27-2007, 09:43 PM   #207
1969k10stepside
Motor time?...you bet
Worked on the motor tonight.I chose the best of several 350s to use.I chose a 2 bolt as it was in the best shape,I would gladly take up a offer on a 350 4 bolt though....
Anyway the heads are off,and I have already had some heads rebuilt for it.I have the complete top end off,have a new edelbrock intake,still need a carb though.I also removed everything needed to remove the crank.I might have the motor down to a bare block tomorrow.Oh the joy of motor work...
Old 02-27-2007, 09:48 PM   #208
2nd_wnd
2nd_wnd's Avatar
Motor work rocks, thats one of my favorite things to do.
I'm using a 2-bolt for my future motor too, except not using stock crank caps, going for the splayed caps, much stronger even better than a stock 4-bolt main
72 LWB
2nd_wnd is offline   Reply With Quote
Old 02-28-2007, 11:15 PM   #209
1969k10stepside
More motor work!!!!
I managed to get the crankshaft and all 8 pistons out of the block tonight.Now I only have to remove the cam and lifters and then I can send the block to the machine shop
Old 03-01-2007, 09:27 PM   #210
1969k10stepside
Little more motor work,I managed to get the lifters out(that was fun) and remove the cam.Now its just a bare block.I might get it taken to the local machine shop next week to be dipped and cleaned then bored over possibly.Im running out of stuff to do...lol
I guess till it gets back I will get the cab in the shop and do body work on it and get the new rockers,cab corners,and a little bit of floor put in.Plus I have to cut out the hole in the floor for the transmission hump as Im using a a/c cab off a 2wd that was a low hump floor.I didnt want to spend alot more money on fixing the original cab.Might work on the short fleet bed too unless I find a better one at the junkyard saturday.
Old 03-03-2007, 05:38 PM   #211
1969k10stepside
Motor is now in the machine shop.They will have it a few weeks.Its being bored .4 over,and they are polishing the crank.They suggested a RV cam,so thats what Im buying.Found a good deal on 35" Pro Comp tires so they are going to be mounted on the 16x10 rims next week
Old 03-03-2007, 06:30 PM   #212
msgross
msgross's Avatar
what are they charging at the machine shop? Mine wanted $75 just to clean the block up....
The Garage:
Old 03-03-2007, 06:35 PM   #213
1969k10stepside
$175 to have 8 cylinders bored,$50 to boil/clean the block.$25 to install the freeze plugs,thats what I remember.....
Old 03-03-2007, 06:41 PM   #214
msgross
msgross's Avatar
thanks, i'm gonna run my engine "as is" until I see the need to pull apart, that is unless I come into $500-$700 for a rebuild...
The Garage:
Old 03-03-2007, 07:14 PM   #215
1969k10stepside
I dont blame you,I have been collecting parts to build a motor for months and finally putting them to use.I know that my motor needed work so I decided to work on it now,rather than after the truck is painted.I really dont need much,just gaskets,bearings,rings,pistons,cam,and carb.I guess now I will be focusing on body work as the rest is done.I want to atleast get the firewall painted before the motor goes in.I have collected up some patch panels so body work shouldnt take long or cost much,till it comes time to paint..
Old 03-03-2007, 07:43 PM   #216
msgross
msgross's Avatar
whats the plans for paint? farming that one out or shooting yourself? (paint I mean!)
My engine could last years or days...smart thing would be to tear into it for some preventive maintenance...budget dictates for now...
The Garage:
Old 03-03-2007, 07:50 PM   #217
1969k10stepside
I am going to brush up on my skills,paint the firewall myself.If I like my painting I might paint the entire truck,if not the firewall is staying painted and I will hire my friend to paint the rest of the truck.He is a professional painter,but paints vehicles in his shop when he isnt painting them at work.His paint jobs which are usually around $6000,he will do for around 3k..
Old 03-03-2007, 08:00 PM   #218
msgross
msgross's Avatar
I'm going GM Dark Green (original) and have no emblems except the "4 wheel drive under my marker light...
The Garage:
Old 03-03-2007, 08:05 PM   #219
1969k10stepside
Thats what color mine was originally.I will be going to look at color choices and have some color photoshopped on the truck once the body is back on.
The emblems will only be "8 350" ,and Custom Deluxe/10
The "4 Wheel Drive" emblems were not put on after 70,I have some of them,they might go on or they might not.I dont know.I have also been deciding on clear,deluxe,or original style sidemarkers,and mid 70s van sidemarkers...so many choices
Old 03-03-2007, 08:11 PM   #220
msgross
msgross's Avatar
I was thinking of making mine a "deluxe" truck but decided to go original.... Might put deluxe pedals on
The Garage:
Old 03-03-2007, 10:20 PM   #221
1969k10stepside
Mine wasnt a original custom but the 2wd donor truck was so thats why it will have custom deluxe emblems
Old 03-04-2007, 12:27 PM   #222
68K20
Noobie McNoobster
68K20's Avatar
What do the 4 wheel drive emblems look like and where do they go, my 68 K20 has nothing like that, but I might be interesting in putting a set on.
The Stable:
1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes
1990 Chevy V2500 Suburban
2005 Kawi KLR650
1983 Honda Goldwing GL1100 Standard (Naked)
1995 Miata M
Fortes Fortuna adiuvat
68K20 is offline   Reply With Quote
Old 03-04-2007, 01:03 PM   #223
1969k10stepside
I bought fenders off a 69 k10 for my 71.They had the 4 wheel drive emblems.
Here is a pic:
Old 03-04-2007, 03:08 PM   #224
msgross
msgross's Avatar
yeppers, they go under the front marker lights on the fenders... you can barely see mine in my profile picture.
not cheap if you buy them repopped...40-50 bucks if I remember...
Dustin, if your not gonna use them I would like to see your two best and compare to mine, we might be able to strike a deal...
The Garage:
Old 03-04-2007, 03:17 PM   #225
1969k10stepside
The one in the pic is the best.The other has some grey primer on it.The primer could be removed and re painted....but they need some paint anyway.I will see if I can dig them out of the emblem box with all the emblems in it
