Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-24-2012, 11:31 PM   #201
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
Sent you a PM.......
Originally Posted by LostMy65 View Post
I need to purchase another power steering bracket. This one is going on my 65.
Old 05-16-2012, 04:05 PM   #202
stevenbren
Question Re: Power Steering Adapter Plates
I have a 68 K-10. i want PS! Can you provide a list of everything I need to make this happen. Will buy your plate and rag coupler if needed. Want to keep old steering colum.
stevenbren is offline   Reply With Quote
Old 05-16-2012, 11:14 PM   #203
Captainfab
60-66 Nut
1) You will need a '68-'87 K series, or '88-'91 V series steering box and the pitman arm.
2) You will need the correct draglink for the front axle you are running.
3) You will need a power steering pump, brackets and pulleys for the engine you are running.
4) You will need the appropriate belt to drive the pump, and also the pressure and return lines from the pump to the box.
5) You may need a new rag joint, depending on whether you get a good one with the box or not.
6) There is bound to be some miscellaneous nuts, bolts, washers, clamps, fittings, etc. that you may need.
7) You will need an adapter plate to mount the box to the frame. The tube and flange will simplify the connection to your original steering column shaft.
Old 05-17-2012, 12:53 PM   #204
stevenbren
Talking Re: Power Steering Adapter Plates
I thank you sir! Does your plate work with the suggested boxes and could you clarify #7 about the the tube and flange?
Old 05-17-2012, 11:02 PM   #205
Captainfab
60-66 Nut
Yes my power steering box adapter plate works with that year range of steering box....that is what it is designed to work with. The tube and flange allows you to connect your original steering column shaft to the power steering bos without having to weld. I'mnot sure on the '67-'68 4wd's. but if it is the same as the 2wd's your steering column shaft is already the correct length. So you may not need the tube and flange. This steering box adapter and the tube and flange was designed specifically for the '63-'66 trucks, so your situation will be a little different.
Old 06-01-2012, 12:58 AM   #206
mexlokote
mexlokote's Avatar
newbie here! i want everything i need to do the conversion? i got a 1963 chevy c10 stepside? what do i need and got any pics of the process, sorry im new to this
mexlokote is offline   Reply With Quote
Old 06-01-2012, 02:21 AM   #207
Captainfab
60-66 Nut
Post #203 above lists everything you will need. I don't have pics handy at the moment, but those are a part of the installation instructions.
Old 06-07-2012, 09:18 AM   #208
junior43
junior43's Avatar
I have a 67 K10 that I would like to install power steering on. Could you pm me the info I need to order your plate? Thanks, Jeff
junior43 is offline   Reply With Quote
Old 06-07-2012, 10:48 PM   #209
Captainfab
60-66 Nut
I replied to your PM Jeff.
Old 06-11-2012, 12:59 AM   #210
C_delgado01
Hi, I'm new here.
I would like to order one of your adapter plates for my 1965 Chevy C20.
Thanks!
C_delgado01 is offline   Reply With Quote
Old 06-11-2012, 01:43 AM   #211
Captainfab
60-66 Nut
I'll send you a PM with payment details.
Originally Posted by C_delgado01 View Post
Hi, I'm new here.
Thanks!
Old 07-01-2012, 09:57 AM   #212
Street Sweeper
Street Sweeper's Avatar
Would like to know everything you have currently available for purchase for a power steering conversion. Please let me know parts, pricing, and payment requirements. Thanks for the help.
Street Sweeper is offline   Reply With Quote
Old 07-01-2012, 11:19 PM   #213
Captainfab
60-66 Nut
Did you receive my reply to your PM a couple weeks ago about this?
What I have to offer is shown in this thread. The power steering box adapter plate and the tube and flange. I do not sell complete conversion kits. I see no sense in paying shipping on those heavy parts, such as the steeing box, that you can easily purchase locally either used or new.
The pricing is still the same as in post #1 & #137. If you purchase both the plate and the tube and flange, the shipping is still $10.00. For payments I accept PayPal and money orders. Let me know if this will work for you and I can get these parts on their way.
Old 07-02-2012, 09:17 AM   #214
Street Sweeper
Thanks for the info - just wanted to make sure there weren't any new parts that were offered that I didn't know about.
I didn't receive a PM - that's why I waited a while - then posted here. Sorry for the redundancy.
I appreciate the help - will be ordering soon.
Old 07-03-2012, 02:18 AM   #215
RockTonka
RockTonka's Avatar
Need to get one of your ps box adapter plates for our 66 burb, please forward paypal info when ya get a chance.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 07-03-2012, 03:53 PM   #216
Captainfab
60-66 Nut
Thanks for the purchase
Old 07-03-2012, 04:15 PM   #217
RockTonka
RockTonka's Avatar
John,
Thank you!
I could have easily fabbed up one of these plates, but your plate is a clean, well-designed, set-up that will definately save me time we don't have.
Additionally, as we researched how to drop a BBC into our burb, I constantly came across tips, ideas, and shortcuts from you on every aspect of this conversion.
THANKS for all the help you give this community!
My build thread
Old 07-05-2012, 03:16 PM   #218
rockdogg2020
Any progress on the 60-62 bracket?
rockdogg2020 is offline   Reply With Quote
Old 07-06-2012, 12:00 AM   #219
Captainfab
60-66 Nut
Sorry but no. Just no time with working 75-80 hrs a week right now. Hopefully in a couple months.
Old 07-14-2012, 10:31 PM   #220
b2948kevin
b2948kevin's Avatar
I couldn't agree more. I really appreciate the help, and the brake booster bracket that I bought from you is top notch quality!
PM inbound for a Power Steering bracket and tube and flange.
66 Chevy C10 Stepside LWB My Build Thread
75 Harley FLH
84 Mercedes 300TD Diesel Wagon
b2948kevin is offline   Reply With Quote
Old 07-14-2012, 11:01 PM   #221
Captainfab
60-66 Nut
Thanks for the compliments guys
I replied to your PM Kevin
Old 07-21-2012, 08:55 AM   #222
Street Sweeper
Ordered my parts - received them within a couple of days. Great quality and great service. Thanks for all the help.
Old 07-21-2012, 11:03 PM   #223
Captainfab
60-66 Nut
Old 07-27-2012, 04:37 AM   #224
MikeS.
MikeS.'s Avatar
Cap'n great job on the plates, thanks.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 08-08-2012, 10:40 PM   #225
GMC66
GMC66's Avatar
Captainfab, you have a PM. Thanks.
GMC66 is offline   Reply With Quote
