Old 05-16-2014, 10:22 PM   #201
nds1968
nds1968's Avatar
Re: Project Blue Goose
Originally Posted by jlaird View Post
A little late, but congrats on the kiddies. I have two myself. Be prepared for even less "truck time!" LOL.
Thanks Josh, Yeah the little ones are taking up most of my time. I also have house projects that take priority over "truck time" so it will continue to be a slow build
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 05-16-2014, 10:26 PM   #202
jlaird
jlaird's Avatar
Join the club! That's ok though, no matter how much these trucks mean to us, family comes first.
jlaird is offline   Reply With Quote
Old 05-16-2014, 10:28 PM   #203
nds1968
nds1968's Avatar
Our new addition to the family. Madelyn Renee, she is one month old today but here she is as a new born
Nate
Old 05-16-2014, 10:35 PM   #204
nds1968
nds1968's Avatar
Here is big brother. Carter Jeffrey, he is 18 months this week. Here goes a pic from Christmas
Nate
Old 06-08-2014, 10:42 PM   #205
nds1968
nds1968's Avatar
I mocked up the rotors and calipers.
Nate
Old 06-08-2014, 10:43 PM   #206
nds1968
nds1968's Avatar
Another pic
Nate
Old 06-08-2014, 10:45 PM   #207
nds1968
nds1968's Avatar
I started to install the sway bar.
Nate
Old 06-08-2014, 11:01 PM   #208
67chevy1series
67chevy1series's Avatar
Man good work it's coming out awesome! I'll always watch this build..
67chevy1series is offline   Reply With Quote
Old 06-09-2014, 12:30 PM   #209
nds1968
nds1968's Avatar
Thanks Rick.
The rearend and wheels should be ready on Thursday
Nate
Old 06-21-2014, 10:11 PM   #210
nds1968
nds1968's Avatar
Picked up my wheels from getting PC.
Nate
Old 06-21-2014, 10:12 PM   #211
nds1968
nds1968's Avatar
I bolted the backing plates on.
Nate
Old 06-21-2014, 10:16 PM   #212
nds1968
nds1968's Avatar
I can't get the sway bar to align with the short frame brackets. I guess I'll have to try it with factory brackets.
Nate
Old 06-21-2014, 10:34 PM   #213
nds1968
nds1968's Avatar
Sway bar attached to the control arm.
Nate
Old 06-21-2014, 10:59 PM   #214
nds1968
nds1968's Avatar
I just checked the install directions on the Ridetech site and they say to remove the bracket and drill new holes. So they eliminate the bracket all together. I'll have to mock it up and see if that's possible.
Nate
Old 06-22-2014, 02:15 AM   #215
67chevy1series
Going well as always! Glad to see more progress
Old 07-10-2014, 11:13 PM   #216
nds1968
nds1968's Avatar
Not much work done but here goes some pics of the cab sitting in my uncles garage also the hood and buddy buckets.
Nate
Old 07-11-2014, 09:29 AM   #217
Bennett68C10
Bennett68C10's Avatar
This is how my Porterbuilt Sway Bar is mounted. I bent the gold bracket to match the frame where it mounts and then I used some grade 8 washers as spacers to space it off the frame a little. Hope this made sense but it worked good.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-11-2014, 06:43 PM   #218
nds1968
nds1968's Avatar
I haven't had the chance to mess with it any further. But with using washers as spacers is the rubber isolator tight against your frame?
Nate
Old 07-12-2014, 01:52 PM   #219
Bennett68C10
I forgot until I looked at it but mine has a plate that mounts between the isolator and the frame. I had to bend the plate to match the angle of the frame and then used 2 3/8" grade 8 washers between the plate and the mounting bracket for the rubber isolator so that it would mount correctly without any bind to it. The isolator mounts tight against the plate.
Keith
66 Suburban
IG: bennett68c10
Old 07-12-2014, 06:48 PM   #220
nds1968
nds1968's Avatar
Thanks Keith for posting the pic.
Nate
Old 07-13-2014, 05:50 PM   #221
Bennett68C10
No problem Nate, hope it helps with yours
Keith
66 Suburban
IG: bennett68c10
Old 07-27-2014, 01:08 PM   #222
nds1968
nds1968's Avatar
Picked up some 1-1/2" x 2-1/2" blocks to make lowering blocks.
Still need to drill the holes for the sway bar mounts.
Detail pic
Nate
Old 07-27-2014, 02:27 PM   #223
nds1968
nds1968's Avatar
Drilled the holes for the sway bar mounts and bolted it up.
It looks close at interfering with the linkage but I'll have to wait and check it out once there is weight on the front end.
Nate
Old 08-01-2014, 10:30 PM   #224
67ctener
67ctener's Avatar
This truck is gonna be bad ass. The route your going is awesome. Love the chrome caps on that white powdercoat.
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 08-03-2014, 05:04 PM   #225
nds1968
nds1968's Avatar
Thanks Scott, I have everything figured out on how I want the truck except what transmission to run. The original SM420 or........?
Nate
