Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 09-12-2011, 11:44 PM   #201
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Post your best budget mods! ($50 or less)
Need to think/remember about the door seals...good idea guys
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 09-13-2011, 12:47 AM   #202
BrianV
BrianV's Avatar
subscribing - love this thread
BrianV is offline
Old 09-16-2011, 09:35 PM   #203
soxplayer
Get a distributor re-curve kit and experiment. Really helped the torque and mileage on a 250 six. Kit was for a V8 but the springs worked fine.
soxplayer is offline
Old 09-20-2011, 12:19 AM   #204
vectorit
What?
vectorit's Avatar
I thought this was handy.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 09-22-2011, 03:53 PM   #205
daily'68
I could never see my climate controls when driving at night. So i bought a led light strip (under $10) and trimed off a group of 3 lights...spliced into my dash lights and stuck it to the bottom of the ashtray...closed the ashtray, turned on headlights and works great! Actually a little too bright at first, had to cover 2 of the lights with elect tape...perfect now. It even illuminates my console cup holder in the floor board. I'm thinking about using the rest and mount under the seat for some more floor board illumination. Anyway, cool trick thought id share.
daily'68 is offline
Old 09-22-2011, 06:17 PM   #206
8door
Not too old to learn
That is a ahem... "brilliant" idea.
1968 C10 a way to long restoration.
8door is offline
Old 09-22-2011, 06:31 PM   #207
Andy4639
Old member
Andy4639's Avatar
Question Re: Post your best budget mods! ($50 or less)
Can you explain how you tied into the LED's?
That may be something I need to do latter on.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 09-22-2011, 06:39 PM   #208
Southcity
Southcity's Avatar
Cool idea and looks good but I was curious to know if your stock climate control bulb is out, not hooked up or just don't have one?
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline
Old 10-07-2011, 07:14 PM   #209
iceship
Has anyons done the camaro gauge mod... I'm looking for the HOW TO for it
iceship is offline
Old 10-08-2011, 08:09 AM   #210
MacGyver72
MacGyver72's Avatar
I have some repair tips that aren't mods but they'll get you home if you need to. I've already seen the photo of pantyhose used for a belt and I can tell you from personal experience that works. Here are some others.
Aluminum foil dipped in coke will remove surface rust from chrome and make it look new.
WD-40 wiped on seals will help them last longer.
A matchbook is the correct thickness to set point gap.
A number one paper clip (most common) is the correct spark plug gap.
800 grit sandpaper will make wipers clean better.
A papermate pen (once the guts are removed) makes a very good hose splice.
Pepper or an egg white will temporarily seal a radiator leak.
Aluminum foil can be used to improve an loose electrical fitting.
WD-40 can be used to reseal the bead of a tire that is off the rim.
And finally you can weld a broken shift linkage on the side of the road with jumper cables and a penny. (Got me my nickname)
MacGyver72 is offline
Old 10-08-2011, 01:31 PM   #211
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Using the penny like an electrode?
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 10-08-2011, 01:42 PM   #212
kikkegek
kikkegek's Avatar
DIY fan shroud guide. Must be under $50,- didnt check that though!
http://www.cadvision.com/blanchas/54...FanShroud.html
kikkegek is offline
Old 10-10-2011, 11:16 AM   #213
MacGyver72
MacGyver72's Avatar
Hello Scott. Yes, if you ground the item to weld then grab the penny with the positive lead, you can create an arc using a battery and weld. at least enough to get you back on the road.
Old 10-13-2011, 01:38 PM   #214
chilihed
How 'bout a $20 electric windshield washer pump so you get a nice even consistent spray. Especially nice in the winter. Simply install a bulkhead fitting on the bottom of your reservoir, mount the pump below that. Then you only need to rerout the washer fluid lines and run the hot lead from your switch to the pump, and ground the other lead.
chilihed is offline
Old 10-14-2011, 01:08 PM   #215
camrycurt
camrycurt's Avatar
I definitely want to do this swap, but when wiring up the new pump do you wire the hot or ground wire through the stock switch?
I thought the switch in the dash controlled the ground wire so was planning on running the ground from the new pump through the switch. Is that not correct?
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline
Old 10-14-2011, 03:51 PM   #216
chilihed
I don't recall off the top of my head. I just ran both wires from the old pump all the way up to the new pump.
chilihed is offline
Old 01-03-2012, 01:44 AM   #217
cjohnson6772
cjohnson6772's Avatar
bump
cjohnson6772 is offline
Old 01-03-2012, 05:43 AM   #218
19Hoosierdaddies68
Cool tricks and ideas, subscribed!
19Hoosierdaddies68 is offline
Old 01-03-2012, 07:57 PM   #219
cst69
Hollywood
cst69's Avatar
How about using black shoe polish on black plastic to bring the color back to new or weatherstipping
1968 cSSt shortbed
1971 custom deluxe shortbed frame off
1991 caddilac escalade ST shortbed
1992 chevy ext. cab Project: leftovers
2003 Silverado ext. cab shortbed (my dad's truck R.I.P.)
1969 trans am clone, pro tour
1985 Yamaha Vmax, custom
1993 Yamaha Vmax, showbike
1969 Sears Suburban SS12 lawn tractor
cst69 is offline
Old 01-03-2012, 09:07 PM   #220
big_al_71
big_al_71's Avatar
underdash lights from painless...
http://www.summitracing.com/parts/PRF-30702/
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 01-03-2012, 09:14 PM   #221
BMERDOC
BMERDOC's Avatar
How about the Jeep door checks. I heard about them working in the 60-66s but couldn't get confirmation about wether they work in my 67 or not. I heard $8 per in a JY?
http://67-72chevytrucks.com/vboard/s...d.php?t=446066
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline
Old 01-04-2012, 08:03 PM   #222
BIGKEV
Originally Posted by 70BLAZERX2 View Post
It had a totally different power curve in it..for the vette camshaft.
It dont hurt to ask..
It will wake up even a 86 stock 305 in a 4x4...make it pull like a 350...Yes it does work..and its cheap.
This short read will shed a whole lot of light on the subject!
http://outintheshop.com/faq/Vac%20Adv%20Spec.pdf
BIGKEV is offline
Old 01-04-2012, 10:00 PM   #223
hugger6933
For those of you that kinda know me or of me would'nt be suprised to find out that this a bodyshop cheapee. Take an old coffee maker out to the shop plug it in fill'er up in about five min. you are ready to wetsand with warm water. It is very usefull in the winter months and I tryed it not long ago thinking why have I not done this sooner. Wetsanding is a miserable enough as it is without having to dip your hand in freezing water! cost on this tip $00 if you have an okd one but even if you don't and need to do this 20 bucks at a dollar store will put you in bussiness
hugger6933 is offline
Old 01-04-2012, 10:10 PM   #224
mrhino
Originally Posted by hugger6933 View Post
for those of you that kinda know me or of me would'nt be suprised to find out that this a bodyshop cheapee. Take an old coffee maker out to the shop plug it in fill'er up in about five min. You are ready to wetsand with warm water. It is very usefull in the winter months and i tryed it not long ago thinking why have i not done this sooner. Wetsanding is a miserable enough as it is without having to dip your hand in freezing water! Cost on this tip $00 if you have an okd one but even if you don't and need to do this 20 bucks at a dollar store will put you in bussiness
nice!
mrhino is offline
Old 01-04-2012, 10:35 PM   #225
stfinney
stfinney's Avatar
When painting the dash cluster, what do you do about the lettering and numbers?
stfinney is offline
