Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 02-07-2011, 10:07 AM   #201
Edmond
Edmond's Avatar
Re: Color Wiring Diagram FINISHED
Thank you Chuck, and I'm glad you are happy with it.
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
Capelle a/d IJssel,
The Netherlands
Edmond is offline
Old 02-18-2011, 12:14 AM   #202
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by actconstruction View Post
....snip....
...snip....THIS PROFESSIONALLY RENDERED CAD DOCUMENT AND ASSOCIATED FILES ARE ENTIRELY THE PRODUCT OF EDMOND'S HARD WORK. WE ALL OWE HIM AND ONLY HIM OUR DEEPEST GRATITUDE. So there it is. Credit where credit is due. Thanks again. You're a lifesaver.
Agreed. Thanks sooooo much for the diagram.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-24-2011, 11:52 AM   #203
mlhand
heck of a nice print,
can you send me the largest print available. I dont have a printer.
my address is Maynard L. Hand 3190 Duck Creek Rd. Box Elder,MT. 59521
mlhand is offline
Old 03-24-2011, 12:11 PM   #204
crakarjax
crakarjax's Avatar
... are these for sale or something??? Maybe you should find someone with a printer, or try Kinko's or the library.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline
Old 03-26-2011, 06:04 AM   #205
Cambons
ok so yeah that diagram helped out some but does someone have a full color one for my 1972 chevy truck with an inline 6 or cant point me in the right way to go?
Cambons is offline
Old 03-28-2011, 12:59 AM   #206
sduckworth13
sduckworth13's Avatar
Awesome job thanks alot, I just traded out a bunch of interior parts i wasnt going to use for a 1969 chevy truck instrument cluster that has the battery, temp, oil pressure, speedometer, fuel, and blinker light holes and around the center hole for the tach. I have a 1967 so I'm sure it will need some modifying to the wiring to get everything to work correctly.
sduckworth13 is offline
Old 05-03-2011, 03:40 AM   #207
CHRONIC
ALL I NEED IS A WIRING DIAGRAM FOR MY A/C & HEATER ( FACTORY), IF SOMEONE COULD PLEASE HELP I WOULD BE VERY THANKFULL.
STEVE...
dslee02@telus.net
PLEASE HELP!!!!
CHRONIC is offline
Old 05-04-2011, 01:17 PM   #208
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
STEVE...
dslee02@telus.net
PLEASE HELP!!!!
for a 6, all I have is a black and white at the moment, but you can compare it to the color v8
http://www.2heeldrive.com/Chevrolet/.../I6engcomp.jpg
http://www.2heeldrive.com/Chevrolet/...b%20wiring.jpg
http://www.2heeldrive.com/Chevrolet/...%20chassis.jpg
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline
Old 05-04-2011, 11:51 PM   #209
CHRONIC
I think i got all i need, thanks to everyone for all the help, good bunch of guys. If there is anything i can contribute i always will.
CHRONIC is offline
Old 05-09-2011, 04:38 PM   #210
JT's 70c10
Anyone have any info on "Shaved side markers)? On my truck (70 C10 fleetside)im having an issue with the break, reverse, and "night" lights. all new wiring from the cab back, including new harness for the lights. Is it a ground prob? or do i need to change out the light switch (All the front lights woork great )? and the rear side markers are not hooked up at all.
JT's 70c10 is offline
Old 05-18-2011, 01:56 PM   #211
L8brake731
L8brake731's Avatar
Awesome! Thanks for the good work!
L8brake731 is offline
Old 06-01-2011, 05:33 AM   #212
TurboGuy
just wanted to say thank you
TurboGuy is offline
Old 06-10-2011, 07:17 PM   #213
tnoftsger
First, a BIG THANKS to all who worked on the wiring schematics, there great. I do have a question tho, i am attemping to un-hack the wiring on my '69. Charging system is not charging due to lack of a 12v on terminal 4 of the voltage regulator. This brown wire is intact to the bulkhead connector. Now, i have instrument cluster, not lights. I have found the brown w/white stripe wire loose in the dash. But is the other wire connected to this terminal at the bulkhead connector that goes to the instrument cluster is a black w/brown stripe from the bulkhead? Do i have that right?
tnoftsger is offline
Old 06-11-2011, 12:13 AM   #214
WORP67
Thanks for all the work that was put into these. They will help me alot.
WORP67 is offline
Old 06-12-2011, 12:35 AM   #215
JT's 70c10
tnoftsgr,
Check that it has the ground to the body (Pass side just behind the cab under the truck) If thats intact you will have to trace every wire back to the cluster. The ground will also cure a lot of other probs too. And just a hint, dont just look to see if its there. You must remove it, sand down the frame and body (add soome wd40 befor you put it back togather). Also its not a bad idea to run a second ground from the batt, to the wheel well (pass side). That could clear up the charging prob too, worth the 15 mins to do it.
Old 06-13-2011, 06:42 PM   #216
tnoftsger
Ground is good, a welcome suggestion tho. I guess what i need to know about the wiring schematic is, with gauges, did the brown wire from the voltage regulator turn into a black w/brown stripe and a brown w/white stripe on the cab side of the bulk head connector.
I have continuity between the voltage regulator and the brown w/white stripe cab side, but not between the voltage regulator and the black w/brown strip in the gauge connection.
Old 06-15-2011, 07:02 PM   #217
JT's 70c10
Looking at the diagram again, its very hard to tell what the right wire it is. Ill look at my 70 this weekend and check it out for ya. But i fear that your's just might have been wired/ rewired wrong. Ill post somthing for ya this weekend for ya.
Old 06-15-2011, 07:36 PM   #218
tnoftsger
I appreciate the help! The black w/white stripe is good from the bulk head to the instrument cluster, but not connected to the brown wire on the engine side (the one that goes to the voltage regulator).
Could be that i'm mis-interpreting the diagrams, I assume that the wire leaving the instrument connection labeled "Alternator", the black w/white strip wire connects to the brown wire on the engine side of the bulk head connector. Maybe by "Alternator", it mean the post on the back of the Alternator???
Old 10-25-2011, 09:20 PM   #219
72shymedblue
72shymedblue's Avatar
Thank you for these diagrams. I have owned my truck (72 Cheyenne medium Blue) for 2 years now, and of necessity have just now started trying to sort out the jumble of non-standard wiring that it has accumulated over the past 40 years. Many extra wires and bad connections both under the hood, and under the dash. It's a mess. My immediate problem is as follows; There was a (non-working) add-on cruise control that I removed. After removing the wires to it, (and apparently one extra, maybe more) it would not start, but cranked fine. So i figured that i had removed a wire between the ignition switch and the coil. Right ? So I connected a wire from the ignition to the fusebox, and it started and ran fine. But only for a couple of weeks. Then my battery ran down. A friend told me that wiring it this way meant that the coil was powered even when the key was off. So I disconnected the wire from the ignition (orange or red) and now I am trying to find how to connect the ignition to the coil (if that is what I need to do.)
You have helped me immensely.
72 Cheyenne Super 350ci
83 GMC Vandura 305ci
94 Buick Regal 3100 V-6
72shymedblue is offline
Old 11-08-2011, 04:50 PM   #220
firemanmario
firemanmario's Avatar
Just wanted to say thanks for the work you put into these. I'm about to get started on my wiring and these will help tremendously
firemanmario is offline
Old 01-05-2012, 10:42 AM   #221
71blazervt
71 blazer. I have an additional wire harness under the hood. It has 3 wires going the the carb and one going to the trans for back up and another green? all are coming off relay's on the fire wall. trying to find out. Does any one have this diagram?
71blazervt is offline
Old 06-26-2012, 10:35 PM   #222
jhaymon
jhaymon's Avatar
for those asking, the 18t wire is normally for a fuel sender.
jhaymon is offline
Old 07-15-2012, 11:25 PM   #223
extremesounds13
Anyone have anything that would show wiring for rear A/C on a 72 GMC burb. Mainly just need to know where the orange wire gets its power from, mine doesn't have power.
extremesounds13 is offline
Old 10-20-2012, 03:59 AM   #224
mikewayne
Hey thanks for such a good informative link as this has made it easy to understand the wiring patterns of these vehicles, as these electronics make a really important part of any vehicle and are the ones that are most tough to understand.
mikewayne is offline
Old 11-18-2012, 05:05 AM   #225
BrutonLS1
BrutonLS1's Avatar
Whats going on with these wires??? The picture is too distorted for me to tell
-Bruton
1968 GMC long bed 5.7/700R4
--I'd rather push a Chevy, than drive a Ford.--
BrutonLS1 is offline
