Old 10-21-2012, 11:02 PM   #201
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Originally Posted by GMCJOE View Post
How much you charge to build a fuel tank like that?...lol I am not sure if I am joking or not, but I am sure the killer would be shipping on something like that..lol Looks awesome.
Thanks!
i'm not sure what i would charge. i would have to get an accurate cost of materials. based on that i could give a better estimate. i have no idea what it would cost to ship. probably ~120 freight. based on shipping of similar sized stuff in the past. that could be way off though!
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 10-22-2012, 03:44 AM   #202
tsnow678
Re: 72 k20 project
Look into a product named Red-Kote for the inside of tank. I used it on my modded 69 Camaro gas tank for about a year without any issues. The ethanol in todays fuels will cause the Red-Kote to lose it's pigment but not it's protection. I had the local radiator shop line it for about $40. They even brazed in a drain into the tank.
Link to my 69 Camaro 6.0/T56 swap:
http://ls1tech.com/forums/conversion...69-camaro.html
tsnow678 is offline   Reply With Quote
Old 10-22-2012, 07:55 AM   #203
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Will do. Thanks!
72 K20 12v build
Old 10-22-2012, 02:31 PM   #204
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Nice work on the tank! If it is stainless, I don't know if I'd coat it. Did you leave the baffles solid like that? The tanks looks sweet though! Loving your welds!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-22-2012, 08:12 PM   #205
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks!
its P&O steel. that is the only reason i want to coat it. after pricing the coatings i am not to sure i shouldnt have made it out of 304. oh well. i feel sacrilegious painting SS and i didnt want the "bling".
the baffles are solid, but do not extend into the lower sump area. should keep sloshing to a minimum.
72 K20 12v build
Old 10-22-2012, 08:28 PM   #206
Dieselwrencher
Re: 72 k20 project
Yeah, it'll keep sloshing to a minimum for sure. I hope it isn't a bit much. Do you have a local rad. repair shop? They usually coat fuel tanks as well.
Ryan
Old 10-22-2012, 09:15 PM   #207
ryanroo
ryanroo's Avatar
Re: 72 k20 project
ive thought about the rad shop. the local guys here are real hokey, and very proud of that... i think ill be better off doing it myself.
IMO the only way to over baffle is to totally seal the compartments off. as long as the fuel can transfer between the compartments as fast as you can fill it, its not to much. the draw tube is .5" so there is no chance of starving the engine. we build tanks with some regularity, and ive repaired enough tanks made by others to have learned that the single biggest problem is lack of baffling. the slosh of fuel fatigues the ends of the tank and will crack the welds over time. that is the main reason i welded inside at the bottom and up the sides. it is a stronger joint and reduces that chance of fatigue a bit. leaks make me angry...
Ryan
72 K20 12v build
Old 10-22-2012, 09:42 PM   #208
RatRod68
RatRod68's Avatar
Re: 72 k20 project
on here too eh? I guess I will follow this build on both forums!
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 10-22-2012, 11:07 PM   #209
ryanroo
ryanroo's Avatar
Re: 72 k20 project
This is the original build thread, so it has a few more pics of the early stages. after i started the pirate thread they are pretty much the same
Ryan
72 K20 12v build
Old 10-24-2012, 07:08 AM   #210
RatRod68
RatRod68's Avatar
Re: 72 k20 project
Schweet!
This is a very similar build i will be taking with my 1 ton, so I am definitely glad i found it over here
build Threads:
Leftovers 68 C20
Semper Fi
Old 10-25-2012, 05:33 AM   #211
72KAY20
72KAY20's Avatar
Re: 72 k20 project
Very nice job on the tank Ryan. Love the attention to detail on your build! Looking awesome!!!
72Kay20 Bel Air, MD
1972 Hugger Orange K20 LWB
350, 4wd, 4spd Sm465, Dana 44, HO52
Other Toys
69 Cortez Silver Z28
86 White Buick T Type
72KAY20 is offline   Reply With Quote
Old 11-03-2012, 11:20 PM   #212
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks!
i did a little bit of repair on that giant hole i hacked into the firewall
i'm no sheet metal guy so this is not going to be one of those jaw dropping OMG things.
72 K20 12v build
Old 11-03-2012, 11:29 PM   #213
VA72C10
VA72C10
VA72C10's Avatar
Re: 72 k20 project
Looks good to me!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-04-2012, 03:16 AM   #214
birdistheword
birdistheword's Avatar
Re: 72 k20 project
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 11-05-2012, 04:49 PM   #215
Dieselwrencher
Re: 72 k20 project
Looks good. I hear you on not being a sheet metal guy. My stuff takes 3 tries to look like their work. Are you planning on running vintage air to be able to clear the fire wall now?
Ryan
Old 11-05-2012, 09:29 PM   #216
ryanroo
ryanroo's Avatar
Re: 72 k20 project
yeah, there are a few trials that are not pictured. haha
i was always planning on vintage air. the stock stuff is to bulky for me. i have this spatial issue. i really like uncluttered space and that stock box takes up to much of my space. i know, i'm a wierdo. i wont even park in my garage when i have space, simply to have a wide open space...
Ryan
72 K20 12v build
Old 11-05-2012, 10:06 PM   #217
Dieselwrencher
Re: 72 k20 project
I can relate to how bulky that dang A/C stuff is. Cough cough
Ryan
Old 11-06-2012, 08:52 AM   #218
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Haha, i remain impressed that you used it and got two turbos mounted in there.
i have some plans for that area rolling around in my head and using the stock heater/a/c stuff would totally ruin my plans.... it may still not work but i have a chance.
Ryan
72 K20 12v build
Old 11-06-2012, 03:55 PM   #219
Dieselwrencher
Re: 72 k20 project
I've thought about ditching the stock a/c heater housing on the next cab, but if I go that route, that cab and project will have to wait. If anything is getting vintage air it is my 40.
Ryan
Old 11-06-2012, 05:48 PM   #220
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
Man, I am loving this build!!!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-14-2012, 10:00 PM   #221
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks!
i tacked this up. hopefully will get it located and affixed this later this week or this weekend. i have also made and remade the tank straps, so i will hopefully get the final revision completed this weekend.
ryan
72 K20 12v build
Old 11-14-2012, 10:06 PM   #222
mosesburb
I had a V-8
mosesburb's Avatar
Re: 72 k20 project
Nice. Where is it going to live on the truck??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 11-14-2012, 11:51 PM   #223
ryanroo
ryanroo's Avatar
Re: 72 k20 project
on the drivers side framerail inside the frame. under the front of the bed and rear of the cab.
ryan
72 K20 12v build
Old 11-15-2012, 03:06 PM   #224
Dieselwrencher
Re: 72 k20 project
Nice! I need a water jet or plasma table. Problem is, Obama isn't helping this SOB out.
Ryan
Old 11-15-2012, 03:46 PM   #225
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
You mean he hasn't even given you a free phone?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
