11-20-2015, 02:57 PM | #201 |
Re: High School Project Build II
Putting new copper-nickel rear brake lines
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
11-20-2015, 04:01 PM | #202 |
It's a roller
11-20-2015, 04:36 PM | #203 |
Looking good .
11-20-2015, 06:29 PM | #204 |
You guys are making great progress. Looks good!
11-30-2015, 10:21 AM | #205 |
Well here our donor - 125894 miles
11-30-2015, 10:23 AM | #206 |
Disassembly has begun
12-02-2015, 01:39 PM | #207 |
Motor out
12-02-2015, 02:35 PM | #208 |
I like the idea of getting the complete vehicle, especially if you retain the factory computer and such. There's sooo very much stuff on the market to convert a LS into anything. I favor hooking it up the factory way. GM made the best drivetrain stuff, period, don't have to even say a word about the engine. Not many folks insane enough to do this w/ a stink'n dodge or ford...
12-02-2015, 05:53 PM | #209 |
The LS engine family is impressive for many reasons. As one example, look at this cylinder wall in a 5.7 from an 02 Firebird with 160k. No ring ridge and the cross hatch is still visable.
12-03-2015, 03:55 PM | #210 |
Fab work on our top rear shock brackets and using a front shock on the rear
This will help get a better angle for the shock
12-03-2015, 05:05 PM | #211 |
6>8 Plugless........
Nice work you guys!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-07-2015, 03:11 PM | #212 |
Welding nuts onto the broken exhaust studs to remove them
12-07-2015, 03:36 PM | #213 |
30 seconds broken stud removal
12-07-2015, 04:00 PM | #214 |
Awsome trick i learned it from a exhaust shop i worked at after school back in the day. Things like this can't be found in book but can be learned from a true craftsman .great job passing down the tech tips like this one.
12-08-2015, 11:01 AM | #215 |
Drilling and tapping for new temperature sending unit
12-08-2015, 03:49 PM | #216 |
Boyd tank and pump is installed, this is one "nice" tank. Thanks Dave Boyd
12-08-2015, 03:50 PM | #217 |
Boyd's tank
12-09-2015, 11:51 AM | #218 |
Making motor mount plate
12-10-2015, 01:28 PM | #219 |
Putting motor in
12-11-2015, 01:44 PM | #220 |
Motor is in - now we have to pull it to notch the motor mount to clear the manifold
12-11-2015, 03:29 PM | #221 |
Wow ,that looks good .
12-11-2015, 09:00 PM | #222 |
You might as well fabricate new engine perches from scratch because the amount of work is about the same by the time you hack up the originals and re-work them.
12-12-2015, 01:40 AM | #223 |
Looks Awesome!
1971 GMC Sierra Grande 2500 2wd "Sadiee" Caddy 472/TH400 Project "Sadiee" 1969 Chevy C/10 Build "Maisie" Thread coming soon |
12-12-2015, 01:55 PM | #224 | |
No - we sliced the edge off drivers side corner and welded it back up - about 15 min job
12-16-2015, 09:58 AM | #225 |
The Yukon driveshaft was 1" to long - so we changed out to an old style yoke and it fit perfect
