Old 04-22-2015, 01:02 AM   #201
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
Originally Posted by FarmerSid View Post
Yes he sold the truck. The roadmaster roasts the the tires with the LT1. Lots of torque. Optispark has been an issue but mine has the vented newer version. Still original and I understand the past issues with it.
No additional support needed for the LCA mounts as that's where the factory composite spring mounted. It's about 3/8" thick.
Those Roadmasters are one of the most underrated highway cruisers
Forgive me if I missed this, but on the 'Vette setup is there a swaybar? Seems like the transverse leaf would make it unnecessary. I can't remember from the last time I was under one.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 04-22-2015, 02:06 AM   #202
hp1957
hp1957's Avatar
FarmerSid, Cool Truck !
Harvey
1957 Chevy Stepside
1958 GMC Fleetside C4 build thread: http://67-72chevytrucks.com/vboard/s...=535686&page=6
hp1957 is offline   Reply With Quote
Old 04-22-2015, 05:48 AM   #203
FarmerSid
FarmerSid's Avatar
Yes there is but my IFS didn't come with one. Not sure if I should be adding mounts for one or not.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 04-22-2015, 06:02 AM   #204
FarmerSid
FarmerSid's Avatar
Harvey
1957 Chevy Stepside
Thanks Harvey!
C4 IFS & D44 IRS
5.3 HO L33
Old 05-07-2015, 09:19 PM   #205
T bone
Sid I recently picked up a C4 front and rear. I'm using the 36 rear. I was hoping you would share a high res image or the front cross member plan shown back in post 98.
Cheers
T bone is offline   Reply With Quote
Old 05-08-2015, 10:16 AM   #206
FarmerSid
FarmerSid's Avatar
I don't have a very good camera as you can tell by my pictures but can get you any dimensions you need. The drawings you refer to are for 84-87 parts. I made mine to 88-96 specs. I measured my stock Vette cross member and built mine accordingly.
Find out what year your parts are from and I can help you no problem.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-08-2015, 10:31 AM   #207
FarmerSid
FarmerSid's Avatar
Forgot that a had a few new pictures I could post. These are from last week and weekend.
Starting to build the mounts. They are made of 3" X 1 1/2" X 1/8" tube. The dog bone brackets are tacked to the frame to make sure I don't lose the wheel centre.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-08-2015, 10:35 AM   #208
FarmerSid
FarmerSid's Avatar
A few of the bat wing cross member and brackets I made ready to be installed. The brackets are made out of 3/16" plate.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-08-2015, 10:52 AM   #209
FarmerSid
FarmerSid's Avatar
Installed new bushing in the bat wing. The Prothane Total Kit came with bushings for both the 84-87 and 88-96 bat wing. The 84-87 ones are extra and will use them for other mounting brackets I need to make.
In the picture of the old bushings, the thin metal sleeve you see had to be removed for the new bushings to fit. Made me stop and think for a bit on what was going on. Bushing kit came with no instructions. The new bushings fit nice a tight. I drilled holes around the perimeter of the old rubber bushing to make it easier to remove them. A little lubricant between the bushing and the housing made it easy to remove them.
Now that the new bushings are installed, I will know that the rear will be and stay in the correct place on final assembly.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-08-2015, 11:03 AM   #210
FarmerSid
FarmerSid's Avatar
The new cross members are in. They are located about 4" above the bat wing so I can run the exhaust through there as opposed to underneath like on the Vette.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-08-2015, 11:06 AM   #211
FarmerSid
FarmerSid's Avatar
found this one too
C4 IFS & D44 IRS
5.3 HO L33
Old 05-08-2015, 11:11 AM   #212
FarmerSid
FarmerSid's Avatar
a few of the carrier mount. This is where I used one of the extra 84-87 bat wing bushings.
I'm now working on the rear shock mounts.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-08-2015, 11:40 AM   #213
starterman99
starterman99's Avatar
looking great, wish I was making progress like you. But life gets in the way sometimes. keep up the good work.
1950 5 window
starterman99 is offline   Reply With Quote
Old 05-08-2015, 12:13 PM   #214
99 to Life
99 to Life's Avatar
killing it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-08-2015, 01:49 PM   #215
Advanced Design
Advanced Design's Avatar
Originally Posted by 99 to life View Post
killing it.
x2...
Advanced Design is offline   Reply With Quote
Old 05-08-2015, 02:31 PM   #216
JJorgensen52
This chassis is a work of art, man!
CURRENT
SOLD
Old 05-08-2015, 03:48 PM   #217
FarmerSid
FarmerSid's Avatar
Thanks guy's! The fabbing of parts sure eats up the hours. It's a wonder nobody has laughed at my wooded wheels.
They are 28" tall which is what I plan on running in the end. The Vette wheels I have are 25 1/2" tall. Hope things turn out as planned in ride height and appearance.
I should have a couple hours tonight to work on the rear shock mounts. I'll snap a few pictures as well as a few of the carrier mount for all to see how I made it.
Cheers!
C4 IFS & D44 IRS
5.3 HO L33
Old 05-08-2015, 07:31 PM   #218
oldman3
oldman3's Avatar
Nice update, and the frame is looking great, nice details....Jim
oldman3 is offline   Reply With Quote
Old 05-08-2015, 08:46 PM   #219
Blue1952
Looks great
Blue1952 is offline   Reply With Quote
Old 05-08-2015, 10:08 PM   #220
T bone
The front and rear I have is from a 91.
Thanks in advance.
Old 05-08-2015, 11:14 PM   #221
99 to Life
99 to Life's Avatar
iv seen guys do the same with wooden wheels. nothing wrong with that one bit. I actually thought it was you using your head, which you are. its ideal to have the right size tire for your ride height. and yeah fab work eats up time for sure.
Old 05-09-2015, 07:38 AM   #222
FarmerSid
FarmerSid's Avatar
T bone, your Vette parts are the same as mine. Here are the pictures that were shared with me. Keep in mind that the dimensions are not the same as your stock vette cross member. Mine measured differently. My measurement from the bottom of the cross member to the top of the upright where the UCA mount goes is 10 1/2" where as the drawing shows 9 1/4". That's pretty much the only difference. I made this change as that is how my vette cross member measured up and felt that I should duplicate what my parts came off of.
Also, the bolt spacing on the UCA mount is different on the 84-87 than it is on the 88-96. I have pdf templates of the UCA mount with the bolt spacing for 88-96. You will be good to go there. I also have pdf's of the rack mounts and upper shock mounts. I changed the upper shock mounts quite a bit as I made them to accommodate a certain length of shock and angle.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-09-2015, 07:40 AM   #223
FarmerSid
FarmerSid's Avatar
More...
C4 IFS & D44 IRS
5.3 HO L33
Old 05-09-2015, 07:47 AM   #224
FarmerSid
FarmerSid's Avatar
Don't know why some are rotated.
That should get you started but definitely measure your stock cross member your C4 parts came off of. Take tons of pictures before you take it apart. Especially the location and number of shims on the UCA. Then throw the cross member on your work bench and start comparing measurements.
Hope this helps you out.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-09-2015, 07:51 AM   #225
Blue1952
Looking great, you say you have PDFs of the dimensions? Could I get a copy? TIA
Rafael
