Old 06-17-2016, 08:32 PM   #201
murd969
Re: 1956 Chevy 3100 Corvette Suspension
The top pic is fully laid out and the bottom is the ride height. Should be pretty awesome.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 06-17-2016, 09:39 PM   #202
murd969
Making some more progress. Working to get the inside of the bed smoothed out.
Instagram: murd969
Old 06-18-2016, 05:19 AM   #203
RockinKees
RockinKees's Avatar
All is looking great!
You nailed it it on the rideheight, very nice stance!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 06-18-2016, 08:45 AM   #204
Kim57
Kim57's Avatar
Real nice stance.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-20-2016, 09:55 PM   #205
murd969
Working on getting the motor set correctly. We're going to have to adjust the motor mounts to raise the motor some. Everything is definitely a tight fit in this truck. The motor does look pretty damn good in it.
Instagram: murd969
Old 06-21-2016, 11:21 AM   #206
Kim57
Kim57's Avatar
Looks good.
Orange headers look good (I know it's just tape).
Kim
My build thread
Old 06-24-2016, 06:35 PM   #207
murd969
We had to modify the transmission cover because it was hitting it. Looks pretty good now.
Instagram: murd969
Old 06-24-2016, 06:41 PM   #208
murd969
We also got the tailgate on with the hidden latches and the stainless arms instead of using the chains. It's been a while since I've seen a tailgate on this truck.
Instagram: murd969
Old 06-24-2016, 06:41 PM   #209
murd969
Here's another view.
Instagram: murd969
Old 06-24-2016, 06:44 PM   #210
murd969
We also had to redo the motor mints. The motor needed to come up some plus they needed to be stronger.
Instagram: murd969
Old 06-24-2016, 07:07 PM   #211
Kim57
Kim57's Avatar
Looking good.
Tail gate looks real clean.
Kim
My build thread
Old 06-25-2016, 09:57 PM   #212
murd969
Had to redo part of the floor. There were just too many holes and issues with the panel so we just replaced it.
Instagram: murd969
Old 06-25-2016, 09:59 PM   #213
murd969
Apparently the other shop didn't get the seat centered so we had to redo the seat mounts. We should be good to go from here.
Instagram: murd969
Old 06-25-2016, 10:30 PM   #214
dug224
dug224's Avatar
Beautiful engine! Enjoyed catching up on your build. Good luck with the new shop. dug
dug224 is offline   Reply With Quote
Old 06-25-2016, 10:34 PM   #215
murd969
Thanks for the comments dug. The new shop has been great. It's been a completely different experience. The work is moving along quickly.
Instagram: murd969
Old 06-28-2016, 07:52 PM   #216
murd969
We got an actuator hooked up to lift the bed floor but we're not sure if we're going to use one in the middle or one on each side.
Instagram: murd969
Old 06-30-2016, 08:22 PM   #217
murd969
We got all of the body parts in and now we're getting ready to knock out the gals and get going on the body work.
Instagram: murd969
Old 06-30-2016, 11:36 PM   #218
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 07-02-2016, 10:16 AM   #219
tiddlar
Looks very nice. are you going to extend the fenders to be closer to the ground when laid out?
Purgatorio
tiddlar is offline   Reply With Quote
Old 07-13-2016, 11:29 PM   #220
murd969
We got the bed sides sandblasted and etch primed the other day. Other body work is going on as well.
Instagram: murd969
Old 07-14-2016, 11:04 AM   #221
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
Old 07-14-2016, 04:56 PM   #222
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Slick!
ChuckDriver is offline   Reply With Quote
Old 07-19-2016, 06:34 PM   #223
murd969
While doing some body work on the firewall it was discovered that there was a ton of bondo on the firewall. After sanding it all down it was discovered that when the firewall was smoothed the other shop just welded a piece of steel over the original. After removing that piece look at the present that we found.
Instagram: murd969
Old 07-19-2016, 06:35 PM   #224
murd969
To be honest I was pretty pissed considering I paid to have it done right only to find that mess. Away went that garbage and a new firewall was welded in. It's not finished but it's a million times better.
Instagram: murd969
Old 07-19-2016, 06:42 PM   #225
murd969
We also found other issues. The cowl wasn't level and it had a dip in it. So after further investigation we found another mess.
Instagram: murd969
