Old 03-16-2015, 06:27 PM   #201
RANDY COX
RANDY COX's Avatar
Re: Randy & Jakes 64 4x4 SLOW build
http://www.ebay.com/itm/381149875281...%3AMEBIDX%3AIT
Jason I found these on e-bay they are 10 ply Radials they were 499.00 with free shipping equals about 125 a Tire. I actually wanted some 7.50x16's they were 151.00 plus 30 a tire for shipping and they were Bias tires to top that so I think I came out better with these Radials...Thanks for the compliments..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 03-16-2015, 06:39 PM   #202
bj383ss
bj383ss's Avatar
Looking good Randy
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 03-16-2015, 10:06 PM   #203
TJ's Chevy
TJ's Chevy's Avatar
Boy Randy! Those new tire look great!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-16-2015, 11:58 PM   #204
mud.man.rj
mud.man.rj's Avatar
Tires and rims look good, should roll easy, no resistance.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 03-17-2015, 01:30 PM   #205
61K10
61K10's Avatar
Randy--your new shoes look GREAT!!! I need to get some 16" rims and some skinny's (would love some org 17.5's) maybe next yr.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-22-2015, 06:49 PM   #206
RANDY COX
RANDY COX's Avatar
I sit my front end back on for curiosity sake to see how the new shoes were going to look and to see how much clearance with a lot taller tire...
I have 1 that didn't seal has very slow leak... I must say that engine sure is easier to work on without that front end on there....
1964 BBC 402 4x4
Old 03-22-2015, 11:38 PM   #207
mud.man.rj
mud.man.rj's Avatar
Looks like lots of clearance.
5.0 4spd std.
7" lift w 35's.
Old 05-02-2015, 09:04 PM   #208
RANDY COX
RANDY COX's Avatar
Well I got out there today and did some work on the ole truck, disassembled the front end and realigned up passenger door. started it up and let her run a bit...Got to get my butt in gear and get the passenger side rear corner in...
1964 BBC 402 4x4
Old 05-02-2015, 11:18 PM   #209
mattbert56
mattbert56's Avatar
Always excited to see progress even if it's little amounts. Love your 292. Looks like ours are twins haha.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
Old 05-02-2015, 11:57 PM   #210
TJ's Chevy
TJ's Chevy's Avatar
Those tires are sweeeeeeeeeet!!!!!!
Old 05-03-2015, 07:21 AM   #211
jmabx
Just read through your build thread and I have to say, it's very inspirational to me. I thought I was the only guy doing major work on his truck outside and without a garage, which as you know, can be a challenge. Sometimes I think that dragging out all my tools to start and dragging them all back in when finished is more work than anything else.
It's nice to see the progress you've made so far and I'll keep an eye out for more in the future. It gives me hope that I can get the work done with the resources available to me... a little at a time.
Jeremy
jmabx is offline   Reply With Quote
Old 05-03-2015, 12:37 PM   #212
61K10
61K10's Avatar
Randy--Glad you are back working on your tk. I'm building a 3.38 third member for mine so i can drive it on the freeway. Of course i won't be able to use 4wd with the different front gears. Again, love your tires/wheels.
kimble
1961 chevy K10
Old 05-03-2015, 12:50 PM   #213
RANDY COX
RANDY COX's Avatar
Thanks Guys, it's been a long while since I've done anything between the weather and being sick and had the Flu.... The ole truck moved under it's own power today, Turned it
around hopefully getting ready to start on the rear mount and cab corner, Been working 7 days a week for the last two weeks and next week have Inventory so really busy. Here are some pixs cause I know hoe we all like pixs...
My Inner fenders are so rusted @ front and in the rear so are the fenders are banged up Purdy good really need to replace with repop or some OEM....I may be able to patch the fenders...got my passenger door aligned now so you don't have to have 2 hands to open it. worked on it for 2 hrs messing with it, came in the house came to this web site and looked up door alignment and within 15 mins had it aligned...It was really about to get on my nerves... need to adjust the clutch as it's letting out on floor no play whatsoever...We
may be moving this yr and I'm looking for a place that has a GARAGE..... Hopefully...
1964 BBC 402 4x4
Old 05-12-2015, 09:09 PM   #214
RANDY COX
RANDY COX's Avatar
Got out there this evening and worked on the ole truck for about an Hr. Finally got the rear cab mount fitted and welded in and also the flooring above it, now just gotta get the rear cab corner final fit and weld it in...sometimes it's amazing how much you can get done in a little time...
1964 BBC 402 4x4
Old 05-12-2015, 09:50 PM   #215
TJ's Chevy
TJ's Chevy's Avatar
Glad to hear it moved under its own power. Always a good feeling. Yep...little bit o time and alot can be done.
Old 05-13-2015, 10:01 AM   #216
1963c-10
1963c-10's Avatar
Looking good!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-13-2015, 10:19 AM   #217
62 Barnfind
62 Barnfind's Avatar
Your truck is coming along nice!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 06-06-2015, 12:51 PM   #218
RANDY COX
RANDY COX's Avatar
Saw my Buddy in his 65 3/4 4x4 today and made me wish mine as done, but do they ever get done. I need to get to work on mine been working a lot of OT lately...
1964 BBC 402 4x4
Old 06-06-2015, 04:08 PM   #219
mattbert56
mattbert56's Avatar
There never done hah but they get Done enough for being able to drive it. That's where I'm at. Drivable. But needs plenty more to be finished. Hang in there buddy!!!
Old 06-08-2015, 01:29 PM   #220
61K10
61K10's Avatar
Hay Randy, how wide are your rims?
1961 chevy K10
Old 06-08-2015, 04:11 PM   #221
RANDY COX
RANDY COX's Avatar
Hey, Kimble I think there either 4 or 4 1/2" wide I had to grind alittle on the inside of wheel and on the caliper to get them to clear....I don't have one broken down to measure for sure...But there not very wide.....
1964 BBC 402 4x4
Old 06-09-2015, 08:53 PM   #222
62 Barnfind
Loving the engine! That green really looks good and I really like it as a truck color.
John Z
62 Barnfind
Old 07-04-2015, 05:11 PM   #223
RANDY COX
RANDY COX's Avatar
well finally made time to work on the ole truck, getting real close to final fit for cab corner
And ole Glory waving, I'm off all next week company plantwide shutdown so hopefully will get more done...may just try to get it road worthy so I can enjoy driving it some...
Will prolly paint my wheels the green color next week will be posting pixs I know how we
all like pixs including me LOL????
1964 BBC 402 4x4
Old 07-06-2015, 04:58 PM   #224
RANDY COX
RANDY COX's Avatar
Well I'm trying to make some headway on the truck as I'm off all week, Yesterday before
church I thought it would be real nice to stubb my pinky toe, so when I came home and took off my shoe the whole side of my foot was swollen and blue, so I think I may have
broken it, it's been hurting ever since. I did however manage to get a shoe on today and limp outside and do some work on the truck, I got all 4 shocks mounted and still working on cab corner it's being a pain to line up for some reason...but it's trying to rain again so you know how it is with no garage.....
1964 BBC 402 4x4
Old 07-06-2015, 06:30 PM   #225
joedoh
joedoh's Avatar
probably didnt hurt till you looked at it...
love this project though!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
