11-11-2019, 07:12 PM | #201 | |
Re: 57 Chevy Wagon - Californa Dreamin'
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
11-12-2019, 04:07 PM | #202 |
One of the design elements I'm planning to use is a knockoff of the Project X 57 Chevy grille bar. When the guys on HotRod Garage removed it to make way for a stock bar, I got a closer look at how it was made and realized I'd never be able to duplicate it, since it was CNC'd from a single block of aluminum as I'd suspected. I don't possess the programming skills, machining capability or the bankroll to make it happen. So I'm taking the poor boy way out...
I decided to use the grille bar that came with the car as my starting point. The chrome on it was blistered and it would have to be replaced anyway. So the plan was to cut away the round turn signal portion of the bar and replace it with a couple of pieces of flat stock formed to follow the curve of the bar. I've had some Muggy Weld zinc rod for a long time and never used it so I figured it would be perfect for working with the pot metal. My first attempt was with 1/8" thick 5052 and was a spectacular fail. Called the guys at MW for advice and they said my flux was way too old to work. So I ordered a new bottle and when it arrived, I tried again, but with no luck. So I switched gears to something I knew would work - ultra formable 260 brass. The zinc rod took to it as easily as it did the pot metal. I cut out the lower half on one side of the parking light bulge and fit the .094 brass stock I'd formed into the opening. Soldered both sides then cut away the top half and repeated the process. Took it slowly in steps and used a wet washcloth clipped to the previously soldered areas to sink away the heat. The last thing I wanted was to have the whole mess get too hot and fall off. Once all the seams were soldered inside and out, I used a small air grinder, a bastard file and a D/A with 80 grit to prep it for All Metal. The picture with the yellow tape shows the cut line for the final width. Now I just need to repeat on the other side.
11-12-2019, 10:01 PM | #203 |
Post Whore
that turned out good Vic..!!!!!,,,are you gonna chrome plate it?
11-13-2019, 12:34 AM | #204 | |
There's a guy in KS I talked to a few years ago that does spray chrome. Don't know if he's still doing it, but I remember he wanted to do 100% of the filler and prep work himself to guarantee the job. IIRC, he wanted around $750 to do a bumper, not including the prep work. Irrespective of cost, I have a hard time handing off a half finished part to someone and trusting they can complete it the way I see it in my head.
11-16-2019, 07:22 PM | #205 |
The grille bar is ready for epoxy primer and filler. I sent a text with some pictures of it to the sandblast guy not too far from me. He wanted $250 to blast the remaining chrome off it. Took a pass. Instead, I used the DA to remove most of the chrome/nickel and then stuck it in the glass bead cabinet to rough up what was left. It hung out the end of the cabinet, but I draped a towel over the opening and it didn't make too much of a mess. Just some copper and pot metal left now. Epoxy will bond to it with no problem.
I did some research on spray chrome and I'm tempted to give it a try. The videos make it look easy (as you'd expect). They say the reflectivity is about 95% of actual chrome. For just the bar, which sits in the center of the grille all by its lonesome, it might just work. I also got started on the bumper bullets. I used the plasma cutter to remove the centers and then a carbide burr in a die grinder to get up to the line that was stamped in them. I put one up in the mill and used a boring head to open it up the rest of the way to fit the light (Dakota/Durango lamp). Next up will be to figure out how to attach the bullets to the bumper.
11-17-2019, 06:48 PM | #206 |
After carefully marking the new smoothie bumper, I took a deep breath and used a 3" hole saw to open up the necessary clearance for the new parking / turn signal lights. Normally, I hack away without regard to the consequences since I figure a Sawsall, welder and grinder will fix anything, but in this case I really didn't want to buy another bumper. 3" was probably overkill, but I had plenty of room and there wasn't any need to conserve the space. My current plan is to weld some threaded tabs to the bumper bullets (which will require chroming anyway) and drill holes into the bumper for the fasteners. Mulling over the best location for said tabs but the photo with the arrows shows a couple of potential spots.
11-18-2019, 07:25 PM | #207 |
Here's a look at how I fastened the bumper bullets to the smoothie bumper. I made some small threaded tabs and marked their location inside the bullets. Then I drilled two slightly oversized holes for the 1/4-20 fasteners that attach on either side. Mocked up the final location by threading the fasteners into the tabs and then set the bullet down in place. Used the MIG to tack the tabs to the bullets then removed the assembly and TiG welded the tabs more securely.
As you can see, the tabs draw the bullets down firmly in place and provide plenty of clearance for the backside of the lights. Found the correct pigtails for the 899 halogen lights on eBay and got them on the way. Still a long way to go before wiring, but that should give me more than enough time to misplace them.
11-19-2019, 10:41 AM | #208 |
Looking good Vic! I've been gone too long and had a ton to catch up on. You've done quite a bit since the last time I checked in on your build. Nice work! Keep it up.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
11-28-2019, 12:22 PM | #209 | |
And Happy Thanksgiving to everyone! I know I have a lot to be thankful for.
12-04-2019, 12:04 PM | #210 |
Happy Thanksgiving! I gotta come by and check on this!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-05-2019, 10:48 AM | #211 |
Proprietor of Dale's Corner
It's all looking great. I vote on the chrome paint on the grill bar. That way you can tell us how it works and your thoughts on the process.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
12-05-2019, 11:51 AM | #212 | |
Thanks, Chip! You know you're always welcome whenever you're in the neighborhood. Reminds me, I need to give your ole dad a call.
Speaking of which, picked up the front bumper bullets yesterday from the plating company. This is the first chrome they've done for me. I've mainly had them do zinc plating previously. I thought they turned out really nice. Chrome can be a bit of a crapshoot so it's a relief they did a great job.
12-13-2019, 07:35 PM | #213 |
Been welding and grinding on the door edges to prep them for the filler I'll use to set the gaps. The patch panels I made for the bottom third of the doors didn't always end up where I planned, so a do-over is required. The gaps were pretty good from the factory on this old wagon, but there are always a few places that could be better.
I didn't like the way the dividers between the doors looked after moving the latch hardware around for the suicide rear doors. When the doors are open, you could see the recess from the stamping process on the backside. So I made a poster board template and transferred it to some flat sheet metal. With it welded in and ground smooth, it adds a ton of strength to the divider, plus it makes it look a lot nicer as well. The good news is, I'm running out of metal fab on the body shell and should transition to body filler in a week or so. I'll still need to do some fabrication work under the hood when I get the body on the frame and the front clip reassembled, but I can use the break.
12-13-2019, 09:44 PM | #214 |
Post Whore
Looks great..!!
12-14-2019, 12:38 AM | #215 |
Thanks, Greg. I'll be glad to finish up the metal fab. Just suiting up for all the noise and dust generated by welding and grinding is a pain. I've learned the hard way, though, that I'd better not skip the dust mask, safety goggles and hearing protection. Not that body work is much better.
12-14-2019, 05:18 PM | #216 |
2 thumbs up!!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-16-2019, 02:04 AM | #217 |
MAAAN! I have some catching up to do. Looks incredible, Vic!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
12-16-2019, 09:00 AM | #218 |
The bullets came out nice. I like the divider work too. It's looking great!
12-17-2019, 12:35 PM | #219 | |
And since I'm just getting caught up, I also wanted to say that I hope and pray for the best for you and your wife through your medical difficulties. I assume that your vision has stabilized, and it sounds like your wife is a trooper and working through the medical treatments well. A little awkward to say all that, but it's well-meant and I hope you guys are blessed through Christmas and the New Year. Thanks again for making the effort to share your projects. Last edited by LT7A; 12-18-2019 at 12:21 AM. |
12-17-2019, 07:07 PM | #220 | ||
Thanks, Mike, hope the rat is staying out of the weather. Having lived in Woodinville, I know this time of year is the pits when you have limited space.
Thanks, John! Can't wait to see how your new shop gets set up. Quote:
I'm trying to keep caught up on this thread without posting too much stuff that isn't newsworthy. The reason for the pictures is because I learn new stuff the best when I can see it. If someone tries to explain something to me verbally, it doesn't seem to sink in. But if you give me a demo, that's all I need to get started.
12-17-2019, 10:23 PM | #221 |
Post Whore
Great news about Kathy ...
12-17-2019, 11:02 PM | #222 |
Vic, It’s good to read that Kathy’s doing great. The project is coming along nice!
Scott |
12-18-2019, 12:24 AM | #223 |
12-18-2019, 01:35 AM | #224 | |
12-18-2019, 09:08 AM | #225 |
Great to hear about Kathy. This car is gonna be awesome!
