#201 | |
Re: "The way it is" 67'swb
carz I think it is??
well was able to get some work done with the long weekend. i got my vent boxes buttoned up and got my engine completely done. got all the power steering hooked up and got my new alternator. i was not thrilled with the chrome finish but actually think it breaks it up and could not beat the price for a 1 wire hookup, internal reg and 110 amps. the only think i am having trouble with is when i go lock to lock it has 1" to go on the pass side but the gearbox runs out of movement and can go/push past lock on driverside. do i have my pitman arm not in the right position on the gearbox? i thought i had it centered but must not have? if i am thinking correctly it goes in 1/4 incriments on the spine and am not sure if i just need to move it 1/4 turn in the correct direction so that it has the same distance? let me know what you guys think or if anyone ele has ran into this. thanks, enough rambling here are the pics.
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#202 |
not bad... no idea on the gearbox...
how are you going to wire this rig? I have heard good and bad on the 1-wire deals...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-07-2010 at 10:40 PM. |
#203 |
you mean the alternator setup,right. i think i will use the one wire for ease and clean look. i know you can wire it with the plug but not sure of any advantage?
when you say good and bad, what have you heard. now you have me worried!!
#204 |
only heard issues of using it with OEM amp gauges... but you are running aftermarket right?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#205 |
Tot Roddin'
Lookin' good!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#206 | |
thanks nate, your truck has given me a lot of get up and go to get mine done.
#207 |
Sofa King Crazy!!
On the steering....line up the pitman pointing toward the steering wheel while it is in the straight position, then adjust the tie rods accordingly, driveway alignment!!! Should help some. The POR 15 was a joke!! I didn't do mine, but I did spray it well with a rattle can before and after welding (the best that I could through the kick panel vent) and it has good coverage!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#208 |
Thank you for the steering advice! I did figure that out after some fiddling. Right now I an working on getting my clutch master cylinder figured out. I think I got it but have to do some rigging on the clutch pedal so that it work perfectly and the plunger does not come out of the back of the MC.
#209 |
I finally found a clutch master cylinder that I would be able to use for my 99' nv3500 transmission. The one for this year did not have the ears to bolt it to the firewall and was a plastic snap lock.
![]() Everything worked out great with the brake mc clearance and the way that i bolted it to the clutch pedal. The throuw length on the mc was 1.5" empty and was able to get a total 1.25" empty on the pedal with keeping the plunger on a parallel plane of +/- 1/8" which I am very pleased with. I dont think I will have to wory about the .25" loss cause I figure once it is bled it will hopefully only go an 1" or so with engaging the clutch fully. I have filled it up with fluid and pump it several times and had some pedal there but am going to leave it bleed it self some night till I try final bleeding the system. Enough rambling, I know what you guys want!
#210 |
and 1 more
#211 |
Had got my clutch completely done today! Once I got the stop firgured out and welded on I blasted and powdercoated the whole set up and installed new plastic bushings. Now if I only had a truck I could use it in!
#212 |
where did you get the bushings from? I assume that you PC'd it in pieces and then reassembled?
good work on the clutch..
#213 |
i had gotten them from ece when i had placed an order from them. i forget the price but not bad at all.
yep tore it down and then pc'd and put back together. it turned out really nice and tight no woble or wear like it was before!
#214 |
Subscribed!!
![]() You've got some great work invested in this truck! |
#215 | |
Local Redneck Authority
#216 | |
Thank you propane mine is the green one, IT IS FOR SALE!! Those could be two neat little projects to do and be different which I love! I think it is neat when people do there own style!
#217 |
Very cool. I don't think there's one BAD bike out there, just some cooler than others! Feel free to check out my bikes on my photobucket. I think I have a couple cardboard sketches of the gs on there too.
http://s88.photobucket.com/albums/k1...02006%20SS750/ http://s88.photobucket.com/albums/k1...01977%20GS550/ awesome progress on the 67, every one of these builds I see I wish I could find a decent cab down south to bring home to my chassis! |
#218 |
Adam B
Nice progress, keep up the good work!
#219 |
Yeah I need to do something with my drip rails too. What do you put back in there for caulking?
#220 | ||
![]() Checked out your bikes pics and they are looking good. Thanks I am trying, getting there slowly.
#221 |
Cool, thanks!!
#222 |
Under Construction
nice progress John! I believe you are talking about seam sealer (caulking) make sure to use seam sealer and not regular caulking.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#223 |
#224 | |
Under Construction
![]() http://lmgtfy.com/?q=3m+seam+sealer
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 05-02-2010 at 10:52 PM. |
#225 | |
![]() Question though. If it's self leveling then how did you keep it from running down the side of the truck where the drip rail turns down behind the door? |
