#201 | |
Re: 1972 GMC Shorty Conversion
The headers you recomended appear to be for a small block. My truck has a big block in it. I found some shorty's made by Patriot that I'm considering purchasing. Thanks, Miles |
#202 |
this is something i have been wanting to do for quite awhile ! looks like you are doing a great job ! it takes some melons to cut up a super nice truck like that !hats off to ya ! now maybe i will get started on mine .hope to see more pic's . great job!
#203 | |
Keep on keeping on, I'm sure whatever you get will be done with all the same attention to detail you have used so far.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#204 |
![]() Join Date: Oct 2008
Your project is coming along nicely! Wish I could say the same about mine but customers come first.
Just out of curiosity, why did you decide to go with the gear vendors unit rather than a 700R4. I think that is a 400 pan I see there. Sorry if you mentioned it before but I am feeling too lazy to go back and look for it. lol Once again great work! Richard
STR Restoration and Customs 1971 C10 Custom 1964 Impala 2dr Hardtop 1965 Parisienne CS 1937 Nash Lafayette 1947 Willys CJ-2A |
#205 |
Tot Roddin'
Great looking new project, and the old one is coming together nicely; any updates?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#206 |
Still Learning
Just got through the whole thing.....WOW! awesome skills! subscribed.
#207 | |
#208 | |
Not a lot of progress lately.. been side tracked with life. I've been plugging away at the wiring. I cleaned up the rear brake/tail harness and installed it. Also installed a new harness from the cab to the rear harness. I'm getting ready to pull the headers off to replace them with something shorter. I'm going to fab up some new shift linkage so I can get rid of the cross shaft between the TH400 and the frame. Once the shaft is gone, I'll have more room to tuck my exhaust up inside the frame. May have to fab up a new tranny crossmember for additional clearance, we'll see. Did you get your center caps yet? If so, lets see some pics. Thanks for looking, more to come - soon I hope. Miles |
#209 |
Tot Roddin'
Miles... I finally did get the caps on and not 70 miles later the water pump blew so, needless to say, I learned my lesson from the truck gods...
![]() Here's two quick pics of what the wheels look like on my truck; couldn't be happier..., well, other than the water pump. ![]()
#210 | |
Miles |
#211 |
Some new headers from Summit Racing showed up today. The Doug Thorley headers I currently have hang way too low for my comfort. These should provide plenty of ground clearance and allow me tuck the exhaust pipes up inside the frame after I redo the shift linkage. These headers are Patriot Clipster headers that I've seen others on this forum use. Should get them on this weekend.
Here's a few pics. Miles |
#212 |
Got some new tires mounted up. 275/60/15 on the rear and 245/60/15 on the front.
Here's a few pics. |
#213 |
Your truck is looking great. The wheels and tires are perfect, i love ruck rally's. Nice job.
#214 |
VA72C10
![]() Join Date: Mar 2008
very nice!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#215 |
Still Learning
Must be nice to just "pop" for new meats like that? They look really good!
#216 | |
Tot Roddin'
The wheels/tires look good mounted and on the truck.
#217 |
Well, my truck is finally out of the garage - under its own power!!
In fact, I drove it around the block over the weekend. I still have a lot of stuff to do before it's road ready (bleed the brakes again -pedal is a little soft, mount the rear bumper and hidden hitch, redo the shift linkage for exhaust clearance, get new exhaust, alignment etc). It feels good to at least have it out of the garage. I pieced together some exhaust just so I could go for a spin, so don't knock me for it hanging down so low. I'm hoping to get the truck in for a new exhaust system late next week. Need to get the bumper, spare tire and hitch installed first. Here's a few pics of it out in the sun. Thanks for looking. Miles |
#218 |
Still Learning
Looks great! What mods did you do to your suspension? Love the ride height and stance. Those rallies look killer!
#219 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Looks GREAT!
Nice choice on the tire sizes.
#220 |
67cheby
![]() Join Date: Sep 2008
Awesome work and good , classy looking truck, i really dig the color
#221 |
Tot Roddin'
Can't wait for paint!
Looks amazing Miles, nice work!
#222 |
Nice stance
#223 | |
Mods are - Front 2" big block drop springs 2.5" drop spindles Rear 6" drop spring Adjustable panhard bar C-Notch All ECE parts. Thanks, Miles |
#224 |
I got the rear bumper and hidden hitch mounted up this weekend. Also got the new shorty headers installed and modified the shift linkage to clear the new exhaust that's coming on Wednesday.
Had some trouble fitting the drivers side header. I had to pull the motor mount out (the bucket portion that bolts to the block) and grind away some meat in order to clear the header. Also has to re-rout the oil dip stick on the passenger side in order to clear the header. As far as the shift linkage, I got rid of the cross shaft (cross shaft between the tranny and the frame) in order to make room for the exhaust. I need to replace the new Napa master cylinder, it's leaking brake fluid around the piston. So much for the "get the good stuff at Napa". A few odds and ends to wrap up before the truck heads off to the exhaust shop on Wednesday. I'll post some more pics after the exhaust is complete. Here's a few pics of this weekend's activities. Thanks for looking, Miles |
#225 |
I really like your shift linkage mod!
I may have to "borrow" that idea.
