Old 01-15-2011, 07:22 AM   #201
Mike Bradbury
Mike Bradbury's Avatar
Re: Project Orange to Green
Wow those are awesome wheels, what is the back spacing on those?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 01-16-2011, 02:13 AM   #202
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Thanks! They are 4" back space.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 01-16-2011, 02:34 AM   #203
Mike Bradbury
I would have thought with that deep of a well the outer edge of the wheel would sit outside the fender. Did yo use a shorter axle?
Old 01-16-2011, 02:00 PM   #204
BACKYARD88
BACKYARD88's Avatar
I haven't done it yet but the rear end needs to be narrowed 14 inches.
-Mike Owen-
Old 01-16-2011, 04:49 PM   #205
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet man, I cant wait to see this thing with all the body on & LAID OUT !!!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-16-2011, 06:37 PM   #206
Painter D
Painter D's Avatar
Good luck trying to get those Coys to polish up better ,I had some that I tried everything to get them to look better but nothing would work. That's ultimately why I ended up selling them.
I don't know if this is true or not but somebody told me that they are polished "cast", not aluminum. Hopefully you'll have better luck with yours than I did with mine.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 01-30-2011, 11:35 PM   #207
garagemonster
Nice
garagemonster is offline   Reply With Quote
Old 01-31-2011, 10:09 PM   #208
BACKYARD88
BACKYARD88's Avatar
They are cast aluminum and not billet. I'll polish them up as best as they will get and probably end up replacing them with billet wheels when it's closer to complete. I don't want a 5000.00 set of wheels to be out of style by the time it's finished
-Mike Owen-
Old 03-29-2011, 11:01 AM   #209
BACKYARD88
BACKYARD88's Avatar
Small update. I got the rear shocks back on(hopefully for the last time) and some more bracing added. I also got the drive shaft cut to the right length, now I need to get some u-joints and finish the carrier bearing crossmember.
-Mike Owen-
Old 03-29-2011, 01:45 PM   #210
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
More more more
Sinister
Killer
Old 04-26-2011, 09:47 PM   #211
BACKYARD88
BACKYARD88's Avatar
Got the front crossmember cut and welded in, rack notches tacked in, carrier bearing Crossmember built and the holes drilled for the front upper shock mounts. Time to tear it back apart, add some plating, finish weld everything and prep for paint!
Edit: I see I took a couple pics upside down
-Mike Owen-
Old 04-26-2011, 10:13 PM   #212
gringoloco
A guy with a truck
gringoloco's Avatar
Moving right along... Ready to see it painted
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-26-2011, 10:37 PM   #213
BACKYARD88
BACKYARD88's Avatar
You and me both! I'll just be glad to get all of this welding finished. I've had enough
-Mike Owen-
Old 04-27-2011, 08:38 PM   #214
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Got any better pics of the rack?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-27-2011, 10:34 PM   #215
BACKYARD88
BACKYARD88's Avatar
This is the best I've got. It's just a power rack for a 93 Mustang I picked up from NAPA.
-Mike Owen-
Old 04-27-2011, 10:41 PM   #216
BACKYARD88
BACKYARD88's Avatar
I test fit the cab tonight. A little trim for the driveshaft and a little adjustment to the high hump to clear the trans and it'll be all good! It all comes apart tomorrow so I can get the frame buttoned up!
-Mike Owen-
Old 04-27-2011, 11:02 PM   #217
FRENCHBLUE72
PROJECT 7DEUCE
Truck is reallu comming along I really need to get me some hoops like you have on the rear..
MEMBER #6377
Project "7DEUCE"
Old 04-27-2011, 11:30 PM   #218
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress! looking good man.
mcbassin is offline   Reply With Quote
Old 04-28-2011, 12:04 PM   #219
67cheby
67cheby
67cheby's Avatar
Sweet
67cheby is offline   Reply With Quote
Old 04-28-2011, 10:52 PM   #220
BACKYARD88
BACKYARD88's Avatar
Thanks!
Got everything that unbolts off so I can start the finish welding and clean up this weekend.*
-Mike Owen-
Old 04-29-2011, 10:52 AM   #221
Mike Bradbury
I thought I remembered that you "Z'd" the front of your frame, I guess not.
How are you going to finish the frame? Powder coat, Por 15 ...?
Old 04-29-2011, 02:27 PM   #222
BACKYARD88
BACKYARD88's Avatar
I did the Z but didn't like the way the LS engine fit with it. I decided the Dropmember was a better choice since I plan to drive it so I sectioned in a set of stock frame rails and ditched the Z. I'm going to paint the frame with single stage gloss black. I feel like money spent on powdercoating would be wasted, no worries about the frame rusting out here and if it gets chipped it'll be easy to fix.
-Mike Owen-
Old 05-12-2011, 09:12 AM   #223
BACKYARD88
BACKYARD88's Avatar
Cut, grind, weld, repeat.*
-Mike Owen-
Old 05-12-2011, 09:14 AM   #224
gringoloco
A guy with a truck
gringoloco's Avatar
I do not envy you, but it will all be worth it
-Chris
Old 05-12-2011, 09:57 AM   #225
67cheby
67cheby
67cheby's Avatar
Nice
