03-17-2013, 08:09 PM | #201 |
Re: project: 3/4 ton dropped
in the back I ended up just removing the stock u-bolts, and just put the rear axle on top of the springs. then I bought the weld on axle perches from http://www.performanceonline.com/196...-PAIR-RAS6787/ and welded them to the axle. my truck was from Nevada so I used my original u-bolts. everything worked out good, but you have to make sure you keep the axle the exact same angle as before. otherwise it will vibrate like crazy. if you don't like welding or don't have one, I recommend these clamp on perches. http://www.summitracing.com/parts/aaf-all56127
for shocks I didn't get any yet but don't think it will be a problem finding some.
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
03-17-2013, 08:34 PM | #202 |
Well my truck was a california truck so I think I can do like you did. So I guess the thing to do would be to do one side at a time so the axle angle doesnt change? I have a welder.
So are you running no shocks right now? Posted via Mobile Device |
03-17-2013, 08:34 PM | #203 |
Oh yeah and where did you buy the c notch kit from? Wanna make sure it fits
03-18-2013, 12:25 AM | #204 |
i bought the c-notch kit from performance online, the same link you posted. the only problem i had with them was that they sent me 2 of the same side. so i just cut one off and said good enough. lol As for shocks, my truck is still a work in progress so i never drove it yet. to get the axle on the same angle, just put the perches parallel to the original ones already welded to the axle. then measure the distance between them in the front of the axle tube and the distance between them in the back of the axle tube. then just tack weld them in place incase you have to move them. then take the leafs and put them under the axle and reassemble. take it down the road to see if it vibrates. let me know if that makes any sense or not. haha
03-18-2013, 12:31 AM | #205 | |
03-18-2013, 07:55 AM | #206 |
ok, great. One more thing I forgot to mention, if I remember right, their wont be any alignment pins on the top of the leafs, so you have to measure from the front of the leaf spring perch to the axle on both sides. So the axle is aligned correctly.
03-18-2013, 08:07 AM | #207 | |
04-02-2013, 11:15 PM | #208 |
well I decided to rip apart my motor, and found some interesting things. First off I found out the previous owner went through the motor and rebuilt it back in 2002. Also, my motor knocked a little bit before I tore it apart, which I found out was the rod caps were loose! Bearings and pistons were pretty scored up. I'll get some pictures up soon.
04-03-2013, 02:50 AM | #209 |
Your truck is looking good . You said you got your tail lights and I was wondering where they hard to instal .
04-03-2013, 08:01 AM | #210 |
To install taillights, there is 4 torques screws on the lens, and that pops off. Then there should be 4 more normal Phillips screw holding the backing piece on. Take the screws out and that will come off. After you pull it out a little, you will have to take the bulb plug-ins off the plastic backing part. Just give them each a quarter/ half turn and pull outwards. than all your left with its your wire harness hanging. Just let me know if something doesn't make sense.
04-03-2013, 01:30 PM | #211 |
It all make sense . I just wanted to know if you bought new tail lights and had a problem installing them because they dont fit right . I bought a pair of tail lights from LMC and the dont fit right .
04-04-2013, 10:08 AM | #212 | |
04-04-2013, 08:55 PM | #213 | |
04-04-2013, 09:24 PM | #214 |
here's some engine pictures
04-11-2013, 10:24 AM | #215 |
Did you get your carpet squared away? i order from stockinteriors.com acc carpet for a good price. They give you extra so that you can trim to fit.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
06-13-2013, 10:11 PM | #216 |
I sent my carpet back and never looked for another one yet. I ended up putting the engine in a bag in the corner. I got the rest of the panels done and painted. im going to get everything fitted and then get the interior all complete. I got all my weather-stripping seals brand new for $25. couldn't pass it up... Front and rear windows I installed last month. ill get some pics up soon
06-13-2013, 10:18 PM | #217 |
06-13-2013, 10:21 PM | #218 |
oh and i also found a seat that was completely recovered with new foam and all insides for $30. i died it black and threw it in the cab. looks like new!! ill post pics from my computer so they are straight.
06-14-2013, 12:38 AM | #219 |
Been waiting for updates! Need more pics!
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
06-19-2013, 10:03 AM | #220 |
Any new pictures yet. Looking great man
SOLD 1978 GMC Sierra Grande "Slow Budget Build" 1969 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=440536 |
06-20-2013, 12:28 AM | #221 |
I had to take my door back because they screwed up on the paint for the 3rd time. ill post a pic of the paint that lifted on the cab seam. missed paint on the rocker panel and now the door...not to happy with them. this weekend I hope to get everything fitted if I get the door back by then. I started restoring my vent windows, and I reassemble the one door. I put a pic up of my seat that I scored from a guy in my area and dyed it black. that's about it for now...enjoy the pics!
06-20-2013, 12:41 AM | #222 |
pics
06-20-2013, 12:52 AM | #223 |
more
06-20-2013, 05:46 AM | #224 |
67-72 parts collector,…
Looking GOOD!!!
06-20-2013, 05:43 PM | #225 |
I love the color and I am very jealous of that seat!
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
