Old 02-12-2016, 09:59 PM   #201
tim's68gmc
tim's68gmc's Avatar
Re: 1968 Gmc ground up restoration
We got all the gaps looking good so now onto fill and sand to get ready for paint.
vehicle's I own 1968 gmc 3/4 ton camper special
1972 gmc jimmy
1972 Chevrolet nova
1947 ford 1.5 ton dully
1997 f-350 1 ton
2007 Chrysler 300 with hemi
tim's68gmc is offline   Reply With Quote
Old 02-14-2016, 10:07 PM   #202
tim's68gmc
tim's68gmc's Avatar
Originally Posted by swamp rat View Post
Did it have a grit? or was it the only black one available?
The sand i got from kleen blast is called tru grit fines that is what is on the receipts.
The sand i got from Mclendons is called sandblasting sand white #30.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 02-14-2016, 11:30 PM   #203
swamp rat
swamp rat's Avatar
Thank you sir! Was the Kleen blast the finer of the two? about the same?
Nice to meet you at the Swap meet Saturday too, hope you sold your goodies.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-20-2016, 10:52 PM   #204
tim's68gmc
tim's68gmc's Avatar
Prepped and put a nice thick coat of sand-able primmer. Now comes the fun of sanding smooth.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 02-20-2016, 10:53 PM   #205
tim's68gmc
tim's68gmc's Avatar
More primmer
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-13-2016, 12:05 AM   #206
tim's68gmc
tim's68gmc's Avatar
It has been a while of hand sanding and more hand sanding to adding some color
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-13-2016, 03:38 AM   #207
swamp rat
swamp rat's Avatar
I can tell that truck is gonna be sweet! Nice work.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-24-2016, 11:15 PM   #208
tim's68gmc
tim's68gmc's Avatar
Paint booth has been dismantled and it is time for assembly. Today we started with assembly of the box and the wood bed has 4 coats of polyurethane and started the fifth coat today.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-25-2016, 09:16 AM   #209
flashed
Looking great ,love the color .
flashed is offline   Reply With Quote
Old 03-25-2016, 04:21 PM   #210
benbloom
keep the pictures coming! thats going to be sweet
benbloom is offline   Reply With Quote
Old 03-26-2016, 01:11 PM   #211
swamp rat
swamp rat's Avatar
Looks great Tim!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-26-2016, 01:24 PM   #212
swamp rat
swamp rat's Avatar
Question about your paint booth:
The pic of the fans would be the intake right? and is it heated? want to get an idea how your heating the air?
I'm trying to build a mini paint booth about 5X6' in my garage.
Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-26-2016, 03:01 PM   #213
tim's68gmc
tim's68gmc's Avatar
Thanks!
i used the fans for exhaust i had filters at the other end for intake and used my shop heater to get the paint booth to 70-75 degrees
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-26-2016, 03:14 PM   #214
swamp rat
swamp rat's Avatar
OH, so in post #189 looks like you have filters covering the fans and are pulling the air thru with additional filters on the opposite side for intake?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-27-2016, 10:05 AM   #215
tim's68gmc
tim's68gmc's Avatar
that is correct.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-27-2016, 11:49 PM   #216
tim's68gmc
tim's68gmc's Avatar
we got lots done this weekend finished the insulation/sound deadening finished the dash less radio, installed the shinny new steering wheel, got the bench seat back from the upholstery shop, then started the wood bed installation.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-27-2016, 11:51 PM   #217
tim's68gmc
tim's68gmc's Avatar
page 2
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-28-2016, 12:10 PM   #218
davepl
davepl's Avatar
If you haven't done all the underdash wiring yet, you might benefit to keep the wheel off a while longer. Stick a tennis ball on the threaded shaft so you don't brain anyone on it, but it gives you a lot more room to work without the huge wheel. Just a thought from doing mine.
And, since I'm burning a post, you likely know but don't tighten down all the bed strips until they're all in and the bed is checked for square.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-28-2016, 12:51 PM   #219
tim's68gmc
tim's68gmc's Avatar
thanks davepl, the wiring is about 95% complete under the dash less radio and a couple grounds, and we are leaving the bolts loose so when its on the truck all square we will tighten, what a job that is trying to get the nut and washer in that channel.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-28-2016, 01:29 PM   #220
LPoole
LPoole's Avatar
You fellas are doing a great job. Love the color. Also like the cab / dash / sound insulation. Keep up the good work. Giving me lots of great ideas for my old truck.
Better to remain silent and be thought a fool than to open your mouth and remove all doubt. - Mark Twain
LPoole is offline   Reply With Quote
Old 03-28-2016, 02:01 PM   #221
TexasLS1
TexasLS1's Avatar
Don't know how I missed this build; nice work. The colors look great and I love the paint booth!!
TexasLS1 is offline   Reply With Quote
Old 03-29-2016, 02:39 AM   #222
Alex4x4low
Excellent restoration, beautiful color, everything very clean as it must be. I will be still attentive of the progress. Congratulations from Sonora Mexico for this project
Alex4x4low is offline   Reply With Quote
Old 03-29-2016, 07:41 AM   #223
tim's68gmc
tim's68gmc's Avatar
Thanks for the comments Lpoole, Texasls1, Alex4x4low it has been fun building this with my son. The color is a dark blue with metalic and depending on what angle you are looking it could look blue, black or purple.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-07-2016, 05:42 PM   #224
tim's68gmc
tim's68gmc's Avatar
more work getting done
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 04-25-2016, 10:21 AM   #225
tim's68gmc
tim's68gmc's Avatar
Ok been a little while sense i posted the truck is about 95% complete, have a few little things to tinker with.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
