Old 06-13-2011, 05:46 PM   #201
flatbed51
flatbed51's Avatar
Re: '50 5 window.....s10 swap
Originally Posted by rhodog77 View Post
Got my mirrors put on today. I really really wanted to go with peep mirrors but it sounds like they arent very functional, just for looks. I picked up these california style mirrors installed in minutes. They come with rubber spacer/wedges to fit any mounting postion. I really like the look of them. Might look a little silly to some....ratty lookin truck with smooth sport mirrors but I still like'em.
I vote for functional over cool when it comes to mirrors, as long as they are not gawdy looking, and yours are not. If you are not happy with them Summit Racing has some pretty cool looking swan neck mirrors. Don
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 06-16-2011, 07:41 AM   #202
duwem
duwem's Avatar
Who did you buy the mirrors from?
I have heard them called "Carolina mirrors" I'm assuming they are the same thing, just different brands have different lingo.
duwem is offline   Reply With Quote
Old 06-16-2011, 10:38 AM   #203
99 to Life
99 to Life's Avatar
After all that fuss with my peep mirror I finally got the drivers side one all line up and it works ok. The pass one I can't see out of for the life of me though.
I thought california mirrors where those trucker mirrors, the long verticle ones. Def too much lingo out there I guess or I'm just not paying attention.
It's nice when you finally get all the pedals hooked up, feels like things are really coming together. Sux though how much room you loose under there though with some mixed matched set ups. I like how my stuff functions but it is a pain to get under there and route wires and get behind the gauges. Not complaining but I think I might try some aftermarket stuff on the next one.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 06-16-2011, 08:03 PM   #204
rhodog77
rhodog77's Avatar
I got the mirrors off ebay from a place called speed pro performance. I got them for under 50 bucks, shipped. Im not sure what they are actually called. I have always called them california sport mirrors. I think that the long vertical ones with the large brackets are called western mirrors. Who knows.... I have seen them called all kinds of stuff. I call them cool!!! The best thing is that they are fully functional. I might remount them a bit higer on the door. The pax side is a little low. I agree with the brake/gas pedal setup. Next time I think that i will go with a frame mounted master cylinder for the brakes and an aftermarket gas pedal. This will do on this build cuz it was free with the S10.
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 06-21-2011, 08:42 PM   #205
vintage_car
can you post a pic of the gas pedal linkage hooked up and mounted in the engine bay?
vintage_car is offline   Reply With Quote
Old 06-22-2011, 10:41 PM   #206
rhodog77
rhodog77's Avatar
Hey Vintage,
Here are a few pics. Not sure if this is what your looking for, if not let me know and I can take some more. The first one is the linkage at the carb and the second one is the mounting clip at the firewall, just under the coil. Hope this helps
brian
1970 P10 Stepvan
Old 06-23-2011, 09:55 AM   #207
vintage_car
perfect! What part is that off of that holds the throttle cable? Is that an s10 part?
Are you going to the southern truck nationals in white house mid-July? I'm trying to have mine drivable by then, I know it will still be in progress, but I'd like to get it on the road. It has been close to a year since it has moved under it's own power.
Old 06-23-2011, 07:26 PM   #208
rhodog77
rhodog77's Avatar
Vintage,
Not sure exactly what part your talking about. I can tell you that the linkage is all s10 and the bracketry is all stock 350 parts. I havent really given much thought about the southern nationals. Im looking for a good show to hit up around that time....so I might come down. Its about a 4 hour drive for me. Im deciding between that and Goodguys in Columbus OH. Its only about 2 hours drive.
1970 P10 Stepvan
Old 06-26-2011, 02:14 PM   #209
vintage_car
Bracketry is what I was looking at. So it's stock 350 for the bracket that holds the throttle linkage and carb throttle spring.
Old 06-26-2011, 04:09 PM   #210
rhodog77
rhodog77's Avatar
Yep, all stock brackets. You must be getting close to having yours on the road.
1970 P10 Stepvan
Old 06-26-2011, 09:29 PM   #211
vintage_car
It is getting closer. Power steering pump is fighting the whole way! Finding hoses that work and brackets are being a pain. Fuel lines are still not done, nor is the electric pump, wiring needs attention, but it is getting there.
Old 06-28-2011, 05:01 PM   #212
vintage_car
are you using a kickdown cable?
Old 06-28-2011, 07:01 PM   #213
rhodog77
rhodog77's Avatar
Hey Vintage,
I am running a stock kickdown. If you look really close, it is attached to the bottom end of the butterfly on the carb. It runs just behind the large return spring. I have only moved the truck around in the driveway a handful of times. I did run it around my neighborhood for a few minutes but never got up enough speed to have the tranny shift. I didnt have my fan hooked up so I did want to get the motor to hot.
1970 P10 Stepvan
Old 06-29-2011, 12:22 PM   #214
vintage_car
do you have a pic of it mounted on the transmission? I don't have any of these components, guess I need to go to the parts store...
Old 06-29-2011, 05:25 PM   #215
rhodog77
rhodog77's Avatar
Vintage,
I dont have a pic of mine. I can get one if you need. I did find one few online though. Check it out and let me know if you still need something.
http://www3.telus.net/public/djs67/m..._cable_cut.jpg
In the pic, its the one that says cut here (not sure why it says that or why you would cut your kickdown).
1970 P10 Stepvan
Old 06-30-2011, 10:29 AM   #216
vintage_car
If it isn't a picture of yours it does me no good at all!!!
thanks yet again for the help...
I got my gas pedal and linkage done last night. next up are the gauges and gas tank.
Old 06-30-2011, 05:21 PM   #217
rhodog77
rhodog77's Avatar
Good luck with the gauges and fuel tank. Post some pix when you get them wrapped up. Let me know if you need anything else. Wont be long and you'll on the road!!!
1970 P10 Stepvan
Old 07-05-2011, 04:43 PM   #218
vintage_car
what did you use for the hard lines you made to go into the gas tank?
Old 07-05-2011, 04:57 PM   #219
rhodog77
rhodog77's Avatar
Vintage,
You can use hard brake lines as fuel lines but you should never use fuel lines for brake lines. Brakes require much more pressure to work so brake lines are built much heftier to handle the higher pressure. Using hard brake lines for fuel lines is fine because of the low pressure required to operate either style fuel pumps. I picked a cheap bender from harbor freight for less than 10 bucks...and I think the 3 seperate size line were less than 20 bucks total.....and the 3 bucks for the jb weld.
1970 P10 Stepvan
Old 07-05-2011, 05:06 PM   #220
vintage_car
I was wondering if brake lines would be suitable. good deal. off work thursday and friday and very hopeful to have the truck driving around the neighborhood. plenty left to do to make it streetable, but man I can't wait to clear this hurdle!
Old 07-05-2011, 05:15 PM   #221
rhodog77
rhodog77's Avatar
make sure you take a video and post it up. Looking forward to seeing yours on the road as well. good luck
1970 P10 Stepvan
Old 07-06-2011, 09:55 AM   #222
vintage_car
do you have have the front clip on the truck with the radiator and fan setup? I have yet another pic request. A shot straight down right behind the grill, capturing the fan/radiator setup and backside of the grill. I'm having clearance issues. No massive rush, I'm still working on gauges, fuel stuff, wiring and building a trans tunnel. But I know that is the next problem area.
Old 07-06-2011, 10:47 AM   #223
kustombrad
kustombrad's Avatar
If you're running a 700r4, that's the TV cable and NOT a kickdown. Make sure you have it adjusted right or you'll smoke the transmission! Looking good!
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 07-06-2011, 10:50 AM   #224
vintage_car
Mines a turbo 350, but I have been reading and some say you can use one and some say you don't need one...
Old 07-06-2011, 11:26 AM   #225
vintage_car
what did you do for a lower radiator hose? I bought one of those universal hoses, but there are some decent kinks in it that I just wouldn't trust on a real drive.
