Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 05-28-2018, 03:09 PM   #201
Mr_Rich
Mr_Rich's Avatar
Re: 97 3500 454 4x4 project
Originally Posted by mingoman View Post
Not a lot going on right now, it's cold, well, by Arkansas standards at least. I've been gathering a few parts though, the metra dash, a back bumper, it's a black powder coated westin bumper and since the under dash panel had holes drilled in it, I picked another one up. I cleaned the dash and panel up, wiped them down in alcohol, and dyed them to match my dash. My radio is on the way!
Have you had any problems with the fitment of the vent on the left side of the dash? I have the same dash plate out and the left doesn't mount as cleanly as the right side vent does. I think I'll have to take a pic of that.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 05-28-2018, 03:21 PM   #202
mingoman
Let me check. I haven't noticed anything odd about it yet, but it isn't snapped completely in yet either. I'm not entirely happy with my bezel lights so it's coming back out.
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 05-31-2018, 07:19 PM   #203
mingoman
Not much going on waiting for the painter, but I did take advantage of the 15% off memorial day weekend sale from super bright led. I picked up the clearance lights for the cab and the under hood light shown here. I'll have to wait till after the paint to see how much brighter the cab lights are.
76/77/78 Cheyenne
Old 07-19-2018, 07:53 AM   #204
LT7A
And hopefully your painter is getting close. If not, have you thought about just having him paint the tailgate and just touching up the rest of the truck? The white should come back really well with some compound, etc. The nice thing is that it doesn't fade like some other colors do.
Old 07-19-2018, 08:50 AM   #205
mingoman
Actually I'm checking on painter #3. I'm taking it to have the trans checked out and probably rebuilt next week, it won't stay in OD, then if I haven't heard from painter #2 It's going to #3.
76/77/78 Cheyenne
Old 07-19-2018, 09:20 AM   #206
Terrick down Under
Terrick down Under's Avatar
Yes, get the greazy work done before shinny new paint!
Terrick down Under is offline   Reply With Quote
Old 07-30-2018, 10:50 AM   #207
mingoman
In typical fashion for me the transmission guy couldn't fit my truck on his lift so I'm going to have to pull it. Since I was that close, I ran it by painter #3 and he's supposed to get started on it in about 3 weeks.
I'd planned on the 8.1L swap being at my leisure after I had this on the road again, but if I'm pulling the trans anyway, I may as well do it all at once.
76/77/78 Cheyenne
Old 07-30-2018, 05:19 PM   #208
Terrick down Under
Talk about “running flat out!”, thats a lot of work, but should be worth every bit of effort you put in.
Old 08-05-2018, 09:35 AM   #209
mingoman
Parts are coming in. I'm going to change to the 2004 and up style cam sensor so a new sensor, timing set, and cover were needed. Ordered a express van balancer and the correct alternator bracket, four seasons fan, hd fan clutch, and new oil pump shaft.
The compression is excellent and all the plugs are clean so I may install the engine as is.
I am getting new intake gaskets and 65mm bolts.
Anyone know of a source for gm corporate blue paint as good as por 15 or Eastwood?
Eastwood discontinued and I'm not sure how long rattle can paint will look decent.
May end up going Chevy orange or black, but I was trying to be a touch different.
76/77/78 Cheyenne
Old 08-06-2018, 02:45 PM   #210
mingoman
Working on swapping over the timing set while I'm off today. I had to pull the old balancer off with a three jawed puller, which was a first for me. The old 2002 style set had hardly any slack so I'm feeling better about the quoted miles on this engine.
I also downloaded the 8.1L factory service manual from the 8.1L classified fb page for free. It's a huge and invaluable wealth of information on these engines!
76/77/78 Cheyenne
Old 08-06-2018, 07:34 PM   #211
mingoman
Done for the day. The new timing set is in and I pulled the oil pan off and installed a new pump shaft. The motor is very clean in the bottom end, I could still see the cross hatch pattern in the cylinders. Also installed a new crank sensor while I was at it.
76/77/78 Cheyenne
Old 08-07-2018, 03:44 PM   #212
mingoman
Had to borrow a balancer installation tool to get the correct balancer on, but it went on pretty easy. My water pump should be in later today then I've got to go over the list I copied from Larry's thread for the bolts and miscellaneous things I've got to buy.
I've not listed any of the part numbers since they are up in several places on different forums and such, but if anyone needs something specific just ask. I'm basically using Larry's thread as a guide.
Also, I did pay for my paint today so here's hoping it gets sprayed in my lifetime lol! They took a pic of my wife's vin tag and matched it with their computer. I have seen it all!
76/77/78 Cheyenne
Old 08-07-2018, 05:19 PM   #213
Terrick down Under
So, my forgettery is working...what color are you going for?
Old 08-07-2018, 07:28 PM   #214
mingoman
The same as my wife's Subaru, crystal white pearl with the fender flares black.
This isn't her car and you can't really see the pearl in the pic, but maybe it'll give you an idea.
76/77/78 Cheyenne
Old 08-13-2018, 07:05 AM   #215
Terrick down Under
Yep could not see it on my phone, but the desk top makes it look ok. Have you thought about painting the flares the same colour as the body? Then do the blackout around the side windows????
Old 08-24-2018, 02:05 PM   #216
mingoman
I've got all my brackets in , have to get the correct ac compressor still, but I wanted to do a quick mockup to make sure it all looked correct, it does.
I took the injector rail off the intake and removed the injectors to clean and install new o rings. I'll paint the engine before before they go back on.
I did find my gm corporate blue paint at Bill Hirsch btw and a big truck salvage yard in Colorado had the zf power steering pump I needed plus he threw in another zf style bracket, the fittings, and pulley to boot.
I may use them too one day since I picked up another 8.1L as a spare.
76/77/78 Cheyenne
Old 08-24-2018, 06:57 PM   #217
mingoman
After cleaning with simple green, gojo, then soap and water I had to paint the intake just to see how it would look.
76/77/78 Cheyenne
Old 08-24-2018, 07:00 PM   #218
Terrick down Under
Everyday, a little bit closer!
Old 09-12-2018, 01:49 PM   #219
Babysis
I have HOT PINK fuzzy dice waiting for you!!!!! Hurry up with getting the truck done already! Geez!!!!
Babysis is offline   Reply With Quote
Old 09-15-2018, 10:34 PM   #220
mingoman
I expect those for Christmas then!
76/77/78 Cheyenne
Old 09-15-2018, 10:37 PM   #221
mingoman
Derrick has been working on the truck and sent me a few pics today. The cab is coming along.
76/77/78 Cheyenne
Old 09-15-2018, 10:40 PM   #222
mingoman
However, he said the bed looked like it was in a wreck, fixed, then another one on top of that. Since the bondo was a couple inches thick in spots I'm going to see about finding yet another bed.
76/77/78 Cheyenne
Old 09-16-2018, 05:47 PM   #223
Wide Open
Sorry dude I know that sucks.
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 10-13-2018, 01:02 PM   #224
86454k30
86454k30's Avatar
Very nice work on your project.
86454k30 is offline   Reply With Quote
Old 10-13-2018, 01:16 PM   #225
mingoman
Thanks! I've found another bed btw and I'm waiting for the guy that owns the yard to get it pulled. He has to move quite a few vehicles to get to the bed I wanted.
76/77/78 Cheyenne
