Old 07-29-2009, 12:57 AM   #201
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
ever changed the intake?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-29-2009, 01:08 AM   #202
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
yes I have, first remove the heater hose,radiator hose water neck remove a little antifreeze from the intake, carb, distributor, and remove the bolts and then the intake, and also the valve cover may need to come off
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-29-2009, 01:11 AM   #203
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
i can do all of that but im afraid of the distributor. dont wanna change the timing or mess somthing up with that
-00 Saturn 5spd
1/4:13:90
Old 07-29-2009, 01:17 AM   #204
texasfunk
texasfunk's Avatar
Re: my 80 build
just take off the distributor cap first, and mark where your rotor is pointing, and when u put it back in make sure its facing the same way
texasfunk is offline   Reply With Quote
Old 07-29-2009, 01:18 AM   #205
texasfunk
texasfunk's Avatar
Re: my 80 build
also mark the body of the distributor, the way its facing, i usually mark where the vaccum advance is pointing
Old 07-29-2009, 01:20 AM   #206
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
ok thanks i start the project as soon as i get my gaskets
how muych do u think a preformer rpm with help from stock?
-00 Saturn 5spd
1/4:13:90
Old 07-29-2009, 01:27 AM   #207
flamingbig10
6.0 powered square
Re: my 80 build
oops forgot about the timing issue, when I did it I took the intake off a junk motor and put it on my motor so the distributor wasn't a issue
Aaron
Old 08-03-2009, 03:07 AM   #208
texasfunk
texasfunk's Avatar
Re: my 80 build
Originally Posted by flamingbig10 View Post
love the tail lights, where did you get them? and also, how did you like the door panels? im thinking of replacing mine, and i kind of like these
Old 08-03-2009, 12:54 PM   #209
flamingbig10
6.0 powered square
Re: my 80 build
thanks, there from traders village in Dallas there half the price of lmc, I like the door panels
Aaron
Old 08-03-2009, 01:34 PM   #210
GMC Guy
GMC Guy's Avatar
Re: my 80 build
do you know who makes the door panels? i'd love a set as well
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 08-03-2009, 02:32 PM   #211
flamingbig10
6.0 powered square
Re: my 80 build
rod doors makes them (http://www.roddoors.com/pages/chevtrk-6787.html) and 73-87 Chevy Truck parts sells them http://store.73-87chevytrucks.com/me...tegory_Code=DP
Aaron
Old 08-04-2009, 09:46 PM   #212
vsoree
vsoree's Avatar
Re: my 80 build
I think Flamingbig10 is one of the most helpful people on the the board, thanks for the link for the heater.
Stay blessed not Stressed!
vsoree is offline   Reply With Quote
Old 08-09-2009, 02:40 PM   #213
flamingbig10
6.0 powered square
Re: my 80 build
thanks vsoree,I try my best
Aaron
Old 08-17-2009, 10:34 PM   #214
flamingbig10
6.0 powered square
Re: my 80 build
today I bought two new front tires for my truck rides and handles a lot better doesn't rattle me to death on the highway any more
Aaron
Old 08-17-2009, 11:05 PM   #215
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 08-18-2009, 09:16 AM   #216
JohnC
JohnC's Avatar
Re: my 80 build
Amazing how those little things make a big difference.
JohnC is offline   Reply With Quote
Old 08-26-2009, 12:19 AM   #217
flamingbig10
6.0 powered square
Re: my 80 build
I worked on the dash a little to get it ready to fiber glassed
Aaron
Old 08-26-2009, 09:49 AM   #218
justpball
justpball's Avatar
Re: my 80 build
nice bro, keep us posted on the dash...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 08-26-2009, 05:05 PM   #219
flamingbig10
6.0 powered square
Re: my 80 build
I finished cleaning up the dash and sprayed some self etching primmer on it and to close up the holes I'll be using air ducting tape
Aaron
Old 08-26-2009, 05:08 PM   #220
silvrbreez
silvrbreez's Avatar
Re: my 80 build
If possible, while you have the dahs off, could you snap of pic of where you used the air duct tape to seal off the water from getting in behind your cowl?
silvrbreez is offline   Reply With Quote
Old 08-26-2009, 05:11 PM   #221
flamingbig10
6.0 powered square
Re: my 80 build
on the cowl panel on the cab I closed up all the openings using the tape
Aaron
Old 09-09-2009, 10:07 PM   #222
flamingbig10
6.0 powered square
Re: my 80 build
Today I cut a panel for the inside fenders
Aaron
Old 09-10-2009, 12:53 PM   #223
JohnC
JohnC's Avatar
Re: my 80 build
Looks good.
Old 09-16-2009, 12:56 AM   #224
flamingbig10
6.0 powered square
Re: my 80 build
thanks John, I finished up the panels but I realized the hood springs need a fresh coat of rattle can
Aaron
Old 09-16-2009, 08:41 AM   #225
JohnC
JohnC's Avatar
Re: my 80 build
They really help clean up the engine bay. Good work.
