Old 02-13-2013, 09:52 PM   #201
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My crewcab 4x4 cummins project
Looks nice! I used por15 cjassis coat on my Longhorn. I did the front frame in August, and it still shines nice. I figured it wouldn't last much longer than the regular stuff, but it has.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-15-2013, 10:30 PM   #202
Pullin81
Pullin81's Avatar
Frames all blasted I got a few spots to touch up and a few rivets I forgot to cut off then it's time for paint...
86 gmc short box..461bbc/th400 12.95@106mph
85 gmc crew cab 4x4 8"lift cummins conversion
Pullin81 is offline   Reply With Quote
Old 02-18-2013, 01:02 PM   #203
Pullin81
Pullin81's Avatar
Woo finally looking like its getting somewhere... Gotta get all the stuff ordered for the diffs going stock in the front maybe with an axle upgrade and 4.56 gears . The rear is going to get a Detroit tru track with 4.56 as well. Need to find one new shackel hanger for the front... Bushing pounded out the mount so I cut them off... Anyone know if a guy can find new ones or is this a junk yard deal?
Old 02-21-2013, 12:50 PM   #204
Pullin81
Pullin81's Avatar
All the parts are here to completely overhaul the diffs just gonna get them to a blast shop and get everything cleaned up and ready for paint... Dana 60 all tore apart ready to blast all the pieces hopefully they get everything done today so I can spray tonight n be good and cured for monday
Old 02-21-2013, 03:48 PM   #205
madcow75
madcow75's Avatar
Looks like you allready have the hardest part done. New Kingpins. Were the origanals very hard to come out.I no they can be PNA to come out.
madcow75 is offline   Reply With Quote
Old 02-26-2013, 09:46 AM   #206
05duramaxhd
http://offroaddesign.com/catalog/FUSH.htm these are bigger!!
05duramaxhd is offline   Reply With Quote
Old 03-01-2013, 12:20 AM   #207
Pullin81
Pullin81's Avatar
Got the front all blasted and painted and for the most part together... Just have to throw the axles in n spindles n brakes... Then it will be time for the back... I managed to find a good set of shackel mounts for the front blasted n painted n bolted them on ... I didn't want to spray the leaf springs but the dull black just doesn't look as nice as the frame so I guess ill do them aswell
Old 03-05-2013, 07:45 AM   #208
Pullin81
Pullin81's Avatar
Question for anyone who has changed out there wheel studs. I'm looking for an extra 1/2" longer wheel stud for my front diff. Just want a little more thread for when the wheels get bolted on... This is all I need for the front and it will be done
Started on the rear it is all painted now and cleaned out... Apparently the 14 bolt in my truck has a one year pilot bearing for the pinion support that is now discontinued so after looking and calling around I managed to find one which should be hear today. Then all I need is the rear drums to show up and the rear diff will be finished...
Old 03-05-2013, 09:43 AM   #209
84chevyguyid
Looks like you are making lots of progress on your truck! Hey just wondering if you have any pics of your rear driveline setup with the crossmember and carrier bearing in place? I am building an 86 crew cab thats going from 2 wheel drive to 4 wheel drive. It didnt have any drive train in it when I bought it and I think it had an aux overdrive in it at one time. I dont have any driveline or the crossmember for the carrier bearing so I was wondering what the crossmember looks like and where its located on the frame.
Thanks,
Mike in Idaho
84chevyguyid is offline   Reply With Quote
Old 03-05-2013, 11:39 AM   #210
Pullin81
Pullin81's Avatar
Thanks,
Mike in Idaho
If you scroll up to where my frames painted just directly below the rear cab mounts is where my steady bearing was mounted ... Due to going a divorced transfer case I eliminated the steady bearing and now run equal length drive shafts front and rear.
Old 03-05-2013, 12:29 PM   #211
dieselmec1993
nice built if u deside when its done to sell it im interested
1977 k20 frame with 85 cab and hopefully 6.5 diesel.
1981 c20 long box 250 3 on the tree daily driver.
1982 k25 with 86 cab tired 350 4speed trans 37in military tires.(project Frankenstein). 8.
1984 c30 crew cab dually 6.2diesel next project
only 18 and finshed 5 projects started when i was
dieselmec1993 is offline   Reply With Quote
Old 03-05-2013, 06:17 PM   #212
Dieselwrencher
Most parts stores have a Dorman catalog and you should be able to find studs in it by the specs of the collar and knurled area length and dia., over all length, and over all dia. I did this on my D60 a long time ago and I know I didn't save any part numbers.
Ryan
Old 03-05-2013, 09:13 PM   #213
bucknorris
nice work. this things gonna be sick!
bucknorris is offline   Reply With Quote
Old 03-05-2013, 11:18 PM   #214
Pullin81
Pullin81's Avatar
Yeah I didn't want to go the factory 2.5 stud I wanted to go at least 3 inches overall I might end up putting the factory ones in for the time being seeing there's still lots of time before this trucks completed... I finally got my discontinued pinion pilot bearing... Yucky 120 bucks... Another problem I ran into my eaton posi unit the factory bolt are to short to go threw the carrier into the ring gear so now I have to try n track those down... Yay one thing after another.
Old 03-05-2013, 11:58 PM   #215
Dieselwrencher
ARP may make some carrier bolts for it.
Ryan
Old 03-06-2013, 09:52 AM   #216
84chevyguyid
I put longer wheel studs on my chevy axles on my 84 3/4 ton cause the aluminum wheels needed the extra length. Go online and look up the dorman wheel stud catalog. Has everything dorman makes with specs and pics. I went a good 1/2 inch longer front and rear.
Old 03-06-2013, 06:21 PM   #217
Pullin81
Pullin81's Avatar
One completed rear diff along with an almost finished front getting excited to roll these back under the frame... Start putting the steering pieces in shocks brake lines ect.
Old 03-08-2013, 12:55 AM   #218
Pullin81
Pullin81's Avatar
Ended up gettin the diffs rolled back under the frame today... All cab mounts blasted and painted with fresh energy suspension mounts... Shocks hung forgot the boots at home n need some bolts... Still waiting on the bolts I ordered for the t case think I almost made the young girl cry at fastnel... Only been 3 weeks waiting... Front studs will be here tomorrow so ill get the hubs and brakes all back on...
Old 03-13-2013, 06:39 PM   #219
Pullin81
Pullin81's Avatar
Got a few odds and ends done the motor is tore apart as far as I'm going to go... Basically short block got it all cleaned up and sprayed black... Heads all tore apart gonna clean it up stick new valve seals in it and spray it... Then tweak the injection pump a bit and so on and so forth...pick away... Waiting to get a new proportioning valve and start doing brake lines get the plumbing in the frame done anyways... The diffs killed my bank account so I'm working with everything I have which will keep me busy for a while yet
Old 03-13-2013, 06:42 PM   #220
Pullin81
Pullin81's Avatar
Painted block... Little different to do being that I usually start with a bare block
Old 03-15-2013, 10:05 PM   #221
Pullin81
Pullin81's Avatar
Ended up getting the head all cleaned. up pulled the valves guides were good valves all still sealed nicely, deck was straight so I just cleaned the valves up put new seals in and reassembled... Valve covers n intake all sprayed ... Just waiting for the head studs to show up n clamp it back on
Old 03-22-2013, 11:34 PM   #222
Pullin81
Pullin81's Avatar
Got my rocker arm pedistals back from my buddy shop all machined down heads now clamped down with arp studs and valves are all set... Pans back on cleaned up and re sealed... Hopefully tomorrow her the tappet cover painted and put back on and start on the injection pump putting in the fuel plate and 3000gsk springs...
Old 03-24-2013, 08:03 PM   #223
Dieselwrencher
Fuel plate? Don't you have a VE engine? Looking good too!
Ryan
Old 03-24-2013, 08:09 PM   #224
Pullin81
Pullin81's Avatar
Engines back in the frame rails hope for the last time pumps all timed and brackets n linkage are all back on ... Just have to decide on sticks n a hair dryer..
Old 03-24-2013, 08:31 PM   #225
Dieselwrencher
Very nice! I know where you can get some sweet injectors!
Ryan
