Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-22-2009, 03:38 PM   #201
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: project: FTD
no as in the "stock gm performance motor" that came with the truck.. had a cool little surprise in it...
hyaaaaayyyy
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 08-22-2009, 04:28 PM   #202
joe231
joe231's Avatar
Re: project: FTD
so, can you elaborate on how you fixed the cracks in your dash pad before you painted it? any progress or before shots?
CHEVY ONLY
Old 08-22-2009, 04:52 PM   #203
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: project: FTD
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 08-22-2009, 06:23 PM   #204
dammitmitchell
the pollock
Re: project: FTD
i used "plastic epoxy"
i caught the cracks while most were under an inch, i also had three holes from where my sirius unit was mounted...
im sorry i diddnt take progress pictures
but here's the steps
wash wash wash the pannel with dish soap and water
scrub with either green scrubbie or soft steel wool, let dry for a few hours...
i WET sanded with 320, then WET 400 grit the cracked areas.. you CAN do this to the entire dash pad for a "smooth surface finish"
and i reccomend wet sandign because the vinyl pad wont heat up or "ball up" in your sand paper
i took the two part (generic brand) plastic epoxy mixxed up about half the tubes and applied it with a plastic bondo spatchula
i put it on thick and as it began to set i "skim coated" it and let dry overnight
NOTE!
it will NOT stick/adhere to an unsanded surface... period.. it will peel..
then i wet sanded sanded it with 400grit to smooth and blend it
then dusted off the pad with microfiber and soapy water
let dry
then did a "feathercoat" with the duplicolor vinyl paint (not the dye)
waited a little bit and did the second coat nice and thick (not a single run thank god)
Now for the speaker inserts i just grabbed some 6incher or bigger speaker grills (if you are creative you CAN in fact fit in the specialy stamped brands like kenwood etc just gotta be careful and patient
i took the grills and "flattened them" cur out all the rperforations and cut out the center metal support rod for the corner holes, filed it and cleaned up the edges (used a small ruler to make sure it was straight)
flipped dash pad over and with the grill on the "top" side i traced the outlineof said speaker holes and then proceeded to leave about an inch of "extra" metal on each corner, and notched them for an "easy spread" then bent the metal to fit flush with the speaker holes
and adhered it with some black silicon..
painted one more time
and now it's ready for install...
then now "next time" i do it i'll sand the whole dang thing
Army vet 02-08
Old 08-22-2009, 06:25 PM   #205
dammitmitchell
the pollock
Re: project: FTD
i have to finish the center hole and i'll post pictures.. but it loooks niceeee
BEFORE
Army vet 02-08
Old 08-22-2009, 06:34 PM   #206
joe231
joe231's Avatar
Re: project: FTD
Cool!
Thanks man!!
CHEVY ONLY
Old 08-22-2009, 09:33 PM   #207
dammitmitchell
the pollock
Re: project: FTD
Army vet 02-08
Old 08-22-2009, 10:01 PM   #208
TheSebring
Re: project: FTD
hyaaaaayyyy
Just surprised you didn't go getcha flat tops. You're gonna have a hard time turning them big ole' tires with your compression so far, I think.
TheSebring is offline   Reply With Quote
Old 08-22-2009, 10:14 PM   #209
dammitmitchell
the pollock
Re: project: FTD
meh.. it's an excuse for heads.. period.. =-)
Army vet 02-08
Old 08-22-2009, 11:11 PM   #210
highperf4x4
Re: project: FTD
my bad, they looked like new pistons. you must have done an awesome job of cleaning them up
highperf4x4 is offline   Reply With Quote
Old 08-23-2009, 11:26 AM   #211
TheSebring
Re: project: FTD
period.. =-)
You've got plenty of those .
Old 08-23-2009, 10:31 PM   #212
dammitmitchell
the pollock
Re: project: FTD
gonna pull the vc's and headers and give it one mreo "good" thick coat of black.. BUT.. im dying for some alluminun VC's.... oh my got they are so dang sexy!!!!
Army vet 02-08
Old 08-24-2009, 11:37 PM   #213
TheSebring
Re: project: FTD
Lol, alluminun. I'm getting this picture of a robotic nun in church that you think is sexy.
Get some of those VC's and post pics of 'em. Like to see how they'd contrast with your engine compartment painting.
Old 08-25-2009, 09:27 AM   #214
dammitmitchell
the pollock
Re: project: FTD
hahahhaa!
that was a funny one.. ! good way to start the morning!
Army vet 02-08
Old 08-26-2009, 10:50 PM   #215
dammitmitchell
the pollock
Re: project: FTD
been busy today
Army vet 02-08
Old 08-26-2009, 10:54 PM   #216
dammitmitchell
the pollock
Re: project: FTD
i have since connected all hozes
carb lines etc...
equal length the rest of the wire i had "layin around" and even found a stray or two
hmmm.. 12 hrs today.. and got two HALF trucks pretty well dont.. (stupid freaking red f-word therw me an electrical curve ball.. spent three hours chasing down a intermediate open circuit found it in the turn signal connectors... grrrrr.. i was NOT pleased..)
Army vet 02-08
Old 08-26-2009, 11:16 PM   #217
highperf4x4
Re: project: FTD
Dang that reminds me, my parking lights on the tool van aren't working. I friggin hate electrical problems. Where's Joe when I need him
Old 08-26-2009, 11:43 PM   #218
dammitmitchell
the pollock
Re: project: FTD
well.. im here too dick..! hahahaha
Army vet 02-08
Old 08-27-2009, 05:39 PM   #219
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: project: FTD
Its lookin good man. But your gunna make the rest of the truck jealous.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 08-27-2009, 07:31 PM   #220
highperf4x4
Re: project: FTD
Ok, if you want to head over and fix it for me then be my guest!
Originally Posted by 1985-GMC View Post
Its lookin good man. But your make the rest of the truck jealous.
Old 08-28-2009, 11:40 PM   #221
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: project: FTD
shes coming along real nice.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 08-29-2009, 11:00 AM   #222
dammitmitchell
the pollock
Re: project: FTD
thank you
Army vet 02-08
Old 08-29-2009, 01:53 PM   #223
highperf4x4
Re: project: FTD
you're welcome
Old 08-30-2009, 07:57 PM   #224
dammitmitchell
the pollock
Re: project: FTD
photo evidence of for guys learnign to shut the hell up and take direction (not orders)... he listened well and we "hid" my fuel filter yaaaayyy... and he only screwed it up his first try!
Army vet 02-08
Old 08-30-2009, 08:11 PM   #225
dammitmitchell
the pollock
Re: project: FTD
i just simply could NOT resist the "shiny sunset" picture
Army vet 02-08
