Old 01-13-2021, 11:44 PM   #201
Mains52
Re: "52 3600/3100"
Originally Posted by joedoh View Post
yeah but I bet it was a fun 2 hrs!
looking good!
Thanks! You're right its always fun fabbing stuff up.
Mains52 is offline   Reply With Quote
Old 01-14-2021, 10:57 AM   #202
dsraven
Re: "52 3600/3100"
looks good. the only thing I wouldda done different is make it a bolt on. thats just me though.
whats the plan for the old cross member? are you gonna connect the dots for frame flex concerns without the cross member where it used to be? remove it entirely? something different?
Old 01-14-2021, 11:22 AM   #203
dsraven
Re: "52 3600/3100"
where are you measuring your angles from? oil pan flange on block?
Old 01-14-2021, 12:32 PM   #204
Mains52
Re: "52 3600/3100"
I will probably just take the remaining parts of the old member out. Art Morrison only has the MII, trans and drive line x member so I figure Ill keep it like that. I am measuring the angles from the tailshaft of the trans.
Old 01-14-2021, 05:53 PM   #205
dsraven
Re: "52 3600/3100"
a more accurate reading of the angles can be had by using the oil pan mounting surface. sometimes the play in the rear trans bushing can make the angle gauge lie when it is using the ujoint or the yoke. you prolly have it dialed in the way you want it now but if you need to change it later you can always use a shim under the trans mount to jack the trans end up some if needed. otherwise slice a piece out of the square tubing under the trans mount and weld it back in lower, if it is already too low.
keep plugging away man. looking good.
Old 01-14-2021, 05:57 PM   #206
dsraven
Re: "52 3600/3100"
sometimes the frame flex can make the cab mount points become closer or further apart. time will tell. could be horsepower/horseplay related for some trucks I suppose, lol. I remember having an old V8 Vega back in the day. sometimes I had to do a burnout in reverse so the doors would close. haha. no subframe connectors on that one. sold it too soon to finish it properly. I remember it went like stink though.
Old 01-15-2021, 08:47 AM   #207
Mains52
Re: "52 3600/3100"
Backwards Burnouts ha I may do some more bracing. I am still unsure. The 3:08 rear end on the back of a high mileage 5.3 probably isnt going to be twisting any doorways ha.
Old 05-27-2022, 01:38 PM   #208
Mains52
Re: "52 3600/3100"
As usual Its been over a year since I touched the truck. There is 8 weeks until GoodGuys and my brother told me we should bust ass and try to get it driveable by then. Its most likely not going to happen but it has given me a reason to push the build along and get my butt back into the truck side of the shop. Racing MX with my son every weekend takes a lot of my free time but its time for some all nighters.
Old 05-27-2022, 03:21 PM   #209
dsraven
Re: "52 3600/3100"
No pics, didnt happen. Lol
Old 06-08-2022, 08:18 AM   #210
Mains52
Re: "52 3600/3100"
Got the passenger side cowl going. Just need to finish it up so I can move on to finishing the bed and running boards. Also got the 5.3 completely torn down. Thankfully I went with my gut and tore it down because the " low oil pressure" that the previous owner was having could have been from the roached / stuck cam bearings and lack of maintenance. To be fair the main and rod bearings weren't too bad and the cylinders still look good but will get ball honed. 175k miles of crappy maintenance I expected some of this.
Old 06-14-2022, 09:43 AM   #211
Mains52
Re: "52 3600/3100"
Well after selling my motovan and having a stack of cash to put into the truck I decided id get a running driving 5.3 to hook up and drop into the truck since my other engine is now going to be a full rebuild. So I found a local guy who does ls swaps for a living and he just pulled a 160k mile 5.3 out of a silverado last tuesday. Ran great and had no issues. Picked it up complete with pcm and harness for 600. Also after a year of dragging my feet I bought my second project for the family and brought home my new 1939 Chevy Master 85. Needs some love but 98% of the parts are there and it was on the road in the early 2000's so I know it can be a runner while the truck gets finished.
Old 06-14-2022, 09:45 AM   #212
8man
Re: "52 3600/3100"
Cool car. Nice find on the 5.3 too.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-14-2022, 09:58 AM   #213
Tempest67
Tempest67's Avatar
Re: "52 3600/3100"
I have always liked the 'Businessman's Coupe' body style....... nice
Tempest67 is offline   Reply With Quote
Old 06-21-2022, 03:16 PM   #214
Mains52
Re: "52 3600/3100"
Alright the countdown is on. I have a ton of parts on the way and with a good effort and a little bit of luck I should be able to have my truck on the road by my birthday 8/30. I really think my GOODGUYS DES MOINES goal was a bit crazy since I am doing all of the work myself. I got the good ol "AFTER THE KIDS ARE ASLEEP" Shop shift so I may be low on sleep by the time its done but Im driving this damn truck this summer. Wont be painted but it will be on the road.
With all of that said. This past friday I took the day off work and went to a local salvage yard. picked up a steering column, brake booster/pedal set up along with the gas pedal set up for the truck and started mocking it up.
Old 06-21-2022, 03:23 PM   #215
dsraven
Re: "52 3600/3100"
do you recall what the booster set up was from? I am using a set from an envoy which has the booster and pedal set up allk in one. cut a hole in the firewall, bolt it in. are your pedals integral with the booster mounting panel?
Old 06-22-2022, 06:52 AM   #216
Mains52
Re: "52 3600/3100"
It was out of a 2007-2013 Silverado 1500 single cab 2wd.
Old 07-08-2022, 03:17 PM   #217
Mains52
Re: "52 3600/3100"
Update: The LS RUNS!!! Tested it on the stand. Steering mocked up ready to be permanent. Fuel Cell mocked up. LOTS of Parts coming in. Big push is about to go down to get it put together.
Old 07-08-2022, 03:23 PM   #218
8man
Re: "52 3600/3100"
Big day, vroom, vroom noise!
8man-aka Robert
Old 07-27-2022, 12:13 PM   #219
Mains52
Re: "52 3600/3100"
BIG UPDATE: So boxes started rolling in a few weeks ago and I have been busting some serious butt to try and get this thing together. I may not have pics of it all but.....
List of Stuff I have done.
Mocked up ad finished steering.
Brake booster and pedals mounted.
Steering column mounted.
frame notched for exhaust manifolds.
Seat mounted.
Driveshaft mocked up/ measured but not done yet.
outer cowls ready to be finished up.
Trans tunnel started.
I have everything to drive the truck besides rad hoses, internal harness for my 4l80e to update it, fluids and Registration.
Old 07-27-2022, 12:19 PM   #220
Mains52
Re: "52 3600/3100"
Big update continued:
So I was installing the new fly wheel on my 5.3 and it decided to crash to the ground and break the oil pan. Its ok I have another truck pan but dang talk about set back. Also this past Monday I had 8hrs of free time to bust out as much stuff on the truck as possible. Well in the first 30 minutes of said free time I had a cutoff wheel on a grinder decide it wanted to jump off the part I was cutting and catch an artery in my shoulder. I really want to get this thing driving but its going to fight me the whole way.
Old 07-27-2022, 12:46 PM   #221
8man
Re: "52 3600/3100"
Dang! That's a tough break. Hope you heal quickly.
8man-aka Robert
Old 07-28-2022, 03:11 AM   #222
NorCalGal
NorCalGal's Avatar
Re: "52 3600/3100"
Uh oh, the wheel of death strikes again! That’s some scary stuff, as bad as it is it could have been way worse. Hope it heals quickly.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 07-28-2022, 07:04 AM   #223
Mains52
Re: "52 3600/3100"
Thank You all
Old 07-29-2022, 12:09 AM   #224
joedoh
joedoh's Avatar
Re: "52 3600/3100"
dude holy hell.
question, was it a plug in grinder? or a batt grinder? lately i have been using a batt grinder for my cutoff wheels because when they get stuck they just stop. the plug in i have just pours on the torque, I caught my t shirt once with a braid cup once and had to unplug it, it was still trying to spin.
hope you heal quick!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-29-2022, 09:43 AM   #225
Mains52
Re: "52 3600/3100"
dude holy hell.
It was a plug in push/lock power button. It hit me then was trying to wrap my shirt towards my face so my first focus was on getting it shut off after I killed the power I felt the warmth pouring down my side. Im bummed I lost that 8hrs of uninterrupted truck time. Im switching to a plasma cutter from now on.
