Old 11-12-2015, 04:31 PM   #201
slowcpe
slowcpe's Avatar
Re: Project 'Kickin Wing' (No Limits/Hotchkis/PorterBuilt/LS Power)
Looking good. Good to hear on the floor as that's the route I'm likely to take rather than trying to patch here and there.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 11-12-2015, 05:00 PM   #202
bterry97gt
Originally Posted by Low68 View Post
The progress looks great. The floor replacement seems like a pretty big step.
Originally Posted by mcbassin View Post
Awesome work on the cab! I really like the full floor replacement. In hindsight, I think it's probably the best option for a really rusted floor.
Thanks! I am happy I went with the full floor. It is more expensive, but the benefits you get are well worth the money. I would have needed complete outer pans, so it would have taken longer to cut those out and weld them in than it took to do the whole floor panel and rockers. Its also nice to have a brand new panel inside and out to scuff up and put a good color matched coat of bedliner on once the cab is painted. My old floor supports were full of dirt that I could have never fully cleaned out.
On a side note: don't fit your doors until after you do the floor. I know common sense would tell you this, but I only planned to do patches so we had already fit the doors. Once the floors were finished the gaps were a little off. We had the cab well braced, but it likely shifted a bit when we layed it on its back. It wasn't anything major, just enough to move the gaps around a bit.
bterry97gt is offline   Reply With Quote
Old 11-12-2015, 06:02 PM   #203
HARDCORECASH
Thanks for the info!! Project is coming along nicely!! Can I drop off my 67 cab and new floor for you fix for me?? Hahaha
HARDCORECASH is offline   Reply With Quote
Old 11-12-2015, 08:04 PM   #204
BossHogg69
motor exploder
BossHogg69's Avatar
Truck is looking great - nice work so far! You nailed the stance
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-13-2015, 06:38 PM   #205
my67chevytruck
Under Construction
my67chevytruck's Avatar
Sweet Build!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-23-2015, 05:08 PM   #206
bterry97gt
Thanks! I have referred to your thread a few times for ideas.
Originally Posted by my67chevytruck View Post
Sweet Build!
Thanks!
Old 11-23-2015, 05:10 PM   #207
BossHogg69
motor exploder
BossHogg69's Avatar
Thanks!
Beware, anything I post is usually a what NOT to do! I'm excited to see some more progress from your build.
Adam
Old 11-23-2015, 05:12 PM   #208
bterry97gt
Question for the guys following the thread. I originally planned to go without inner fenders so I kept the original hood hinges. Now, I am doubting that decision and was curious if you knew of any options that might work for me with the original hinges?
I know slosh tubs require porterbuilt style hinges, and the original ones obviously wont work due to the drop and width of wheel/tire I am running...
Old 11-23-2015, 06:02 PM   #209
BossHogg69
motor exploder
BossHogg69's Avatar
How much did that No Limit wideride drop the truck? Like 5"? or is it more than that? I'm running a 5" front drop with stock inners and have slung my truck into some wicked turns and accidently hammered it over a few bumps and haven't bottomed it out or rubbed yet, and that's with a chubby 454 up front. I'm running a 19x9", 6" bs & 275/35/19 that are 26.5" inches tall with 35 psi in them. Hotchkis 1500# springs, 2.5" drop spindles & Chris Alston DA shocks.
I went back & forth on the inner fender/hood hinge deal myself - stock vs. slosh tubz vs hills rod & custom vs none, but I really didn't care for the looks of the PB hinges or the Slosh tubz. For some reason, I just had my heart set on the Ring Bros hinges, so that meant no inner fenders or stock ones. Running no inners really wasn't an option because I didn't want to trash all the work I put into getting my engine bay the way I wanted it. I do really like the Hills Hot Rods inners, so if I had it to do over, I'd buck the form over function adage and run them with PB hinges, then I could've run a little less backspace on my front wheels.
You may have already, but if you'll check out Chris Smith's build (user Chris67GMC) he had his stock inner's in and was using a Wide Ride on air. Don't know if that's still the case now. You can probably hit him up and get some help, he's who I ordered my Ring Bros. hood hinges from and was really good to deal with.
Sorry for the long winded post, let us know what you come up with!
Adam
Old 11-23-2015, 06:56 PM   #210
Luther Grimace
Luther Grimace's Avatar
You are rocking right along man. Good job!
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 11-23-2015, 08:00 PM   #211
ajgriffin
ajgriffin's Avatar
What is the lower hinge bracket that you showed in your earlier pictures?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 11-25-2015, 01:20 PM   #212
bterry97gt
I'm not sure how much I am technically dropped, but its pretty low. I have coilovers, so I could adjust up some but would prefer not too. I am running a 20x10 with 275/35 but will likely go to 285/35 on the next set.
I like the look of meaty tires with no inners but worry about dents on the firewall and hood, also the noise reduction. If I thought it would even be close I would give the factory wells a shot, but I am thinking no unless I am willing to sacrifice some drop. Thanks for the info!
Old 11-25-2015, 01:23 PM   #213
bterry97gt
Thanks man, Im ready to see that duramax dropped in the chevelle!
It is the plate that you lower door hinges bolts into, mine was rusty and half stripped, so we replaced it with new pieces from Nsane Hot Rodz.
Old 11-25-2015, 11:11 PM   #214
blake's first
blake's first's Avatar
Very nice truck.. It's already a head turner so I guess it will be a neck breaker when it done...
My Name is Rusty Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=570083
blake's first is offline   Reply With Quote
Old 11-26-2015, 01:34 PM   #215
blake's first
You can use Mercedes hood hinges they look good and go in the same spot as stock .. I didn't like any of the inters out there so I'm making molds to make my own they fit a 22x 10 with 285s and don't rub Name:  image.jpg
Old 11-30-2015, 01:28 PM   #216
bterry97gt
Originally Posted by blake's first View Post
You can use Mercedes hood hinges they look good and go in the same spot as stock .. I didn't like any of the inters out there so I'm making molds to make my own they fit a 22x 10 with 285s and don't rub Attachment 1470984
Those looks awesome, but looks like a lot more work than I am willing to invest haha.
Old 11-30-2015, 01:52 PM   #217
bterry97gt
Been doing some bodywork on the cab and looking at some colors, have it narrowed down to a few non-metallic grey chips. I am avoiding metallic paint colors due to the fact that I haven't painted much before and it will be once less thing to worry about when spraying. The colors I like are kind of a love it or hate it type of thing. My dad says the look like primer with clear over them, but he is warming up to them
Lambo Grigio Telesto- #1 right now
Ford Lithium grey- Still waiting to see this one in person. #2
Porsche grey/black- More of a safe choice, more like a natural grey color
Old 11-30-2015, 04:18 PM   #218
knomadd
knomadd's Avatar
I like the BMW color. But then again, I've always looked at it like your dad. That one though is starting to grow on me. The ford color looks like the sealer we used at the shop I worked at in college (just smooth). I've seen it in person and am not a fan... but that's me.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 12-11-2015, 01:07 AM   #219
bterry97gt
Got the cab in slick sand, I have a few areas that need a little more attention but all in all it looks pretty good.
Old 12-11-2015, 02:10 AM   #220
deejaaa1
looks sharp.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 12-11-2015, 03:18 AM   #221
Low68
Low68's Avatar
Looks good
Build Thread
Low68 is offline   Reply With Quote
Old 12-23-2015, 11:38 PM   #222
aboyer
Adam B
Very nice build!
aboyer is offline   Reply With Quote
Old 12-24-2015, 12:10 PM   #223
Twisted71c10
Twisted71c10's Avatar
can't wait to see the final results !
Twisted71c10 is offline   Reply With Quote
Old 12-26-2015, 07:53 PM   #224
dkauffman05
dkauffman05's Avatar
Truck is looking fantastic man ! Keep up the great build. Funny thing is that all the colors you have posted ware also ones I was trying to choose from. I love the Gringo grey.
dkauffman05 is offline   Reply With Quote
Old 12-26-2015, 07:54 PM   #225
dkauffman05
I'm also in for some front inner fender ideas. I has some rubbing issues on the track in hard turns . I'd also like to keep the stock hinges.
