Old 06-14-2010, 10:25 PM   #201
nuke1
nuke1's Avatar
Re: Halfbreed - GMC Z71 + IH Extd Cab
I have kept tabs on what has been happening here, and your truck is totally fricken awesome!!!!! great work on it!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 06-15-2010, 01:35 AM   #202
sparkydog
sparkydog's Avatar
Thanks nuke1. I am honored that a guy with your skills likes what I am doing! I sure wish you were local (like the same nation) so I could have you do my rear doors and cab roof. Any chance you are going to Disneyland real soon?? (hint)
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 06-15-2010, 01:41 AM   #203
sparkydog
sparkydog's Avatar
Tonight I did two fun things.
First I tried out something crazy - I wanted to "stabilize" my stock bench seats from falling apart any more than they already are. So just for s&g's I tried some stretch wrap from work. I have no idea how long it will hold up but it was fun, kind of kinky and (at least for a short while) really firmed up the contours and fit. As a bonus I get kind of a weird fart noise when I climb in. To top it off I threw on a Mexican blanket I had. I swear I am not into the look - I just had it laying around.
Oh and of course what should fall out of the seat bottom while I was wrapping it but a hornet nest. Sheesh that Travelall was FULL from stem to stern with nests. Fer crying out loud!
Balls and a Sawzall
Project Halfbreed
Old 06-15-2010, 01:46 AM   #204
sparkydog
sparkydog's Avatar
Next I pulled out the two sets of hood hinges I had and tried to figure out if one set was better than the other - nope, both were in the same condition. So I grabbed a set, cleaned them off and disarmed them.
Then I got to drive the truck out and turn it around (yay!) and started setting up for the hinge fitment. I parked the truck nose in so I could hang lifting straps from the trusses.
Took the pass side wheel and fender skirt off. Tacked a little lifting eye onto the hood and set it back on the truck with some lifting straps,
Balls and a Sawzall
Project Halfbreed
Old 06-15-2010, 01:51 AM   #205
sparkydog
sparkydog's Avatar
Then started holding up the hinge and snapping pictures. Then I realized that things were going to be more challenging over on the driver side. Boy I sure hope I can clear the brake MC and the wire harness bulkhead unit. (It is a given that the cruise control module is up for a relo.)
Oh well that is why I am doing all of this - for the challenge and thrill of solving the 100's of big and little problems that crop up.
Balls and a Sawzall
Project Halfbreed
Old 06-15-2010, 02:00 AM   #206
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
wow, i am jaw dropped. Great work, cant wait to see the outcome. She'll be one of a kind. i see one of those ih crew cabs near by and always admire it.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 06-15-2010, 02:18 AM   #207
sparkydog
sparkydog's Avatar
I have my first cause for concern over the condition of the GMC chassis. Now that I have the truck running again and have been around it for maybe a total of 20 minutes of running, I think I may have a problem. The exhaust pipes have two small leaks where the hanger brackets are welded on and they cracked. Whenever I have fired up the motor I got a lot of water dripping out of these cracks. (The crack is upstream of the stock muffler.) Well today when I turned the truck around it was the first time it was sloping backwards down the hill. I stopped the truck outside the garage and left it idling while I moved some chit around inside the garage. It was parked maybe 5 minutes and here is how much water came out.
That just seems like more than "normal" H20 combustion byproduct. My Burb doesn't make that much water. I smelled it and I don't detect any antifreeze - just smoky water smell. But I am worried that I have a blown head gasket. Except I woudn't think the water would get into the exhaust but the other way around.
Whaddup with all that water?
Balls and a Sawzall
Project Halfbreed
Old 06-15-2010, 11:23 AM   #208
Racinaround
Racinaround's Avatar
For Hood Hinges Check out the Porter Built Hinges for the 67- 72 trucks that mount to the cowl area?? or old jeep or land rover hinges that mount on the outside?? I think it would fit the build??
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 06-15-2010, 01:59 PM   #209
NONHOG
NONHOG's Avatar
Hornets ! Hate them ! Always on the look out myself.
That seat cover before the mexican blanket reminds me of my grandmothers
62 Fury wagon with clear seat covers.(many years ago)
I am no expert but if all the running that engine is getting is around the yard
it could never dry out and am often surprised at how much moisture an exhaust system can hold. Thats what I am hoping for you !
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 06-15-2010, 02:15 PM   #210
JimmyFloyd
Looking goof. Let me know if you need any little pieces, as we just got a rusty 65 in the junkyard here. I don't think there is a good body panel aside from the hood, but the interior has some parts.
couple more pictures here: http://s282.photobucket.com/albums/k...2010/?start=40
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 06-15-2010, 03:37 PM   #211
sparkydog
sparkydog's Avatar
Wow.... that IH has had a HARD life! Paint is a little faded too!
Balls and a Sawzall
Project Halfbreed
Old 06-15-2010, 03:40 PM   #212
JimmyFloyd
Actually, the Bondo is a little faded. I think the paint peaced out a while ago when the rust moved in...
Old 06-16-2010, 01:07 AM   #213
sparkydog
sparkydog's Avatar
Our grannies must have had the same taste in bling. Mine did the same thing - probably hit some of the furniture in the house with it too! And right now my bench seat is as tight as granny's girdle!
Balls and a Sawzall
Project Halfbreed
Old 06-16-2010, 03:26 AM   #214
ERASER5
ERASER5's Avatar
Creepy. Sparkydog knows how tight his granny's girdle is.
Keep up the good work on the truck, and uh, leave granny alone...
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-16-2010, 10:38 AM   #215
sparkydog
sparkydog's Avatar
Did a little more cutting on the GM firewall so the IH hood hinges will fit. Then I was able to mount them onto the hood and start designing a bracket/weldment that will become the attach point for the hinge onto the firewall.
I tried to get my camera over on the DS of the engine bay and see how the hinge looks there. Not quite the right camera angle but I'm starting to hope that I'm going to clear the harness bulkhead OK.
In the final shot the black thing behind the hinge with the vicegrip holding it is the start of my bracket.
Balls and a Sawzall
Project Halfbreed
Old 06-17-2010, 02:06 AM   #216
sparkydog
sparkydog's Avatar
Finished the basic shape of my hinge bracket. Tacked the PS in and then marked the hole locations. Drilled the holes. Cut the bracket off/out. Made a clone for the DS and welded in nuts on both sides. Tacked the new brackets back in the truck. Bolted up the hood and crossed my fingers and carefully closed and opened it.
I think I will be OK over on the DS. Very busy in that area and I think eventually some harness mods are in the works so I can stay well clear of the hinge and spring.
But for now I think all is well and I can proceed with more welds and more gussets to strengthen the whole area. Tonight is that last stuff I can accomplish on this trip. More progress in 2 weeks or so!
Balls and a Sawzall
Project Halfbreed
Old 06-18-2010, 06:27 PM   #217
sparkydog
sparkydog's Avatar
Ouch! I walked right into that one, huh?! Rimshot for Eraser5.
Balls and a Sawzall
Project Halfbreed
Old 06-18-2010, 06:38 PM   #218
sparkydog
sparkydog's Avatar
I forgot to post this pic of the DS hinge area - as you can see it's a little too crowded and the hinge wants to rip up one of the harnesses someday!
I'm toying with the idea of fabbing up a "spanner bar/tube" that would run across the engine bay but under the hood. There's lots of open airspace above the fender line that isn't occupied right now. Then I could mount some of the orphaned GMC technology off it. Like the CCM, the coolant recovery tank and maybe the ECM if the harness route would be better. Something like in the sketch.
Balls and a Sawzall
Project Halfbreed
Old 06-30-2010, 11:16 AM   #219
sparkydog
sparkydog's Avatar
3" Come to Jesus
Whenever I have been involved in a creative project I have learned that there always comes a time where I am tempted to modify/expand/redo something. Well I have just such an episode now with Halfbreed.
I'm fretting over 3" of proportion. I am second guessing my decision to cut the rear cab doors as short as I did. I am wondering if I should deal with this or not. For me, the "ideal" proportions for the cab and bed are those of the modern GM X-cab (like the '97 that donated it's chassis for my build). I really like the balance of the body. When I was busy 3 months ago trying to figure out how to cut the real sheetmetal and deal with all of the variables, I decided to make the rear cab about 3" shorter than ideal because at the time I could not figure out a clean way to modify the bottom rear wall of the IH cab to clear all of the GM equipment.
But with 20/20 hindsight I know there is a fairly good way to deal with this. I just wish I would have thought of it then. If I was to stop now and go do this over I will be faced with at least a 1-2 month delay and I will have to chop up the cab of another GM Xcab in order to get a new floorpan/rear wall piece. I will also be faced with having to fill in 3" of IH door frame opening with body metal that I don't think I saved. And finally I would have to cut the bed again and shorten it another 3". So it is a significant amount of work. But it's better now than later after I have cut down the IH rear doors themselves. If I do that and then change my mind I have even worse consequences.
These are shots of what I am talking about. In the first picture I show how the truck looks now compared to what the slightly longer cab would look like. The top image is how it is now and the bottom image is photoshopped to the longer cab. You can see the rear doorway is wider. And the second picture/pair shows how the slightly longer cab matches up with the GM body/bed proportions.
I know a lot of you probably don't even see the difference and that is just it - this probably doesn't matter all that much. It's the OCD/perfectionist in me.
My choices are: 1) forget it and keep going, 2) convince myself that someday later I can change the body again if I want to, 3) stop and deal with this now before I cut the rear doors down.
Opinions?
Balls and a Sawzall
Project Halfbreed
Old 06-30-2010, 11:35 AM   #220
Walts_restoration
i thought they looked a little small on the rear doors, although its not my project nor my time and money lol. Id say if your unhappy now stop and fix it, but make sure its what you want so its done right the first time.
Old 06-30-2010, 11:36 AM   #221
JimmyFloyd
I would say deal with it now. Think of all the other stuff you'll be basing measurements off of now, and all the custom pieces you'll have to make for the doors, which you'll have to re-do later on if you change your mind.
And if you need a roof cut section, let me know and I can cut that one of the 65. I think it's like $75 or so for a roof here.
Old 06-30-2010, 11:50 AM   #222
dougminton
dougminton's Avatar
I wouldn't mess with re-doing that much wok unless I was going to be the one getting in and out of the back door.not enough difference in the looks.
But that's my opinion. Doug
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 06-30-2010, 12:56 PM   #223
67ChevyRedneck
67ChevyRedneck's Avatar
Put the rear seat in. Mount a door and with it open see how easy or difficult it is to get in or out. Go from there.
That's a hell of a lot of work for 3". That kind of change is sometimes the motivational killer in projects like this. You cut it back apart, wonder why the hell did I do this?, then give up. Maybe not permanently, but sometimes for years. You seem to not be this type of person, but redoing months of work can deter even the best of us.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-30-2010, 06:52 PM   #224
NONHOG
NONHOG's Avatar
Wow lots to think about. The way I see it the longer doors will look more OEM.
the shorter doors will look just fine as long as they look like factory doors.
(no shaved handles)
It is really hard to tell w/o seeing doors in there.
can you photshop the doors in there with and w/o the 3" ?
Either way it will be really cool ! (and I'm picky)
Old 06-30-2010, 08:21 PM   #225
sparkydog
sparkydog's Avatar
Yeah redneck you are soooooo right. I do have to think about the de-motivation aspect of this too. So far I have been making good, steady progress and I don't really want to stop the momentum until I have it street legal. From there on I can deal with the 100's of remaining items - even deal with the potential big body makeover to add the 3" later on. If I leave the cab alone and proceed on I only have 24 items on my punch list before it is street legal again.
Wow lots to think about. The way I see it the longer doors will look more OEM. the shorter doors will look just fine as long as they look like factory doors.
(no shaved handles)
Also good advice hoggy! Now that I have the hood and fenders on I think I will take a fresh side shot of the whole truck. Then I will get a good side shot of the rear doors and chop them into the picture. Thanks!
Balls and a Sawzall
Project Halfbreed
