#201 | |
Still plays with trucks
Re: Slick Copper's Build Thread
I'm not sure if it was an attempt at a PTO RPM control or something else. I have never seen any paperwork explaining it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#202 |
![]() Join Date: Aug 2010
Ok, so is that in the same location as my choke? I guess a lil different than a choke cable?
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
#203 |
Looks the same as the choke cable. My friends 67 has both the choke and throttle cables on the right side.
#204 | |
#205 |
I will see what I can do. It may take a while. I'll email him and see if he can take a pic of the dash for me.
#206 |
Cool!
#207 |
dont know if i ever told you but i took a pic of the original gas cap for a 67 and its in my thread.
#208 |
Oh yeah I did see it!
#209 |
SHEW!!!! Dang it's hot!!
![]() ![]() ![]() ![]() ![]() ![]() As far as what I actually got done was- Got my fan bolted back on w/new spacer, got my driver inner fender painted (no pics yet), got my ebrake handle, brake pedal and gas pedal arm painted, and got my transmission cooler lines bent and mostly in place. Finally got dark on me, so decided to give it up for the night. Here's some pics of the days activities for you picture nuts! ![]()
#210 |
Here's more. This is how my visor retainer/hooks were screwed in. Not exactly original. Also they're from a aqua colored interior truck. And I forgot that I cleaned up my gas pedal. Planning to get the stainless trim for it and the matching 72 style brake pad and trim.
#211 |
Glad you made some progress even in the heat.
I finally made some progress today in the heat too. It feels good to see some progress doesn't it. ![]()
#212 |
Sure does!
#213 |
Well it just started pouring!
#214 |
raymond thecab trim does look good you need 5 peices for the drivers side and 6 on the passenger. the beds are 3 peice front back middle , the pedals and rods look good. 67 could have the trim and rubber pad to just like the 72.we need pics of the inner fender! pop those holes out (i assume they bondo'd them) and get some clips and pp the trim on!
#215 | |
#216 |
So looks like on my th350 that's where the kickdown cable goes in at. It's just the plastic end peice on it, no cable. Guess I don't need it, tranny seems to shift fine without it. Guess I just need to figure out my leaking problem. Off to Auto Zone for tranny fluid and dipstick!
#217 | |
You really need to get a functional one on there. The base is hollow and will spew fluid out the middle if there is no cable on it any more. It will help get that pig moving a little better when you go to accelerate while cruising down the road too.
#218 |
Maybe I should get one then. That's probably where my leak is coming from. Do you know where I hook the other end up? I know on the carb, but where? Thanks!
I got my final coat of semi-gloss black on the driver inner fender and got my chrome dipstick installed. Also removed my other fender emblem. Waiting for my other set I won on Ebay to come in. Got a used set of bowtie 10 emblems and custom door emblems for $10 plus shipping! Gonna pick the best two outta the ones I got, paint the bowties in blue and shine the chrome. Also gonna do my grille emblem that way.
#219 |
NOS trim would be nice! sounds like a plan. i know what you mean. my dads truck has a 68 bed and a 70 cab and front clip, so when i popped out the bondo holes i realized after putting all the cab and front trim that, the back holes were to high and it was 68 so he has all the holes in his bed but no trim. i was saying pop out the hole for the trim peice you have and not any others and when you get another trim peice just pop the holes out for that. so it would be either trim or a smooth body panel with no holes, until you got the trim for it.
#220 |
Here's a couple pics. My painted inner fender (driver side) and I took off the driver side fender emblem. It fell right off. Never even had the nuts on the back of it! No tape or anything! Good thing I went to take it off, could've lost it going down the road.
#221 |
Well, Rick figured I'd just wait till I get a whole set and put it all on at once. Figure it'll look kinda funny with that one peice on the cab!
#222 |
haha your probably right!
#223 |
Grandpa in the rustmobile...
Keep us updated how you 'restore' your emblems I should do it too
be careful popin the trim clips off I wouldnt wanna mess up that (pretty nice) paint
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#224 |
Post a pic of the throttle linkage side of your carb and we will see if it has the right one on there to work and point you to the right place to make the kickdown connection.
#225 | |
