Old 02-07-2017, 11:39 PM   #201
Graham57a
Graham57a's Avatar
Re: Do you have a 1972 Plaid Blazer/Jimmy?
Here's a local truck I'm working on, curious how it's a non promo truck but reads Cheyenne equip. I'm fairly new to the blazer world so I'm just comparing to pickups
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 02-08-2017, 06:13 AM   #202
SS Tim
SS Tim's Avatar
You can't really directly compare it to Highlander pickup.
Nothing wrong with that SPID though and an interesting combo.
As you noted it is a trim upgrade Highlander and not a bundled promo package Highlander.
Unlike the Fleetside pickups, Blazer Highlanders were an upgrade of the Z84 CST trim package. As such they also were the only bucket seat Highlanders. Of note Blazers required both the Z84 CST trim and the optional hardtop coded Z59 or Z58 but not apparently a rear seat.
SS Tim is offline   Reply With Quote
Old 02-08-2017, 10:11 AM   #203
SoCoC10
SoCoC10's Avatar
Just sold this survivor for a friend of mine. It is going to Green Bay WI. New owner is going to reupholster, fix the rust and paint. Just refresh not a full restore, it doesn't need much.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 02-10-2017, 12:55 PM   #204
Chulisohombre
Chulisohombre's Avatar
Doesn't look to need much. Great looking truck.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 07-09-2017, 08:02 AM   #205
SoCoC10
SoCoC10's Avatar
They're still out there! Garaged and used sparingly as a hunting rig since 2001. I found this one just outside Denver, CO.
Old 07-09-2017, 08:32 AM   #206
briank
Nice ride...did you buy it? Those damn rockers!
briank is offline   Reply With Quote
Old 07-09-2017, 08:41 AM   #207
SoCoC10
SoCoC10's Avatar
Yes it followed me home. Goes in Monday for an estimate for rust repair.
Old 07-09-2017, 09:42 AM   #208
mrtoni
Saw that. $15000?
mrtoni is offline   Reply With Quote
Old 07-09-2017, 10:29 AM   #209
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Great find - two things good to note:
1) speaker location (would use brackets w nutserts I believe, differs from AC brackets)
2) white rear wheel tubs - I've seen several now and like this one seem to be St. Louis builds. Did GM paint the wheel tubs white on some highlanders?????? My blue one is similar. Is the jack decal on top of the paint?
Old 07-09-2017, 11:29 AM   #210
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Examples...
Old 07-09-2017, 11:30 AM   #211
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Old 07-09-2017, 11:31 AM   #212
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Vvvv
Old 07-09-2017, 12:02 PM   #213
DeadheadNM
Carpe manana
DeadheadNM's Avatar
One more.
Old 07-09-2017, 08:03 PM   #214
Chulisohombre
Nice highlander sococ10. Plan on there being more than just rockers needing repair once they cut them off. I needed floors and floor brace and inner rockers with some rocker tortion box repair. I really need to replace the tortion boxes now as the repair has failed now too. Rust gets everywhere and eats inside out. Good luck on repair and hopefully everything else is solid. When I got mine repaired the first time at a shop it was 300 per side. This last time I did it myself and cost me 40 per side and a wire spool for my welder. It's not super difficult but my truck isn't in as good if shape as yours either. So it didn't need to be perfect. I just wanted it solid again.
Old 07-09-2017, 10:52 PM   #215
DeadheadNM
Carpe manana
DeadheadNM's Avatar
It's worth noting that in addition to the white wheel tubs the front face of the step on the floor pan is painted white on SoCoC10's Highlander - my blue St Louis highlander was as well but I dismissed it as an addition from a prior owner, which I no longer believe to be the case. Here are example pics - anyone with a highlander that has white rear wheel tubs please chime in as we may have have a plant specific variation.
Note white overspray on the retainer spring for the lug wrench.
Old 07-09-2017, 10:54 PM   #216
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Pic of the step face.
Old 07-09-2017, 10:59 PM   #217
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I can't find a good example pic of the white step face on mine but glimpses can be seen on the last two photos here: http://67-72chevytrucks.com/vboard/s...36&postcount=4
And this pic shows slight white overspray on the retainer spring like that above:
Old 07-11-2017, 09:09 PM   #218
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The (upside down) smoking gun! Jack decal upon factory white paint.
Two tone OEM Highlander interior.
Thanks Troy.
Old 07-11-2017, 09:11 PM   #219
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Additional documentation pics. Rear carpet strip used on the front - correct on some k5s.
Old 07-11-2017, 09:11 PM   #220
DeadheadNM
Carpe manana
DeadheadNM's Avatar
....note white paint on the top to bedside bracket, some were body color.
Old 07-11-2017, 09:12 PM   #221
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Found a pic from my blue highlander...same white face. Rear carpet strip up front as well.
Old 07-11-2017, 10:23 PM   #222
mrtoni
The rust repair estimate must've been very high since it's now listed on eBay for $20000 more but same pictures
http://www.ebay.com/itm/like/2225726...&ul_noapp=true
Old 07-12-2017, 10:00 AM   #223
ClassicStyle
ClassicStyle's Avatar
Interesting on the white step face, I took a look at my truck, appears to original paint inside, and mine is body color, you can see the holes for the trim, but otherwise no white
Dark blue and 671 gray plaid highlander built in flint
1972 Dark blue, Cst, Highlander
ClassicStyle is offline   Reply With Quote
Old 07-12-2017, 08:29 PM   #224
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for checking.
Next step is to try and figure out why some have "two tone" interiors while others do not. The orange blazer above and my blue blazer were built in January and February respectively (1972), both St Louis trucks and neither a promo-pacackage. I'm wondering if the added paint was a plant specific variation and maybe on k5s built before a certain date.
Keep your eyes peeled for other examples.
Old 07-12-2017, 10:29 PM   #225
ClassicStyle
I will pay attention in my travels.
I'll have to look at my build date, sequence number is 166648. Order number on the bottom jkg700
Amazing to me the differences between trucks right out of the factory
"ss tim", highlander, plaid
