Old 04-05-2011, 10:41 AM   #201
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods 52
I always made cups top and bottom. It was the best way to get it as low as possible by cutting the tubes as big as needed.
This is a 2000 Tahoe I bagged. I used DJM lower arms, and plated them.
This one is a All wheel drive SS Chevy Truck we did. This one was a real challenge.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-05-2011, 01:39 PM   #202
MrDude_1
Re: Daverods 52
If you're running plates on the LCAs, you bolt the bags directly to the plates.
If you're running stock or other coil spring LCAs, then you bolt the bags to cups. the cups act like the ends of the spring.
Looking at that plated LCA, you just need upper cups, and you would drill through the plate and bolt the bag directly to the lower plate. alot of S10 guys run a setup similar to what you've made there.
Personally on my truck I will be running tubular LCAs, that are also made with a plate to directly mount the bag. These are the ones I will be buying.
MrDude_1 is offline   Reply With Quote
Old 04-05-2011, 01:55 PM   #203
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
That's just a picture. I have'nt made it yet. I was just wondering if that is what I needed to do. Or if the cups just set in the spring pockets?
daverod is offline   Reply With Quote
Old 04-05-2011, 02:51 PM   #204
MrDude_1
Re: Daverods 52
well, it really depends on how low you want to go.
with upper and lower cups, you can only go so low on an "S10".
if you just mod the arm for the bag, you can go down until the "humps" on the arm hit the frame.
by "dehumping" the lower control arms and running a plate, or using aftermarket LCAs, you can go low enough to set the frame on the ground.
Old 04-05-2011, 05:40 PM   #205
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
It's always that last couple inches that's the pain. Guess we'll be dehumping. I knew I'd be welding today.
Old 04-05-2011, 07:12 PM   #206
MrDude_1
Re: Daverods 52
if you look at the "baggin it" section of S10forum.com you'll find all the info you need... just be warned, it IS a mini-trucker site. lol.
Old 04-05-2011, 11:07 PM   #207
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
One down.
Old 04-05-2011, 11:08 PM   #208
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
one to go.
Old 04-06-2011, 10:17 AM   #209
MrDude_1
Re: Daverods 52
nicely done.
Did you put anything under the plate?
when you go to cut the frame for the bag clearance, just take your time and make a nice smooth arc. From the work you've done so far, Im sure you'll cut it out nice and pretty.
Old 04-06-2011, 11:49 AM   #210
Strodder
Strodder's Avatar
Re: Daverods 52
With the upper cups I welded in a long stud that would go through the shock hole. It would keep the bag in place.With the lower I bolted the bottom of the bag to the plate, or lower cup. I've done many S-10's and they all laid frame. Not one failed air bad from rubbing, and waring a hole in the bag. Just make sure you cut away anything that can touch the bags. Also grind that cut smooth.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-06-2011, 01:58 PM   #211
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Originally Posted by MrDude_1 View Post
nicely done.
Now I have to cut my frame too.
Old 04-06-2011, 01:59 PM   #212
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
nicely done.
I'm goiong to put somthing under the plate, tonight.
Old 04-06-2011, 02:01 PM   #213
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Thanks Dennis. I picked up a zr2 rear end at lunch. 3.73 gears with a posi. Frickin thing was heavy. Good thing I'm old enough to be smart about lifting heavy stuff.
Old 04-06-2011, 02:54 PM   #214
MrDude_1
Re: Daverods 52
yup, you have to trim the spring cup area to clear the bags.
done properly, its no big deal. you can always put regular coil springs back in too (with diff LCAs obviously)
just dont hunk off a huge chunk like the kid did on the first frame I bought.
heres a recent thread on S10 forum with pics
Old 04-06-2011, 05:44 PM   #215
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Thanks Dude. Big help
Old 04-06-2011, 08:14 PM   #216
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Daverods 52
You can always weld up the area in green. No biggie, but thanks for that link. I was wondering myself!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-06-2011, 11:53 PM   #217
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
we'll call it frankinstein. Need to grind it all nice. Ran out of juice.
Old 04-09-2011, 05:26 PM   #218
ruffrida2005
Re: Daverods 52
Hey Dave when you get your link bars in I need some measurements. I pulled up to a stoplight today and the guy next to me had the same setup. He said it rode real nice with no twist.
Paul
Old 04-09-2011, 05:44 PM   #219
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Should be about a week.
Old 04-09-2011, 06:08 PM   #220
ruffrida2005
Re: Daverods 52
alright cool. I'm ready to get on the ball with mine. Will probably still be a couple weeks.
Theres a ZR2 rear here local to me for $150 on the evil bay
Paul
Old 04-09-2011, 08:50 PM   #221
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Thats a good price, Bet it's not a posi.
Old 04-10-2011, 12:17 AM   #222
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Worked on my bedsides. Put on a couple stake pockets. Removed the bottom bed piece.
Old 04-10-2011, 12:24 AM   #223
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Finished my lca's. Waiting for some bags.
Old 04-10-2011, 12:46 AM   #224
bubba327
HOW long until spring??
bubba327's Avatar
Re: Daverods 52
You are getting right with this project. it is looking good. Should be ready by Motorfest!!
I was looking at at a 49 cab today at the swap meet...... I wanta have one too.
But it was not a 5 window.
gotta finish the 64 first, if I can get it back from my daughter!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 04-10-2011, 12:57 AM   #225
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
That's funny I was thinking that you were out truck hunting today. Just buy one you need somthing to do. You can always add a couple windows. Thats my plan years down the road when I chop it. Doing pretty good for a project that's spost to be on hold, huh.
