Old 04-06-2015, 04:56 PM   #201
rusty76
rusty76's Avatar
Re: Blake's 67 GMC stepside build
Well if you can handle body work I'm sure you can handle an house remodel. Great job on the doors.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-07-2015, 09:53 AM   #202
reaper71
reaper71's Avatar
Doug and Rusty thank you!!
Pic #1. Back in primer..
Pic #2. 2nd view
Pic #3. and one more..
reaper71 is offline   Reply With Quote
Old 04-07-2015, 01:17 PM   #203
yj4000
yj4000's Avatar
Very nice work! Most door bottoms don't get that much attention. This type of detail is what set the nice trucks apart from the Excellent trucks.
Ryan.
yj4000 is offline   Reply With Quote
Old 04-10-2015, 09:57 AM   #204
reaper71
reaper71's Avatar
Thank you Ryan!!!
This was something Dad (oldman3)had taught me to do with thing's like this, Most people will never see it but it's the right thing to do..
Pic #1. Drivers side door's turn for TLC..
Pic #2. 2nd shot
Pic #3. After the blocking was done and ready for more primer.
Pic #4. This was after the primer was sprayed, I masked it off to keep from getting overspray on the backside of the door..
Mark...
Old 04-10-2015, 12:58 PM   #205
Advanced Design
Advanced Design's Avatar
You know, if you and Jim ever host a body work/paint and interior seminar count me in!
Advanced Design is offline   Reply With Quote
Old 04-11-2015, 09:47 AM   #206
reaper71
reaper71's Avatar
Haha, sure thing Doug!!
Old 04-11-2015, 06:04 PM   #207
rusty76
rusty76's Avatar
I'd go as well. Might take me a little while to get there. Lol
My build thread
Crossmembers CC
Old 04-11-2015, 06:56 PM   #208
swamp rat
swamp rat's Avatar
^^^ X2 ^^^. Awesome work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-13-2015, 10:23 AM   #209
reaper71
reaper71's Avatar
Thank's Guys...Too kind!!
Pic #1. So...Someone at some point it time thought it was a good idea to butcher up the hole for the antenna. (Needs help)
Pic #2. This was after I cut out the janky piece. (I rounded the corners to help keep cracks from starting)
Pic #3. The new piece ready to go in.
Pic #4. Tacked in place.
Pic #5. All metal finished, a bit of hammer/dolly and ready for poly filler and primer..
Mark...
Old 04-13-2015, 03:40 PM   #210
swamp rat
swamp rat's Avatar
Mark...
On the antenna plate, any advice on keeping it from warping and changing the contour? I still fight that, still learning, i would to love to show a piuc that didn't have bondo slathered allover it someday, my gas filler delete plate i just did is a prime example..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-14-2015, 10:03 AM   #211
reaper71
reaper71's Avatar
Swamp Rat... To answer that question, The cowl does have a bit of a compound curve to it so was a little easier to keep it's shape.
But for future projects what makes it easier for me is I tack it in the corners first and use a hammer and dolly to flatten the weld. Then put a tack in between these tacks and repeat. If the metal starts to move a little to much you can always grind the weld,cut and re do. ( practice on old pieces to get the hang of it, so take an old piece and remove a chunk and make a New filler piece and weld in)
Hope this helps, any more questions feel free to ask I'll try and answer the best I can...
Mark...
Old 04-14-2015, 10:16 AM   #212
reaper71
reaper71's Avatar
Pic #1. This is the Running board..
As you can see a classic "cave & pave"
Pic #2. Here it is with the 1/2" of mud removed A snotted up mess!!
Pic #3. 2nd look
Pic #4. So first I removed all old welds. Then I made 2 cuts so I could start to pull it back into it's original shape.
Pic #5. After welding
Mark...
Old 04-14-2015, 10:18 AM   #213
reaper71
reaper71's Avatar
Swamp Rat, To add to your question (forgot to mention) Invest in some small magnets and clamps they are a life saver!!
Old 04-17-2015, 10:09 AM   #214
reaper71
reaper71's Avatar
Pic #1. Here is another look after I pulled the steel back into shape and welded.
Pic #2. After spraying in Epoxy primer.
Pic #3. A shot in High build
Pic #4. after blocking
Old 04-18-2015, 12:14 AM   #215
swamp rat
swamp rat's Avatar
Could you do me a favor and put a straight edge across the lower body line on that door front to back and tell me if its suppose to have a bit of a curve to it? I assumed they were straight but never looked that close at them untill i took my door off and did a little spot media blasting, i thought maybe i may have stretched the door skin it but i checked the passanger door ( no media spot blasting ) and it was the same.
Guess i'm learning more and more stuff about these trucks every day.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-20-2015, 09:39 AM   #216
reaper71
reaper71's Avatar
Yes they do!!! It is fairly slight.
Old 04-21-2015, 01:47 AM   #217
swamp rat
swamp rat's Avatar
Ok, maybe about 1/4" out in the middle or maybe less? Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-21-2015, 09:34 AM   #218
reaper71
reaper71's Avatar
Yes, give or take...
Pic #1. Ok, as some of you may know the stock dash in these trucks are a bit Boring and the customer wanted to change it up a little but not go overboard!
Here is the old portion I removed and will be smoothed out and will have the radio and A/C controls in it's place.
Pic #2. The template.
Pic #3. Transferred to metal..
Pic #4. The opening that will be filled in.
Pic #5. New panel tacked in place..
Old 04-27-2015, 09:56 AM   #219
reaper71
reaper71's Avatar
Pic #1. Another view.
Pic #2. All welded and ground.
Pic #3. Here is a shot after the radio slot was cut out and the new bracket was fabricated to hold up the back of radio.
Pic #4. Here is the radio installed as well as the A/C controls. The A/C controls did not have a mounting plate so I made one from a piece of Aluminum and will be polished later.
Pic #5. Another view.
Mark...
Old 04-27-2015, 02:41 PM   #220
Advanced Design
Well that is cool!
Old 04-29-2015, 04:15 PM   #221
reaper71
reaper71's Avatar
Thank's Doug..
Well that is cool!
Old 04-30-2015, 09:37 AM   #222
reaper71
reaper71's Avatar
On to the A/C setup...
Pic #1. I decided to go with round vents since they fit really nice in the lower section of the dash..
Pic #2. Showing the passenger side. It also shows the empty inside of glove box area where the new A/C unit will make it's new home.
Pic #3. This is the new A/C unit...It is made by Southern Rods (southern Air Maxi 1 unit) It is fairly small,all electric controls and full kit is $819 compaired to the V.A unit over a Grand...
Pic #4. Another view.
Pic #5. The brackets I made to mount the unit..
Old 05-04-2015, 10:04 AM   #223
reaper71
reaper71's Avatar
This update is of an Idea I had for the "Transponder" for the GPS speedo from Speedhut. I didn't want the unit sitting on the dash and looking ugly so...
Pic #1. I removed the old section of speaker grill and made a plate to replace it.
Pic #2. This was after all the tacking was done and started to cut the shape for the Transponder.
Pic #3. Here the unit is being mocked up.
Pic #4. This is after the metal work was done and ground down.
Pic #5. Here the Transponder is in it's new home.
(The wire for the transponder will run through the hole in the back of recess to the gauge)
Till next time..
Mark...
Old 05-05-2015, 07:58 AM   #224
Advanced Design
Looks good Mark. Great idea for the sensor. Did the ac package have patterns for positioning the vents?
Old 05-05-2015, 06:31 PM   #225
reaper71
reaper71's Avatar
No Sir all My figuring.
