08-13-2011, 11:16 PM | #201 |
67-72 parts collector,…
Re: Project: NO-LIFE,...
I think it's going to have to come out to do that.
I don't know how you do it,... when it's in the truck.
08-13-2011, 11:22 PM | #202 |
Village Idiot....
Easy........Reynolds Wrap.
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
08-13-2011, 11:24 PM | #203 |
Tot Roddin'
Now where are those pics? I never see them posted.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-13-2011, 11:28 PM | #204 |
Village Idiot....
Waiting on yours first!!!! I'll see if I got some with some wrap in them to show you.
08-13-2011, 11:30 PM | #205 |
Can you change a 6-cylinder oil pan gasket in the truck?
08-13-2011, 11:32 PM | #206 | |
Tot Roddin'
I think I need to bring some of the foil I use at work to pull in radio stations back to the garage now.
08-13-2011, 11:37 PM | #207 |
Still Learning
Nice work with the tubing Keith.
Not sure if you can change the 6cyl pan gasket in the truck or not? I know you can on a big block truck. I just removed the motor mount bolts and a few other things then jacked it up far enough to get the pan out. It was a major PITA. I do remember that part. |
08-14-2011, 08:52 PM | #208 |
A guy with a truck
Agreed. I like that they stand out a bit, showing off the hard work that went into them...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-14-2011, 09:34 PM | #209 |
Get some tips from n2billet and detail it real quick. I just stabbed a new motor today in Krusty, and got alot of plumbing, etc. The front clip is off and painting core support etc. I got along way to go and ive got about 800 miles to KS.
Good luck on your progress. Any pics. from this weekend???
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
08-14-2011, 09:43 PM | #210 |
Nothing worth showing.
I bent up the trans lines today. (That's another job that will get re-done when the engine comes out. What a pain, doing it in the truck.) I'm going to fill it with fluids tomorrow and look for leaks. Ha. Gas, water and trans fluid. I need to drive this thing, some, before I head to Kansas. Plus I may need to remove the exhaust manifold,... if I can't get the manifold studs out.
08-14-2011, 10:01 PM | #211 | |
08-14-2011, 10:36 PM | #212 |
Blaze-Air
Great job on getting the tranny puzzle figured out.
Keep the engine and compartment as is, just make it ultra clean. Good progress. Posted via Mobile Device |
08-14-2011, 10:52 PM | #213 |
Village Idiot....
That would hurt if it wasn't true...........Keith (lolife) is a lot smarter than me by testing everything before a trip.....by the looks of things this year will be no different for me on the other hand
08-15-2011, 11:24 PM | #214 |
Tonight I added an overflow container to the truck.
It's just a cheap poly tank from Jegs. I alway try to put these somewhere out of the way, because they are ugly. I mounted it to the battery tray. The radiator overflow hose runs under the battery and connects to the bottom of the can. The upper hose exits thru a hole in the inner fender. I had to make a spacer, for the lower mounting bolt,... because of the weird angle on the side of the battery tray.
08-15-2011, 11:28 PM | #215 |
Also filled the truck with fluids, and started it.
Luckliy there were no leaks in any of the new lines I made. I have a terrible exhaust leak, so it's kinda loud. (sounds like a tractor to me. Ha) But,... with the truck setting on jackstands,... I have a vibration that wasn't there before. I'll fix the exhaust,... and then look at this vibration issue. Trans or Engine? Who knows. I may be done with this truck,... for this year. I need to get back on Ginger anyway,...
08-16-2011, 12:09 AM | #216 | |
08-16-2011, 08:18 PM | #217 |
Tot Roddin'
Looks good installed Keith.
Curious about that rattle... let me know if you need help tracking it down once you button things up.
08-16-2011, 08:45 PM | #218 |
Keith, your truck is coming along nicely, interior really looks great!
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
08-16-2011, 11:30 PM | #219 |
Got the exhaust manifold "doughnut" put in tonight.
Then proceeded to pull the trans back out so I could remove the "bent" flexplate. I found my vibration.
08-16-2011, 11:32 PM | #220 | |
Thats the only part of this truck that hasn't given me grief.
08-16-2011, 11:53 PM | #221 |
Still Learning
What caused the bent flywheel?
08-16-2011, 11:59 PM | #222 |
Three indexing dowels on the 292 crank.
They were tapered. .440" dowels and .420" holes in the flexplate. I bent the center of the new flexplate and tried to use it anyway. I thought I was going to drive it tonight,... but now I'm flexplate shopping again. It's kicking my butt,...
08-17-2011, 12:02 AM | #223 | |
Still Learning
08-17-2011, 06:23 AM | #224 |
It's more than just reaming the holes.
It's a big mess. I can't get the dowels out of the crank. The original flexplate pulled one dowel out when it was removed. (so I have 2 of the three dowels still in the crank). I'm trying to figure out if I need the dowels at all. Can I cut them off flush? Can I drill the dowel holes on the flexplate over-sized? I can't seem to find any 292 specific answers on the internet. Plus the crank bolts are 1/2"-20. And I need a 5/8" long bolts. Seems like the regular 1/2-20 bolts I used distorted the flexplate in the center. I have some ARP bolts coming now,... but who knows it they are correct. The original torque converter bolts were 7/16". My new converter is 3/8". All the 292 flexplates have 7/16" holes in them. Ive' spent so much money on a simple trans swap,...
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-17-2011 at 06:59 AM. |
08-20-2011, 07:58 PM | #225 |
Well here it is out of the garage.
The new transmission works great. No leaks in any of the new lines I made,... but the engine is just too tired. I got the exhaust manifold leak fixed,... and it sounds like it has a low end knock around the #1 cylinder. It's getting put back in storage. I think the 292 will be coming out, and be replaced by a small block or my old 454,... someday. It would be cool to throw a new 4.8 LS engine in it,... since the 292 was a 4.8. But that's not in the budget for this low budget truck. Gotta get back on Ginger.
