Old 09-22-2016, 10:39 PM   #201
Tikal48
Tikal48's Avatar
Re: Harold's '48 S10 LS1 Build
Originally Posted by Flysocal View Post
I really like the fuel door. I wonder if there is enough curve in it to work on the fender?
I was seriously looking at putting the gas door on the front side of the fender. But it definitely looking like it was going to take quite a bit of work. It would have given me a little bit more elevation of the gas neck above the gas tank. The S10 door has a slight radius in a single direction, which I was able to straighten out very easily. The radius on the '48 is going in two directions. I was planning on saving the hinge and replacing the skin and fabricate a new recess.
I'm happy with the way it came out and it was not that difficult to do. But in the fender would have definitely looked awesome.
Tikal48 is offline   Reply With Quote
Old 09-22-2016, 11:06 PM   #202
Tikal48
Tikal48's Avatar
I got the driver side bed side and fuel door sanded and in epoxy primer.
I received my Gel coat and PVA, so I decided to get the wheel tub mold cast today. This didn't come out too bad. I have a few other things going on before I try to cast one of the tubs.
Old 09-23-2016, 09:06 PM   #203
Tikal48
Tikal48's Avatar
Another full day of body work. I opened a couple of windows in the rear cross support, where I could access the top of the license plate recess. I added a filler piece below the tail gate to get rid of the ugly gap. I also welded out the edges of the roll pan. Just a little more sanding and I can get this primed.
Old 09-24-2016, 07:31 AM   #204
slammed57
slammed57's Avatar
Its been a while since i checked in..doin some great work...looks like i need to check in more often. Keep the mods comin.
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 09-24-2016, 10:35 PM   #205
Tikal48
Tikal48's Avatar
I at least got all of the rear sheet metal primed, except the driver side fender. Now it can rain all it wants. I got a lot done, but I cut the gap a bit close on the rear roll pan. I will go back and fix this later. It looks a lot better without the huge gap that was there before.
Old 09-25-2016, 03:52 AM   #206
av8tr33337
av8tr33337's Avatar
Looks awesome.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 09-25-2016, 11:29 AM   #207
99 to Life
99 to Life's Avatar
you are moving right along. you keeping track of hours? I know I'd be.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-25-2016, 12:25 PM   #208
MIKESAD50
Looking good and nice progress
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 10-01-2016, 09:53 PM   #209
Tikal48
Tikal48's Avatar
I finished welding the tail light housings in the driver side fender and have the All-metal body filler applied and sanded out. I will prime it tomorrow.
I decided to work on the gas filler neck, and the neck housing. This wound up being a pain to fabricate, but for the most part, it is done. The bottom mounting hole is almost in line with the housing side wall. I still need to add a bit of a recess to clear the cap screw. I also need to do a bit more clearance grinding to clear the door hinge.
Old 10-02-2016, 10:10 PM   #210
Tikal48
Tikal48's Avatar
I added the recess and final bolting pad to the gas neck housing. I roughed in the body work and shot it with some epoxy primer. I will do the final touch ups later.
Old 10-02-2016, 10:40 PM   #211
Tikal48
Tikal48's Avatar
I decided to cast one of the wheel tubs to kill the rest of the day. I made some final touch ups on my wheel tub mold and prepped it with some PVA. One good coat of gel coat and I laid 4 layers of glass. I will pop this out of the mold tomorrow. I want to get both cast, where I can cut the bed sides for the wheel clearance. I also need to install the bed side angle pieces.
Old 10-03-2016, 10:42 AM   #212
99 to Life
99 to Life's Avatar
you should quit your day job!!! nice work
Old 10-03-2016, 08:38 PM   #213
Tikal48
Tikal48's Avatar
Thanks 99! I appreciate the words of encouragement, but I'd probably starve to death from being too slow. . . LOL
Well for my first molded fiberglass part, it didn't come out too bad. I did wind up with the few small areas on the bottom flange on one side that I need to fix. Other than that, its not too bad for the first attempt. I will try to cast the other one next weekend.
Old 10-03-2016, 11:29 PM   #214
chev3600
chev3600's Avatar
Wow. The tubs turned out really nice, Keep it up.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 10-08-2016, 09:11 PM   #215
Tikal48
Tikal48's Avatar
I received my stainless exhaust pipe and welding wire and started fabricating one of my exhaust tips. The wire welder did okay, but I wish I had my TIG welder working. I don't have a garage where I can set it up. I guess that I need to stop working on the truck and build a garage. . . Or not.
I need to modify the front lower corner of the receiver box. The corner is visible below the running board. I will cut and round the corner to make it less visible.
Old 10-08-2016, 09:25 PM   #216
Tikal48
Tikal48's Avatar
Here are a few shots of the exhaust tips. I have the tips sticking out 1" from the edge of the running boards. I don't think that they will be too much of a shin knocker. Just enough where you can see them good.
Old 10-10-2016, 09:25 AM   #217
99 to Life
99 to Life's Avatar
nice work
Old 10-15-2016, 11:14 PM   #218
Tikal48
Tikal48's Avatar
Not a whole lot of progress today. I pulled the driver side exhaust tip back off and rounded the front lower corner. I also completed the fabrication on the passenger side exhaust tip, and got it mounted under the running board. I still need to fabricate the exhaust tip inlets.
Old 10-15-2016, 11:18 PM   #219
Advanced Design
Advanced Design's Avatar
Very nice work on the exhaust tips. I really like how they exit and the theme matches the hood.
Advanced Design is offline   Reply With Quote
Old 10-16-2016, 10:21 PM   #220
Tikal48
Tikal48's Avatar
Well I've been kicking the can down the road long enough, so I decided this morning to start on the passenger side door. I measured and marked the door and inner door skin and cut them to match. I tacked the inner skin and test fit on the truck. As careful as I was, I still had to re-cut the inner skin to adjust the fit. I had to cut 1/4" out of the front side of the inner door skin. I was able to get the skin re-tacked and re-checked the fit.
Old 10-17-2016, 10:08 AM   #221
99 to Life
99 to Life's Avatar
nice, where is the patch from? I made mine by hand. The corners were the hardest part.
Old 10-17-2016, 09:15 PM   #222
Tikal48
Tikal48's Avatar
These are Dynacorn re-pops. It is actually not a bad looking piece. It had a couple of areas that I will have to touch up, but it beats me having to try to reproduce the panels. This truck is the only sheet metal experience that I have. I might have attempted to make the repairs now without these panels, but I bought them last year, so I might as well use them.
Old 10-22-2016, 10:26 PM   #223
Tikal48
Tikal48's Avatar
Here are a few shots of the inner and outer skin replacement. After rolling the side and lower edges, I re-hung the door and checked the fit. I had to cut and bend the window frame out to align with the top of the opening. I have a lot of work yet on correcting the gap around the door.
Old 10-23-2016, 11:04 PM   #224
Tikal48
Tikal48's Avatar
Working on the door gaps today. I shaved the drip rails over the doors, which left me with a large gap over the doors. I added a strip to the top of the door to close the gap up. I still have a little touch up to do with some All-Metal on the inside of the door frame.
The gap on the back side of the door was too close. I had to grind the lip back and weld the edge. I am doing a short section at a time and rough grinding it close. I will apply some All-Metal and do all of the final sanding of the edges when I get all of the edges fixed.
Old 10-24-2016, 12:47 AM   #225
iowaboynca
iowaboynca's Avatar
very nice attention to detail. Keep it up.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
'48, bearclaw, ls1, s10
