04-19-2016, 11:11 PM | #201 |
I'm trying....
Re: Hemi's 70 Blazer build
unum dura mater
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
04-27-2016, 11:41 PM | #202 |
Dan. Did you get your tailgate letters from Bill's or where?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
04-28-2016, 09:02 AM | #203 |
04-29-2016, 07:39 PM | #204 |
I'm trying....
Just noticed the avatar change. Usually puts the official pin on the build thread. Looks good. I expect you are going to have a fun summer.
04-30-2016, 04:58 PM | #205 |
I got to see this truck in person today. Everything is top notch! Very well done. Also got to meet the owner and son. Nice to meet you and hope to see you soon.
06-04-2016, 03:04 PM | #206 |
I just found my street rod that I sold last year while surfing the web. I sold it so I could build my Blazer because I wanted something more usable. Holy crap they're asking a lot for it !! The least they could have done is detailed the underside before taking the pictures. Kinda sad to see it end up on E-bay.
http://www.ebay.ca/itm/Dodge-Other-2...853&rmvSB=true |
06-04-2016, 09:13 PM | #207 |
UMH.....holy EZRXTRCJYTVGKHBKJNLM:<":> omg! That thing is rowdy! I might have to really think about it before I got rid of my Blazer to keep that.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-08-2016, 08:15 PM | #208 | |
Posted via Mobile Device |
06-08-2016, 08:52 PM | #209 | |
The calipers mount to a custom made 1/4" thick backing plate. I've got about 1500 miles on it now, and it stops as well as my new truck. I'm extremely happy how the conversion worked out. |
06-09-2016, 12:03 AM | #210 | |
06-09-2016, 08:47 AM | #211 | |
Even with a CNC mill or lathe, these will have to be made out of two pieces. There's not too many parts that can't be machined by CNC, but this is one of them , even though it looks like a simple part.This part would be perfect to duplicate on a 3D printer. The biggest problem is the surface that sits against the inner door panel. It's a curved surface that's at an angle, which by itself would be easy to machine, but the problem is the stub that fits inside the door. It's difficult to explain in words. I still have one original plastic one that I could take close up pictures and measurements if you wanted to make some? Dan |
06-09-2016, 09:24 AM | #212 | |
https://youtu.be/dvGtw1Qk1F0 I agree 3D printing would be much easier. If I can make a 3D drawing of it then I may be able to find someone to print it - but I think I will prefer aluminum Last edited by Tomo; 06-09-2016 at 09:43 AM. |
06-09-2016, 11:18 AM | #213 |
I guess I should have said they can't be machined on a 3-axis mill. If someone has access to a 5-axis or that flip jig then it's doable, but for only 2 pieces it's not worth the effort. It only took me about 20 minutes to machine them manually from brass. I'll try and get some measurements in the next day or so.
07-06-2016, 01:57 PM | #214 |
ok if I really zoom in it looks like you have a oh **** handle for your passenger. did you make it or buy it?
07-08-2016, 04:39 PM | #215 |
Sorry for the late reply, I must have missed your post. I made those handles from 3/4" 1/8 wall DOM, and slipped a foam rubber grab handle over it. There's also a threaded backing plate inside the A pillar to bolt them to. They work well, and I could probably lift the truck with them.
07-10-2016, 10:07 AM | #216 |
My wifey wants one!!
07-17-2016, 03:31 PM | #217 |
Dan good meeting you yesterday at the Syracuse Nationals. Truck also looks awesome in person!
07-18-2016, 11:12 AM | #218 | |
Dan |
10-12-2016, 08:55 AM | #219 |
Hoping you can answer a question for me. I believe you used nylon fuel line for the tank to rail. Did you go all the way to the rail with the nylon?
Thanks, David |
10-12-2016, 11:14 AM | #220 |
I used nylon all the way from the in-tank pump to the fuel rail on the engine, as well as the return line. Beautiful stuff to work with, and I will never use steel line again for any future builds.
10-12-2016, 11:49 AM | #221 | |
Same question about trans cooler lines. Did you use rubber at the cooler or steel all the way? I appreciate your input. David |
10-12-2016, 02:13 PM | #222 | |
The reason the factory uses a braided "buffer", is because they used steel lines. The nylon flexes enough that this isn't necessary. The only thing you need to watch out for is to keep the line away from any heat sources like exhaust. I also wrapped the lines with a split rubber hose anywhere ther was a chance of chaffing. For extra safety, I tie wrapped the fitting on the fuel rail at the engine so that it can't pop off and cause a fuel leak. For the transmission lines I used Cupro-nickel 3/8 tubing along the frame and hydraulic flex lines to the transmission. Way overkill, but I know it will never give me issues. |
10-12-2016, 06:47 PM | #223 | |
Would you mind sharing some details on this custom conversion kit? Photos of backing plate & details of the mods would be great! I also have a 70 (it's not going to be done nearly as fast as yours...) & I really like this option compared to the price of a conversion kit or replacing the entire front diff. I'll also be doing an LS swap so I will likely take the calipers of the donor truck. Great work on your blazer - really like your color choice. Hope you're enjoying it! Thanks, Tom |
10-13-2016, 07:46 AM | #224 | |
10-13-2016, 08:39 AM | #225 | |
