Old 04-04-2016, 01:15 PM   #201
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Great deal on new crate engine
No, they're not run, you have to break them in with the correct oil, etc.
The warranty is supposed to be 3yr 36K if replacing a 350, it's supposedly only 1 yr 12 months if you replace a "non 350" engine with it (like a straight 6), but as far as they know... your old 350 blew up
And no, mine is still covered in plastic in the garage. My 3 yr warranty might run out before I even install it!
I'm going to make a video with stuff with the current date with the engine on a stand with the ID tag, etc before I install it, just in case.
I've knocked out a ton of projects since I bought the motor. I bought it to replace the low compression smoking 350 in my truck now, but the damn thing keeps running good, so I haven't "had" to do it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-04-2016, 02:19 PM   #202
chazdo2
thanks again!
chazdo2 is offline   Reply With Quote
Old 04-04-2016, 10:51 PM   #203
lawest
I used the Joe Gibbs break in oil that I purchased at NAPA.
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 04-05-2016, 07:45 AM   #204
chazdo2
Thanks again!!!
Old 04-05-2016, 08:58 AM   #205
snipescastle2
snipescastle2's Avatar
Talking Re: Great deal on new crate engine
Here's another deal, 7 year/70,000 mile warranty to boot! With no core return!
http://m.ebay.com/itm/CHEVY-383-420H....c100408.m2460
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 04-05-2016, 01:29 PM   #206
chazdo2
Ben
Gonna have to start saving my pennies!!!
Old 02-17-2017, 01:31 AM   #207
El Dorado Jim
Originally Posted by LockDoc View Post
I don’t know about anyone else but the engine I ordered from Jegs did not include break in instructions. I saved the instructions from my last 350ci 260hp crate engine so I thought I would post them in this thread. The normal disclaimers apply to this document such as no guarantee of accuracy, correctness, or omissions, and you use it at your own risk… All I can tell you is that I used these instructions for the crate engine I installed in my ’69 Suburban last summer and it worked great…. It also includes a lot of other useful info. Just print it out and hang it on the wall.
If anyone finds any errors please let me know and I will check them out.
Thanks,
LockDoc
Initial Crate Engine Break In Procedure
The following form is the GM recommended crate engine start-up procedure with some minor changes made to it by Sallee Chevrolet. You can use this form for keeping track of your engine's break-in.
GM'S RECOMMENDED CRATE ENGINE START-UP PROCEDURE
Print this document out and check off numbers below when each step is completed.
1) Safety first! If the car is on the ground, be sure the emergency brake is set, the wheels are chocked, and the transmission cannot fall into gear. Next verify that all hoses are tight and that both the radiator and radiator over flow jar/tank are full and have been filled with the proper anti-freeze and water mix.
2) Before starting your engine for the first time, add one pint of engine oil supplement ( EOS¹) to the crankcase oil and then check the oil level. Once this has been done, prime the oil system with an oil pump primer tool. Make sure number 1 cylinder is on TDC compression stroke, and install the distributor.
3) Adjust the distributor timing roughly by hand for a quick start up and smoothest idle possible.
4) When the engine first starts, verify that the engine rpm is at a safe level and that the timing is set near or at 30° before top dead center (BTDC). Run the engine speed between 1,500 and 2,500 RPM's, varying the engine speed up and down with-in this range, to prevent overheating of the exhaust valves and the exhaust system. This should be done with no-load on the engine and for the first 30 minutes of operation.
5) After the first 30 minutes of the engine running, set the ignition timing according to the timing specifications. Now would be a good time to check thoroughly for leaks.
6) Adjust the carburetor settings, if necessary.
7) Drive the vehicle with varying speeds and loads on the engine for the first 30 miles. Be sure not to use a lot of throttle or high RPM.
8) Run five or six medium-throttle accelerations to about 3,800 RPM (55 to 60 MPH), then letting off in gear and coasting back down to 20 MPH.
9) Run a couple hard-throttle accelerations up to about 3,800 RPM (55 to 60 MPH), then letting off in gear and coasting back down to 20 MPH.
10) Change the oil and filter with recommended oil (10w30SG in most cases) and filter.
11) Drive the next 500 miles normally, without high RPM's (below 3,800 RPM), hard use, or extended periods of high loading.
12) Change oil and filter again.
13) Your engine is now ready for many happy cruising miles!
Note¹: EOS P/N 1052367 can be used any time during the life of the engine.
Technical Note: This procedure has been corrected and improved from the original GMPP procedure by Sallee Chevrolet.
Warning: Your engine will not be fully broke in until after at least 2,000 miles of driving have been put on it with normal organic oil.
Installation Parts You May Need
10147994 - Intake Gasket
12346192 - Silicon Sealant for Intake Gasket
Both of the following gaskets are needed for the fuel pump mounting plate:
10114141 - Fuel Pump Gasket
12560223 - Fuel Pump Mounting Plate Gasket
This would also be a good time to go to a chromed fuel pump block off plate or mounting plate if you are planning on adding chrome to your engine or you can just reuse your existing mounting or block off plate. Sallee Chevrolet can supply you with a chromed block off plate that has the Chevy Bow Tie on it as well as a chromed mechanical fuel pump and chromed fuel pump mounting plate if you plan on running a mechanical fuel pump.
You can use either a 1 quart or 3/4 quart oil filter with this engine.
25160561 - 1 Quart Oil Filter (ACDelco PF1218)
25324052 - 3/4 Quart Oil Filter (ACDelco PF454)
05613957 - Spark Plug (ACDelco R45TS) [Gap @ .035 for points distributor, .045 for HEI distributor]
Flexplates and Flywheels that can be used depending on your application:
00471598 - 14 inch diameter flexplate (automatic transmissions)
00471529 - 12.75 inch diameter flexplate (automatic transmissions)
03991469 - 14 inch diameter flywheel (manual transmissions)
Harmonic dampers that can be used:
06272221 - 6.75 inch harmonic damper
06272222 - 8 inch harmonic damper
Thermostats that can be used:
10207381 - 180°F Thermostat
12514334 - 195°F Thermostat
10105135 - Thermostat Gasket
Water pumps that can be used:
12522016 - Cast iron, long-leg style, water pump for 1969 through 1976 applications.
88894341 - Cast iron, Long-leg style, water pump for 1977 through 1987 applications.
12458926 - Cast iron, short-leg style, water pump for 1967 through 1972 pickups and cars up to 1968.
12458924 - Cast iron, short-leg style, water pump for 1971 through 1981 Corvettes.
What to do after installation and initial break-in is completed.
1) Check oil level.
2) Check engine coolant for level and proper temperature protection for your location. Also check that the coolant is cycling properly and that the thermostat is opening when the engine warms up.
3) Check for leaks and retighten fan belts.
4) If you have installed an aluminum intake manifold, you must re-torque the intake bolts. Torque to 35 ft.-lbs. or tighten snuggly with a wrench, if no torque wrench is available or practical for your application.
5) If your engine has tubular exhaust headers, retighten the header bolts after the initial engine break-in to prevent leaks.
Periodic Maintenance
1) Change engine oil and oil filter every 3,000 miles or every 3 months whichever comes first. At the time you are changing the oil, you should also inspect the air filter and the PCV filter. Replace these if dirty.
2) Do a monthly check of fluid levels and check for fluid leaks.
3) Do a monthly check of fan belt tension and condition.
350ci/5.7L Engine Torque Specifications
Camshaft Sprocket Bolt/Screw - 18 ft.-lbs.
Connecting Rod Nut - .006 bolt stretch preferred 20 ft.-lbs + additional 55° (45 ft.-lbs. if no angle gauge available)
Crankshaft Balancer Bolt/Screw - 63 ft.-lbs.
Crankshaft Balancer Pulley - 35 ft.-lbs.
Crankshaft Bearing Cap Bolt/Screw and Stud - Inner: 70 ft.-lbs, Outer: 65 ft.-lbs.
Cylinder Head Bolt/Screw - 65 ft.-lbs.
Distributor Bolt/Screw - 25 ft.-lbs.
Drain Plug - 15 in.-lbs.
Engine Oil Gallery Plug - 15 ft.-lbs.
Engine front Cover Bolt/Screw - 75 in.-lbs.
Exhaust Manifold Stud and Bolt/Screw - 26 ft.-lbs.
Flywheel Bolt/Screw - 65-70 ft.-lbs.
Intake Manifold Bolt/Screw:
First Pass - 15 ft.-lbs.
Final Pass - 35 ft.-lbs.
Oil Filter Adapter Bolt/Screw - 17 ft.-lbs.
Oil Level Indicator Tube Bolt/Screw - 106 in.-lbs.
Oil Pan Assembly:
Corner Nut/Bolt/Screw - 15 ft.-lbs.
Side Rail Bolt/Screw - 165 in.-lbs.
Oil Pan Drain Plug - 15 ft.-lbs.
Oil Pump Bolt/Screw To Rear Crankshaft Bearing Cap - 66 ft.-lbs.
Oil Pump Cover Bolt/Screw - 80 in.-lbs.
Spark Plug (Tapered Seat) - 15 ft.-lbs.
Starter Motor Bolt/Screw - 35 ft.-lbs.
Valve Rocker Arm Cover Bolt/Screw - 25 in.-lbs.
Water Pump Bolt/Screw and Stud - 30 ft.-lbs.
this is great,thanks Leon
El Dorado Jim is offline   Reply With Quote
Old 10-31-2017, 11:03 AM   #208
Keystone_Hate
Thread revival!!
If anyone is looking, Radley Chevrolet in Virginia has the 10067353 small block crate engines for $1675 with free shipping. I just bought one from them and the engine looks great. Save $400 over the new iteration of the 350 that Summit and Jegs sells.
Keystone_Hate is offline   Reply With Quote
Old 10-31-2017, 12:31 PM   #209
Auctioneerhere
Originally Posted by Keystone_Hate View Post
Thread revival!!
Save yourself the trouble, find them on ebay:
https://www.ebay.com/usr/radleygmwho...p2047675.l2559
Auctioneerhere is offline   Reply With Quote
