Old 01-28-2021, 09:09 PM   #201
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
today we repositioned the engine, I think I'm happy with it. tomorrow we'll make it permanent! I think I've been screwed on the intake! I sent him $400, he hasn't answered my email in 5 days. going to contact paypal tomorrow!
skymangs is offline   Reply With Quote
Old 02-02-2021, 08:57 PM   #202
skymangs
skymangs's Avatar
Remade the transmission crossmember today, now the driveline is in the right position!
Old 02-11-2021, 11:16 PM   #203
skymangs
skymangs's Avatar
I finally sourced an LS1 intake (minus injectors and rails). Gonna require some creativity With belt routing, the idler pulley interferes With the throttle body.
This is the belt routing we need
Old 02-12-2021, 10:57 PM   #204
skymangs
skymangs's Avatar
This is the belt routing we need IOT use the car intake! And we finished painting the intake today.
Old 02-13-2021, 08:01 PM   #205
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
theres not alot of belt contact on the crank pulley. Usually at 2/3rds of the pulley is in contact with the belt. So under high load from either the ac or alternator could cause belt slippage. Also which direction does the water pump normally turn on the LS? Ive never looked into one, so re-routing the belt might alter the direction of the pumps rotation.
GreasyLikeaBurger is offline   Reply With Quote
Old 02-13-2021, 10:29 PM   #206
skymangs
skymangs's Avatar
That picture is from LS Simple's website, so I’m sure it’s been R&Ded. I happen to have both those brackets.
Old 02-19-2021, 10:18 AM   #207
skymangs
skymangs's Avatar
we kept running into clearance problems, in the end we decided it would be way easier to rework the truck harness
Old 02-19-2021, 10:22 AM   #208
skymangs
skymangs's Avatar
This bracket allows me to use a GM R4 pancake AC compressor
Old 02-19-2021, 10:29 AM   #209
skymangs
skymangs's Avatar
Here’s the harness after 2 hours of removing plastic sheathing and tape. The Second pic is the pile of what we removed.
Old 02-19-2021, 10:32 AM   #210
skymangs
skymangs's Avatar
Here’s a video of JP reworking the harness https://www.facebook.com/10446154501...63174672146253
Old 02-19-2021, 11:35 PM   #211
skymangs
skymangs's Avatar
pic 1. This is the Harness after 5 hours of pulling 8 injector, 2 coil, MAF, IAC, TPS, ALT, and trans circuits. we still have a few left, we’ll do on Monday
pic 2 & 3. This is the new harness before sheathing.
Old 02-23-2021, 11:52 AM   #212
skymangs
skymangs's Avatar
The first couple pics are the firewall starting to get welded up. The next few are of the harness coming together, and the last is the leftovers.
Old 02-23-2021, 01:36 PM   #213
gigamanx
Wow, sure am glad I decided to just get the Terminator X Max kit for my LS. Pretty cables all ready to install. A little worried about some reviews that the wires are too short. We'll see!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 02-23-2021, 01:54 PM   #214
skymangs
skymangs's Avatar
yeah, I bought a harness for this one but it was for a car intake and wouldn’t fit! Wound up modding one anyway
Old 02-24-2021, 12:13 AM   #215
skymangs
skymangs's Avatar
1.This is the rat's nest of wires we’re dealing with, it’s ever so much harder explaining what to do than to just do it yourself!
2. Here JP combined 2,4,6,8 injecor power into 1 wire
3. Here we are beginning to pin the red and blue connectors, every wire must be lengthened or shortened. All 160 of them!
Old 02-24-2021, 10:33 AM   #216
Tempest67
Tempest67's Avatar
My hat is off to you, as I have no idea what/how you are doing this.
This is why I like carburetors and distributors, and LS motors (computer controlled) scare me.
Tempest67 is offline   Reply With Quote
Old 02-24-2021, 11:26 PM   #217
skymangs
skymangs's Avatar
They really aren’t that scary, once you understand the function of each sensor. A Wiring harness conversion is actually way simpler than this. But I absolutely hate having the harness run in the side of the motor and I hate the PCM being under hood!
Old 02-24-2021, 11:29 PM   #218
skymangs
skymangs's Avatar
1. Firewall progress
2. What we got done on the harness today
3. What’s left
Old 02-25-2021, 08:58 AM   #219
6DoF
6DoF's Avatar
1) your nuts and i like it
2) are those the auto solder/seal shrink tube deals? how do you like em vs the old school way?
6DoF is offline   Reply With Quote
Old 02-25-2021, 09:44 AM   #220
skymangs
skymangs's Avatar
I love them, I buy them in 100 packs on eBay for like $10. Saves tons of time over solder/heat shrink.
Old 02-25-2021, 02:09 PM   #221
Tempest67
Tempest67's Avatar
Skymangs, you make it sound simple, but all those wires intimidates me so much that I stay away from computer controlled engines.
Well done, and like I said before, I tip my hat to you.
Old 02-25-2021, 09:35 PM   #222
skymangs
skymangs's Avatar
1. What we got done today
2. What’s left
Old 02-26-2021, 08:39 AM   #223
6DoF
6DoF's Avatar
don't worry, a lot of ppl are allergic to wiring. #1 symptom is a tingling sensation when you touch them.
Old 02-26-2021, 09:54 AM   #224
skymangs
skymangs's Avatar
ha, ha! I used to be that way, but I realized that the future of hot rodding was LS Engines. And if you’re not growling you’re dying. So it was critical that I learned it!
Old 02-26-2021, 10:06 AM   #225
6DoF
6DoF's Avatar
that can start an interesting conversation ... LS EFI vs Carb. i have yet to see a dyno shoot-out where the carb didn't make better numbers. now, it's basically negligible numbers for most applications, and there's obviously more to it, but the carb aint dead yet!
i'm actually putting a carb on a 2005 truck 6.0L going into my dad's car this summer. different sound and look from EFI, and retains more of the character of driving the car.
