07-09-2009, 05:14 PM | #201 |
Fire Truck
Re: No Regrets - The Rebuild post
Not a fan of chopped tops but I must say that looks SICK! Keep it up man!
-Nick '83 Chevrolet Silverado Stepside http://67-72chevytrucks.com/vboard/s...d.php?t=349394 |
07-09-2009, 11:05 PM | #202 |
It'd be alot cooler if you did
Hey Marc how it going? I had Jeff over at Michigan Exhaust do the pipes. He actually came through with the pipe itself for a pretty good price as well.
07-09-2009, 11:16 PM | #203 |
Very cool. What are you doing for a gas tank?
Evan B. |
07-09-2009, 11:29 PM | #204 | |
Not sure yet... I have a stainless fuel cell from before, but I would really like something a little more "stealthy." Unfortunately "stealthy" and "low cost" don't seem to jive. No matter what, it unfortunately has to be mounted in the bed... I'm out of safe places to mount it on the chassis. |
07-12-2009, 08:09 PM | #205 |
I spent most of the weekend (Friday and Saturday) at Pinks All Out, I saw a lot of really nice cars.
Anyway, Sunday I was able to get a little tinkering done. First I finished up the new and still needing improvement upper radiator support bracket. I got a little happy and drilled the mounting holes in it before I test fit the shroud and... well they need to be moved back about 3/16" of an inch so the bracket has enough overhang to let the shroud lay flat on the radiator. I also figured out that the aluminum radiator I had bought had a pretty nasty bend in it from shipping, but was able to straighten it out by strategically placing some blocks of wood on the shop floor and standing on the opposite corners of the radiator. Other than that, things look pretty groovy. I also got busy on making the brackets that hold the A/C condenser. I think they turned out pretty good, considering Hot Rod Air supplied some glorified plumbers tape to accomplish the same job. Last edited by smashingchuck; 12-07-2009 at 06:44 PM. |
07-12-2009, 11:37 PM | #206 |
nice work!!
looks good!!
CHEVY ONLY |
07-13-2009, 06:38 PM | #207 |
hey, how are you retaining the AC on your truck? your bagging it right? or am I wrong? just curious. I want to bag mine and Z the frame. but I WANT AC lol
Edit... looking back I see its bagged now... DOH!! anyways.. AC? Last edited by bigbadjohn84; 07-13-2009 at 06:40 PM. |
07-13-2009, 07:34 PM | #208 |
6.0 powered square
he's using a under the dash a/c unit
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-13-2009, 08:57 PM | #209 |
ah.. that bites.. i saw where one guy on here had his blower assembly relocated upward to allow room and retain ac.. I was hoping to find more pics of resources on how this is done.. the under dash ac is cool.. lol. but mine is a low buck project. granted Im gonna do some big things, just wanna do my best to make it stock feeling while layin out lol
07-13-2009, 09:41 PM | #210 |
Low & Fast!
Nice work man!
07-13-2009, 11:26 PM | #211 | |
07-18-2009, 07:11 PM | #212 |
---Saturday---
I got the electric fan mounts made and it seems to fit pretty nice. I used a Jeep Grand Cherokee fan from moparpart.com. I also got the catch can mounted and I'm starting to look at my inner fenders again... I never finished them completely and they still need some "massaging". After I get the inners mounted again I can start checking out where I'm going to put the A/C bulkhead and finally hang the Hot Rod Air "box" inside the cab. Last edited by smashingchuck; 09-25-2009 at 10:15 AM. |
07-18-2009, 09:23 PM | #213 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-18-2009, 10:28 PM | #214 |
400? not bad. I amy look into that for sure. I want mine to lay low. that would open up wheel choices for me as well your truck is coming along great man! can't wait to see the finished product
08-07-2009, 10:07 AM | #215 |
Phone's ringin Dude.
Any updates?
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
08-07-2009, 12:34 PM | #216 |
08-08-2009, 11:04 PM | #217 |
Hey Smashing I see you are working on the A/C I got mine almost done. Good luck on using the bulkhead fitting. I was going to try that but there just wasn't enough space. Also I was sorta in alittle bit of a time crunch. It get ice cold in there now though.
There are some pics of it in my thread. Your truck is looking pretty sweet. Keep it up!!
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold 93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs. 09 Yaris wife's daily. |
08-20-2009, 07:03 PM | #218 |
Truck looks great! Reminds me of mine, except better in every way possible. I'm scared to start stripping the my cab, fearful of what I might find with the chopped roof, and my doors are in hideous shape/aligned terribly. The gaps/lines are all over the place over basically the entire body. Seeing yours all lined up though definatly makes me want to get crackin on the bodywork with mine, cant wait to see the final product
'75/'81 Chevy C-10 project... Hitting the streets Spring '10.... Cardomain Page http://www.cardomain.com/ride/3371894 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=357953 |
08-20-2009, 07:27 PM | #219 |
Thanks Zman. I plan to get cracking on it again this fall. I had to take a break so I could do some much needed renovations on my house. I had to tear down a chimney that passes through three different roofs, replace a window, and make all the trim. The final outcome is to make it look like it was never there, so I have to reside it as well. My house is 100 years old, which means all dimensional lumber that we are used to now is too small, so I have to buy all oversized pieces and plane and rip it down to the desired size. It's only slightly time consuming. I'm half way there.
08-20-2009, 07:53 PM | #220 |
yeller
OK, pics of the house are in order now!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
08-20-2009, 09:48 PM | #221 |
maybe i missed it...what is the fan shroud out of?
CHEVY ONLY |
08-21-2009, 01:11 PM | #222 |
It's a stock replacement from LMC.
Don't have any of the work getting done, but here's a shot from this spring. |
08-21-2009, 01:34 PM | #223 |
whoa! thats beautiful!! no wonder the trucks slowed down...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
08-21-2009, 01:40 PM | #224 |
x2!!
08-22-2009, 10:55 AM | #225 |
Keepin it old school
That is a beautiful house..
