Old 02-08-2012, 02:32 PM   #201
tylervalo
Re: 86 squarebody made2drag
What color is your truck?
tylervalo is offline   Reply With Quote
Old 02-08-2012, 05:22 PM   #202
Leedogg
Just read through this thread- Nice job! Any plans to SFBD?
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 02-08-2012, 06:06 PM   #203
made2drag
made2drag's Avatar
tan-ish, i guess.
made2drag is offline   Reply With Quote
Old 02-08-2012, 06:07 PM   #204
tylervalo
Do you have the paint code by chance?
Old 02-08-2012, 06:10 PM   #205
made2drag
made2drag's Avatar
no plans to stock floor it or traditional bd. i hope it lays frame in the rear and may lay crossmember in front. still have an inch or inch and a half in the front. not sure if im going to put drop spindles on it or mod the lca's a little. i kind of like riding aired out right now. but im sure i'll want to go lower after i get the bed on and valves installed.
Old 02-08-2012, 06:11 PM   #206
made2drag
made2drag's Avatar
when i get home i'll look on my spid and let you know
Old 02-08-2012, 06:16 PM   #207
made2drag
made2drag's Avatar
i see your in AL...let me know if you know of any truck shows coming up...and do you have a build thread on your bagged 4 door?
Old 02-08-2012, 10:11 PM   #208
mcboomport
mcboomport's Avatar
Originally Posted by made2drag View Post
cool! glad you got everything. make sure you get a stepper bit. it will make it a lot easier to drill the holes for your upper bag plates. remember to use a spring compressor.....dont do the jack-on-the-lca trick. if you get in a bind like its under the lca and you cant move the jack how you want it....you're screwed! last tip......spray some penetrating spray on all the bolts a day before. bagging the front is time consuming but worth it in the end. cant wait to see your build! take lots of pics.
ps. i wish i could take credit for the welds....lol
Ive always used the jack method on these truck. You won't have a problem. Just make sure your frame is on jack stands as high as you can safely go. A typical jack stand is fine. Ps, your truck is looking great.
mcboomport is offline   Reply With Quote
Old 02-09-2012, 10:12 AM   #209
made2drag
made2drag's Avatar
"161u 61 doeskin tan solid"
and it says "1zyl solid color" on the line above it
interior is "xss1 saddle tan custom"
i have a touch up bottle that is labeled GM 61.....could be from autozone
Old 02-09-2012, 10:27 AM   #210
made2drag
made2drag's Avatar
ive done it on a 85 s10 blazer about 10 years ago. i attached a chain and lock around the springs and lca to make sure if something slipped i wouldnt be in the hospital. it felt like an unpredictable mouse trap to me. lol. due to the questions he was asking it seems like it is his first time lowering anything, i think he should use the safest method....especially on a burban....but you're right the jack method works too
Old 02-09-2012, 10:40 AM   #211
made2drag
made2drag's Avatar
Old 02-09-2012, 10:43 AM   #212
made2drag
made2drag's Avatar
huge difference of clearance now between the c notch and the step notch. the paint can is to give you an idea of the space now...we all know how tall they are....i still need to box the insides and clean up the sawall cuts where i chopped the old frame out....maybe this weekend or middle of next week
Old 02-09-2012, 12:52 PM   #213
stepside83
stepside83's Avatar
Notches look good can't wai to see more, keep up the good work, and lots of pictures please.
stepside83 is offline   Reply With Quote
Old 02-10-2012, 02:06 AM   #214
franky69c10
chevy runs deep
franky69c10's Avatar
Looking good bro
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 02-10-2012, 10:21 AM   #215
91Subbed
Yeah I've never bagged anything! But I think after all the tips you've given me, I got this! Lol...I just needed some insider tips.
Notches look good! My spindles should be here today and I'm gonna start my build this weekend! It supposed to be pretty cold here in Arlington though, it's gonna be a cold garage! I'll keep you posted!
91Subbed is offline   Reply With Quote
Old 02-10-2012, 03:08 PM   #216
made2drag
made2drag's Avatar
cool man....cant wait
Old 02-18-2012, 11:35 AM   #217
made2drag
made2drag's Avatar
made some lowering blocks. i made one side longer to help flatten out the leaf spring on the shackle's side. and after i get tired of leaf springs...if i do that is...i can weld these to some 2x2 bar and mount the other ends to the front leaf spring hangers and add some bag mounts.
i would be like the 2 link ekstensive makes...in the end i'll likely have basically the same thing.
Old 02-18-2012, 11:37 AM   #218
made2drag
made2drag's Avatar
the round edges on the 2x3 and the flip edges were fun to weld! not the greatest but i dont think i'll have to worry about them coming apart....i filled a rather large gap.
Old 02-18-2012, 11:39 AM   #219
made2drag
made2drag's Avatar
i have 1 side in and working on the other side....not much time today to work on it though. maybe it will be done tommorrow
Old 02-18-2012, 11:40 AM   #220
made2drag
made2drag's Avatar
its still on jack stands right now
Old 02-19-2012, 03:59 PM   #221
made2drag
made2drag's Avatar
have both sides done now and had to notch out the crossmember. i used a piece of 2x3. i will have to notch a little out of the crossmember that is attached under the bed. no big deal though because that crossmember is around 4 inches tall. next up is to figure out shock mounting and putting in a 2 x 4 cross brace and bag mounts...i would like to also do the hidden hitch so when i get the sport bumper i can flip my tag down and hook up. i only need to use a trailer every couple of years or so...may or may not do that since its not really a priority
Old 02-19-2012, 04:12 PM   #222
KatFish
You can take a regular Reese hitch an make it into a hidden hitch fairly easily. I'm going to be doing one for my buddies suburban soon so I'll post pictures of the process.
Trucks looking good by the way.
KatFish is offline   Reply With Quote
Old 02-19-2012, 05:16 PM   #223
stepside83
stepside83's Avatar
Looking good bud, I can't wait to get started on mine
Old 02-19-2012, 08:02 PM   #224
made2drag
made2drag's Avatar
cool, im very interested in doing that. so your saying buy a reese hitch and weld it to a piece of 3x3 or something?
Old 02-19-2012, 08:03 PM   #225
made2drag
made2drag's Avatar
it wont be long and you'll be bagged
