Old 12-10-2013, 01:02 PM   #201
piratexpress1369a
piratexpress1369a's Avatar
Re: 1965 Suburban Resto-Rebuild
did you check out that link i sent you for the gas shocks
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 12-12-2013, 12:51 AM   #202
hemifalcon
Pirate.. Yeah buddy--I checked it out.. I have the original pieces measured and will likely use the gas shocks when it all goes back together.. Thank you..
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 12-12-2013, 12:55 AM   #203
hemifalcon
So--yesterday I finally ventured down to the newly opened Harbor Freight only about 15 minutes away and picked up the mini-needle scaler.. And the pneumatic scraper.. I figured for the price charged for the tools, they would be well worth their cost if they worked and lasted to the end of this job..
well--I am VERY pleased with the performance of both.. Just a breeze using both tools in removal of the rubber undercoating material from the firewall area. The needle scaler is awesome.. Here's the results prior to sanding.. I will spend quite a bit of time working on the underside to get the undercoating from the bottom of the body... Gotta do it..
On all the irregular surfaces the scaler was very easy and user friendly.
Old 12-12-2013, 01:53 AM   #204
McMurphy
McMurphy's Avatar
That needle scaler is good for getting gunk out of hard to get into nooks and crannies too !
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 12-13-2013, 12:34 AM   #205
piratexpress1369a
hemifalcon does your barn doors open from the inside? my 63 does not but i was thinking about a way to be open the door from the inside ..what are your thoughs?
63
Old 12-23-2013, 01:52 AM   #206
hemifalcon
Pirate:
No they don't. The door handle/button on the outside needs to release the passenger door first, then the latch for the driver's side door can be opened with its own release.
Old 12-23-2013, 01:56 AM   #207
hemifalcon
So--after working 12 days straight--I finally got back under the burb today. I spent about 2 hours needle-scaling and scraping undercoating and the burb. I have a long way to go--
pass side mostly done
center view showing untouched drivers bottom.
Old 12-23-2013, 08:22 AM   #208
bj383ss
bj383ss's Avatar
About to be doing the same thing. I will have to pickup one of those scalers.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 12-24-2013, 10:47 PM   #209
hemifalcon
Here we go a little deeper--I yanked the rear floor section out tonight. I'm almost done with removing all the undercoating and I think the wheel wells will be the biggest pain as it's really thick and stuck on pretty good. Oh well--just letting the air scaler do it's job. I only ended up breaking two bolts during removal of the rear floor--but decided to finally do it. I will now have to wrestle with the idea of installing a "truck-style" rear floor--or if I'll do the plywood again. If I do the plywood--I'll have to source similar style rubber coating--shouldn't be too difficult. Or--maybe carpet?? Likely rubber.. ORRRRRR--maybe put some nice stainless runners atop the plywood or a raised protective surface?? I dunno--we shall see. Either way-having the floor out makes clean up very easy..
Here are the pics--
someone really hammered the hell out of the inner parts of the wheel houses.. I don't know why--
you can see the two halves of plywood-measured out at 5/8" thick. The rubber top almost seems like it had a layer of asphalt between it and the wood--it does NOT peel off.
rear lip detail.
Old 12-25-2013, 12:06 PM   #210
piratexpress1369a
are you going to put new plywood in or go steel floor ...i have the wood floor in mine but not sure what i was going to do with it
63
Old 12-25-2013, 12:50 PM   #211
hemifalcon
Tossing ideas around for a little bit. Besides--every time I think I have this thing figured out and the "next step" planned--something else comes up. After wrapping up all my undercoating I think I will paint the interior. Then--put the floor back in. When that time comes I will hopefully have a plan figured out on what I want to do with it. Floor will definitely be wood--not sure what route I'm going to take yet.
Old 12-26-2013, 12:21 PM   #212
piratexpress1369a
i understand that ..no matter which way you go it will work out the best
63
Old 01-01-2014, 02:16 PM   #213
hemifalcon
Happy New Year guys and ladies..
SO--here's what happens when you spend 2-3 hours removing undercoating.. One more wheel well to go and I can get some paint on the underside. I opted to buy the 3M Schutz undercoating--so that will be going on in the next week or two (can't wait to make THAT mess..)
I knocked the dents out of the passenger wheel well--and found some rust on the rear edge of the inner flange.. I'll now have to fix that.. My girlfriend also put a hammer and dolly in her hand for the first time.
Old 01-01-2014, 07:59 PM   #214
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Wow!
Glad that I am done with that stuff!
Nice job, I love those 'burbs! I had one in high-school!
Modges'66 is offline   Reply With Quote
Old 01-02-2014, 02:40 AM   #215
piratexpress1369a
wow that is really clean ..yes mine were that clean lol..nice job
63
Old 01-09-2014, 12:46 AM   #216
hemifalcon
Okay... Before I give up on the idea of the truck-bed style of floor--I need to give it a shot..
If anyone has some shortbed or longbed bed strips--I would like to buy them. They don't have to be pretty--just solid and straight.. I'll worry about pretty ones later.
pm me if you have any that you're wanting to part with..
If so--Quote me also on a price for shipping to 60002!
Old 01-09-2014, 12:16 PM   #217
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Yeah I know exactly what it is like to have your face dusted over. lol! Nice work so far!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-29-2014, 01:20 PM   #218
hemifalcon
Finally did a little work on some small stuff on the burb. I cleaned up all the rubber roof gasket which goes between the roof supports and roof skin.. They had black spray paint and gunk on them from a previous owners wise idea of using a rattle can recklessly..
Then-started assembling the slider windows.. I had purchased a different set from forum user that had been half-ass repaired--so I re-did them again.. I had them powdercoated black and they kept staring at me.. So-I cleaned up the glass panels and started the job.. Only thing I'm thinking is to buy the better exterior seals from Steel Rubber. Damn they're expensive.. So--here are some photos.. (not really fun stuff..)
Those are standard 9/16" Arrow staples which were re-shaped and pushed through the fuzzy's.. Squished in and folded over. Worked pretty danged well.
The angled end of he fuzz was fixed-they were tweaked from shipping.
Glass slides very nicely with a good tight fit. NO more silicon crap to hold it together.
I found a guy on the auction site who sold me a single slider latch for $70/shipped.. Hoping to get it later this week--supposedly just has scratch on it--but I figure I can re-finish it and use the lift portion for my latch.
Old 01-29-2014, 02:08 PM   #219
Low Elco
Great work on a cleeeeean truck!
Low Elco is offline   Reply With Quote
Old 03-09-2014, 11:05 PM   #220
hemifalcon
Okay..
One small but PITA hurdle jumped.. Between lots of little other projects--I finally got this done. I also finally got my metal bed slats from California for mockup of the rear wooden floor..
Here's the shiny black paint with silicon rubber at all the seams spread in..
And...here it is with the 3M Schutz sprayed on.. I am very happy with how this turned out. The instructions for the stuff said to spray between 40-60psi--I liked it best at 45psi and it sprayed on very nicely.. I like the texture and appearance. Took a full gallon to cover the bottom--and I could have gone with another 1/2 gallon to make it nice and thick--but I'm not unpleased.. Nice stuff..
Old 03-09-2014, 11:30 PM   #221
likaroc13
Rollin' Old Skool
That looks nice! PITA, but should be worth it in the long run.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 03-10-2014, 12:22 AM   #222
hemifalcon
No kidding---I keep setting goals for the project and looking toward putting the body back on the chassis... Going to just do one project at a time.. Rear floor is next before paint on interior and probably a dark grey Herculiner on the floor--
Oh yeah--I've grabbed some upholstery samples recently---;-)
Old 03-10-2014, 09:33 AM   #223
piratexpress1369a
looks great ..are you going to use plywood floor?
63
Old 03-10-2014, 09:41 AM   #224
1963c-10
1963c-10's Avatar
Nice job on the floor...came out great
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-10-2014, 10:17 AM   #225
hemifalcon
No plywood... It's going to be individual planks
Thank you--still a long way to go
