Old 11-16-2012, 08:33 PM   #201
CHROMAHOLIC
CHROMAHOLIC's Avatar
Re: off it goes
Mast Motorsports L99
L99 416
Specs:
Type: Displacement: Compression Ratio: Bore x Stroke:
Rev Limit:
Crank:
Rods:
Pistons:
Cam:
Heads:
Intake:
Valve Springs:
570 HP
L99 6.8L
416 Cubic Inches
11.2:1
4.070 x 4.000
7000 RPM
Callies Forged
Callies H-Beam
Mahle Motorsports
Mast Custom VVT Core Cam LS3/L92 Heads
LS3Car Intake
Mast Nitrided Beehive
LS3 Aluminum Block
Plateau Honed to 4.070”
True Surfaced Deck
Engine Block Debured Blueprinted Shortblock
GM Car Harmonic Damper
ACL Rod and Crank Bearings Callies 4.000 Stroked Crankshaft Callies H-Beam Connecting Rods Mast/Mahle Motorsports Pistons LS3/L92 Cylinder Heads
ARP Head Bolts
ARP Main Studs
Cometic Headgaskets
GM VVT Phaser with Restrictor
Mast VVT Core Custom Hydraulic Roller Cam LS3 Hydraulic Roller Lifters
Mast Black Label Pushrods
Mast Nitrided Beehive Valve Springs
M-90 Calibrated ECM
M-90 Main Wiring Harness
MAP/IAT Harness
Dual Bosch EGO Sensor
LS3 IAFM
GM 90mm DBW Throttle Body
Bosch Dead Headed Fuel Rail
Bosch LS3 Fuel Injectors
Mast 8 Layer Air Filter with IAT Bung
Intake Air Temperature Sensor 560-2218 | info@ Crankshaft Position Sensor
Camshaft Position Sensor
Oil Pressure Sensor
Oil Temperature Sensor
Engine Coolant Temperature
Engine Knock Sensors
Manifold Air Pressure Sensor
Ignition Coils
Spark Plugs
Plug Wires
GM Foot Pedal
GM Starter
GM Oil Filter
Engine Break in Oil Additive
Your choice of F-Body, Y-Body, or Truck Water Pump, Balancer, and Oil Pan
Runs on Premium 91-93 Octane
CHROMAHOLIC is offline   Reply With Quote
Old 11-16-2012, 08:46 PM   #202
88Jimmy4x4
88Jimmy4x4's Avatar
Re: off it goes
wow......talk about taking it to another level.....nice choice
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-16-2012, 09:33 PM   #203
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: off it goes
THat will be fun!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-16-2012, 10:24 PM   #204
VA72C10
VA72C10
VA72C10's Avatar
Re: off it goes
Nice$$$
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-17-2012, 01:23 PM   #205
K20chevy
K20chevy's Avatar
Re: off it goes
Does that engine have a functionin VVT? Will you run an auto or manual tranny?
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 11-17-2012, 01:29 PM   #206
tip
Re: off it goes
Mother of God!
tip is offline   Reply With Quote
Old 11-17-2012, 08:11 PM   #207
CHROMAHOLIC
Red face Re: off it goes
It's a VVT motor, running a Gearstar Transmission 4L65E built to motor specs, tranny built to 600hp and 600lbs of torque.......motor dyno'd at 578 hp
Old 11-17-2012, 08:43 PM   #208
legendman
legendman's Avatar
Re: off it goes
Wow!!!
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 11-17-2012, 08:52 PM   #209
bigblock73
yeller
bigblock73's Avatar
Re: off it goes
Damn Jim...
bigblock73 is offline   Reply With Quote
Old 11-17-2012, 09:35 PM   #210
CHROMAHOLIC
Re: off it goes
This is same motor .....so it should sound pretty sweet when I fire it...
http://m.youtube.com/#/watch?v=Rwr-X...%3DRwr-XhB4l9E
Old 11-17-2012, 10:37 PM   #211
mooseknuckles
mooseknuckles's Avatar
Re: off it goes
thats gonna be bad ass bro...
mooseknuckles is offline   Reply With Quote
Old 11-17-2012, 11:18 PM   #212
y5mgisi
y5mgisi's Avatar
Re: off it goes
That is bad ass!
Old 11-18-2012, 09:47 AM   #213
K20chevy
K20chevy's Avatar
Re: off it goes
WOW! That is even more power than my VVT motor. I´m running around 500 HP on my L92 with functioning VVT and full ´08 Emissions. You will love the VVT, the torque band is amazing! I love mine!
Old 11-24-2012, 05:04 PM   #214
CHROMAHOLIC
Re: off it goes
front bumper all tucked in for the night....lol
Old 11-24-2012, 05:29 PM   #215
VA72C10
VA72C10
VA72C10's Avatar
Re: off it goes
Nice! Was thinking of doing that on my shop truck....sectioning and capping it...
Old 11-24-2012, 05:53 PM   #216
bigblock73
yeller
bigblock73's Avatar
Re: off it goes
Very cool Jim, love the bumper. Shaving the bolts goes a long ways too!
Take notes bumper Tucker's, this is how it should be done.
Old 11-24-2012, 06:32 PM   #217
CHROMAHOLIC
Re: off it goes
thanks Jeff
Old 11-24-2012, 09:19 PM   #218
J Knight
J Knight's Avatar
Re: off it goes
Your metal fabricator is the God of Fab!!
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-24-2012, 09:28 PM   #219
CHROMAHOLIC
Thumbs up Re: off it goes
^^^^I agree
Old 11-24-2012, 11:18 PM   #220
trout
Re: off it goes
^^^^^this is a awesome fabricator^^^^^^
Edited by staff
trout is offline   Reply With Quote
Old 11-25-2012, 07:41 AM   #221
K20chevy
K20chevy's Avatar
Re: off it goes
Looks absolutely amazing!!!! I love it when people just make the original just look that tiny little bit better than stock, without going overboard. Will you put the bumper triagular mounts from the fram to the bumper back in??
Old 11-25-2012, 08:02 AM   #222
CHROMAHOLIC
Re: off it goes
Thanks for the compliments, no triangular mounts....they are tucked and narrowed enough now that the vibrating will be minimal so we're running a small one to the rad support only and losing the long ugly one to the frame. Also shaved all the bolts of for a cleaner look. Not doing any off the wall stupid stuff to it....trying to build it as if GM built a slammed 77 LS powered Truck. Going to make some slight mods but to the average eye it will look stock, it will take a C-10 enthusiast to notice the subtle changes.
Old 11-25-2012, 10:54 AM   #223
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
Re: off it goes
That Mo-Fo, is going to be NASTY!!!!
Smoke_Dog is offline   Reply With Quote
Old 11-25-2012, 12:39 PM   #224
moneyeater
moneyeater's Avatar
Re: off it goes
I´ve seen Stacey David doing that to his Copperhead C10 and it makes an unbelievable difference but still subtle enough that most people don´t realize!
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 11-27-2012, 08:25 PM   #225
y5mgisi
y5mgisi's Avatar
Re: off it goes
That kind of effort to pull off such a small detail is what makes trucks/builds like this a notch above the rest.
